Post by Mr Kipling on Jan 20, 2019 21:11:41 GMT 1
Now at that stage of do I keep it as a Streetfighter and show the engine off or wrap it in a fairing...…
Post by midlifecrisisrd on Jan 20, 2019 21:16:43 GMT 1
NAKED NAKED NAKED NAKED NAKED NAKED NAKED NAKED NAKED NAKED
Post by philmill on Jan 20, 2019 21:47:30 GMT 1
+1 ON THE NAKED FOR ME TOO...
Phil
Post by dusty350 on Jan 20, 2019 21:48:29 GMT 1
Thanks for the link They do look really nice Dusty
Post by jimmypx on Jan 20, 2019 22:16:47 GMT 1
Naked if you can hide the coils and other small bits. But I do like fairings as well.
Post by Mr Kipling on Jan 20, 2019 22:20:43 GMT 1
Naked if you can hide the coils and other small bits. But I do like fairings as well. Coils , power valve holder etc all gets hidden under the tank..... ;)
Post by Tobyjugs on Jan 21, 2019 0:32:44 GMT 1
With those handle bars I would choose naked
Post by tipfinchy on Jan 21, 2019 18:49:50 GMT 1
if you go for no fairing , polish the underside of the engine as I think with them bars you will be showing it to all as you mono wheel down the street
Post by 4l04ever on Jan 22, 2019 0:02:28 GMT 1
I would go naked if you used the other engine mounting framework, as that looks nicer :-)
Post by 4l04ever on Jan 22, 2019 0:05:03 GMT 1
Maybe worth trying the Tyga seat unit on to see what that looks like on this bike too.
Post by Mr Kipling on Jan 22, 2019 17:12:35 GMT 1
So I took advantage of the sunny weather again today , drilled n tapped n helicoiled a frame fitting , also re attahed the rear subframe and all the gubbins that go with it.....
Post by Mr Kipling on Jan 22, 2019 20:14:22 GMT 1
I would go naked if you used the other engine mounting framework, as that looks nicer :-) Unfortunately the 2 kits are not interchangeable …...
Post by Mr Kipling on Jan 22, 2019 20:17:46 GMT 1
Maybe worth trying the Tyga seat unit on to see what that looks like on this bike too. I was gonna fit the Tyga kit on here but have changed me mind...…. ::)
Post by Mr Kipling on Jan 23, 2019 15:38:24 GMT 1
Little more progress , front brakes firmly re-attached.....
Post by Mr Kipling on Jan 25, 2019 16:05:56 GMT 1
So I,ve been waiting on an ignition switch too arrive which has finally , but now the head scratching starts as it doesn't fit into the space I have available and the std switch neither fits either... funny thing is the switch fitted the Std top yoke but not the billet yoke Oh the joys of swapping components.....I,m gonna have too sort this conumdrum out before I press onto the next phase of the build…..Guess I,ll have too track down the std top yoke....its here somewhere repeat SOMEWHERE.....
Post by mouse on Jan 25, 2019 18:43:11 GMT 1
That is one sweet looking rolling chassis Mr K
Mouse
Post by Mr Kipling on Jan 26, 2019 14:54:04 GMT 1
So it turns out the offset for the ignition switch on the billet yoke is wrong , thus not allowing the ignition too fit so ive found the std yoke and will get a spacer made up too allow me to use this instead , once I,ve done this I,ll have it vapor blasted n I,ll be ready for the next part of my build.....
Post by Mr Kipling on Jan 28, 2019 17:04:37 GMT 1
Aargh , 2 steps forward 3 steps back , I now have a bare frame again as the ignition has thrown up another surprise resulting me having too strip it back bare again...easy fix but annoying all the same...
Post by Mr Kipling on Jan 31, 2019 13:52:52 GMT 1
Frame back from the engineers , bit of reshaping and I,m good to go....
Post by midlifecrisisrd on Jan 31, 2019 20:43:30 GMT 1
Frame back from the engineers , bit of reshaping and I,m good to go.... Keep your chin up, will be worth it in the end Steve
Post by Mr Kipling on Feb 2, 2019 16:15:20 GMT 1
Frame back from the engineers , bit of reshaping and I,m good to go.... Keep your chin up, will be worth it in the end Steve Yeah I know its all part of the swings and roundabouts that make building hybrids fun.... ::)
Post by Mr Kipling on Feb 3, 2019 14:45:23 GMT 1
Braved the cold but sunny weather too re-assemble my rolling chassis today , need too vapor blast me top yoke next but slowly getting back on track....
Post by Mr Kipling on Mar 27, 2019 18:36:04 GMT 1
So the build is returning back too a Streetfighter as per original heading with a couple of new changes , first change is the fitment of these R6 Forks fitted with Ohlins internals , I,m awaiting on a few nuts n bolts but then can restart the build..
Post by oldbritguy on Mar 27, 2019 18:38:43 GMT 1
Lookin' lovely Mr K
Them forks are well nice!!!!!
Post by Tobyjugs on Mar 27, 2019 20:00:35 GMT 1
Great to see some movement on this Mr K
Post by philmill on Mar 27, 2019 22:21:57 GMT 1
I'm looking forward to watch this start to move forward again.
Phil
Post by 525bri on Apr 3, 2019 17:19:50 GMT 1
I thought the front end looked great, why the change?
Post by Mr Kipling on Apr 9, 2019 15:20:36 GMT 1
I thought the front end looked great, why the change? Simples , the black front end is better equipped...... ;)
Post by Mr Kipling on Apr 13, 2019 20:43:45 GMT 1
Spent the whole week searching for a billet sidestand too no avail , feel like calling time on this one too as I,ve lost my enthusiasm...
Post by dusty350 on Apr 13, 2019 21:14:50 GMT 1
Have you tried Billetworld ? Dusty
