Post by ozzy on Nov 18, 2017 23:50:14 GMT 1
Best way to protect edge of belly pan from heat from allspeed fitted if possible, thought could drop a tad .may be stick some heat shield in, any other options. Cheers Oz, Also seeking nos right rear foot peg, and nos left white side panel.
Post by jollyr6 on Nov 19, 2017 12:07:01 GMT 1
get hold of bertiemollie on here he had a load of nos stuff for sale
Post by jaylee22 on Nov 19, 2017 18:34:57 GMT 1
drop the belly pan away from the pipe by putting something between the inside of the bellypan and the frame bracket where the bolts go through.nuts/washers?
Post by wonkywheel on Nov 19, 2017 20:39:21 GMT 1
drop the belly pan away from the pipe by putting something between the inside of the bellypan and the frame bracket where the bolts go through.nuts/washers? I might try that. I'm having similar problems, and did back in the day. My bellypan is off while the Allspeed is fitted, even the down pipe is too close for my liking.
Post by ozzy on Nov 20, 2017 15:14:20 GMT 1
Ya jay, but the two tabs on belly pan sit in the bottom of rad cover, not much gap to play with,can’t understand why allspeed down pipe off right so much🙄as is touching the side of the belly pan, ready to melt like a welly🙄
Post by wonkywheel on Nov 22, 2017 21:13:10 GMT 1
Ya jay, but the two tabs on belly pan sit in the bottom of rad cover, not much gap to play with,can’t understand why allspeed down pipe off right so much🙄as is touching the side of the belly pan, ready to melt like a welly🙄 It's a joke. I think the only way out is to be a cheap pattern and modify the right side. Something i ain't prepaired to do to a genuine one.
Post by ozzy on Nov 24, 2017 0:04:49 GMT 1
Ya I agree mate .
Post by jaylee22 on Nov 24, 2017 18:14:01 GMT 1
had a few Allspeeds and often had the problem of it melting the bottom of the pan but never the side? are the brackets on the frame that hold the rad cover in place straight? moving the rad cover over slightly will move the belly pan over more. hard to tell with out seeing it but when you fasten the exhaust up there is sometimes room to move it around before tightening it up? hope this helps?
Post by guiri on Dec 5, 2017 23:47:43 GMT 1
Best way to protect edge of belly pan from heat from allspeed fitted if possible, thought could drop a tad .may be stick some heat shield in, any other options. Cheers Oz, Also seeking nos right rear foot peg, and nos left white side panel. i have a nos side panel in white..but ive recently fitted a nos mk2 decal that cost me a right packet so wouldnt get back what it owes me if i sold it. i also have right hand one with no decal and my nos nose fairing to match..
Post by donkeychomp on Dec 28, 2017 1:33:00 GMT 1
Bacofoil? Just a thought.
