Post by wangwang on Nov 11, 2017 19:58:53 GMT 1
Just discovered this small piece missing on the cases I bought to use. I assume it will need repairing ;-(. Recommendations in the Lancs area for alloy welders. Cheers wang
Post by headcoats on Nov 11, 2017 20:29:01 GMT 1
Is it where the kickstart spring sits
Post by wangwang on Nov 11, 2017 20:47:59 GMT 1
Is it where the kickstart spring sits Yeah, you can see a feint line in the case where the spring has gone round from the break!
Post by oldelsieboy on Nov 11, 2017 21:01:50 GMT 1
Just discovered this small piece missing on the cases I bought to use. I assume it will need repairing ;-(. Recommendations in the Lancs area for alloy welders. Cheers wang Send it to Tony at AJ's Vapour Clean he'll sort it. www.ajsvapourclean.com/contact.htmlOEB
Post by wangwang on Nov 11, 2017 22:30:25 GMT 1
Just discovered this small piece missing on the cases I bought to use. I assume it will need repairing ;-(. Recommendations in the Lancs area for alloy welders. Cheers wang Send it to Tony at AJ's Vapour Clean he'll sort it. www.ajsvapourclean.com/contact.htmlOEB Does he do welding too?
Post by Shytalk on Nov 12, 2017 10:16:54 GMT 1
Drill, pin and JB Weld it.
Post by oldelsieboy on Nov 12, 2017 10:27:40 GMT 1
Post by wangwang on Nov 12, 2017 10:55:24 GMT 1
Post by copper99 on Nov 12, 2017 20:31:47 GMT 1
Great workmanship, I think I will take him my upper crankcase for repair (usual, chain snapped and taken out the top section near the engine number)
Post by kostas on Nov 13, 2017 19:59:59 GMT 1
Would putting a bolt and a nut thru the hole just beside the broken section work the same way?
Post by Shytalk on Nov 13, 2017 20:35:16 GMT 1
Post by kostas on Nov 13, 2017 21:02:05 GMT 1
Good enough. If you don't want to strip the engine to get it welded then this is the way forward..
Kostas
Post by wangwang on Dec 21, 2017 22:33:38 GMT 1
All sorted and nice and shiny...
