Post by dusty350 on Nov 1, 2017 19:36:58 GMT 1
Hi Done a search for wiring the twin Banshee coils, but it seems all previous pics were linked to Photof**kers, so I cant see them Anybody got any pics ? It's for my Lc. I'm guessing an orange from the looms coil connector to the spade on one coil, and then linked to the other coil's spade connector. Then the opposite ends of the coil linked together and earthed ? Is that right ? Thanks Dusty
Post by Tobyjugs on Nov 1, 2017 20:12:10 GMT 1
Hi Dusty the orange wire go to both coils and the black wire earths to the frame. In the picture below i used an orange red wire instead of orange.
Post by dusty350 on Nov 1, 2017 21:12:04 GMT 1
Cheers mate, that's great Any reason you mounted them upright rather than flat ? Regards Dusty
Post by Tobyjugs on Nov 1, 2017 21:15:03 GMT 1
I think they they fit better but i had to make a small bracket to support the other side
Post by dusty350 on Nov 1, 2017 21:32:16 GMT 1
Ah ok. Haven't offered mine up yet, although I did get a pair of brackets from Norbo. Will have a play around with it when I get time. Cheers Dusty
Post by sbscnor on Nov 1, 2017 21:37:57 GMT 1
Dusty if you can hang on till tomorrow I can put a pic up using Norbo's mounting plates for you.
Post by dusty350 on Nov 1, 2017 21:45:42 GMT 1
Hi Colin That would be great thanks. Any ideas/pics are good. Probably be Friday before I can get a look at them Regards Dusty
Post by Tobyjugs on Nov 1, 2017 21:55:43 GMT 1
I don't think it matters which way you fit them, this was easier solution for me.
Post by rigga on Nov 1, 2017 22:33:51 GMT 1
Post by dusty350 on Nov 2, 2017 8:18:25 GMT 1
Thanks for that Rigga Just to confirm - I will connect an orange wire from the looms coil plug to one spade, then piggyback that to the other spade. The black from the loom 's coil plug is redundant, and you just earth the 2 coil bodies to the frame ? Dusty
Post by Tobyjugs on Nov 2, 2017 9:02:54 GMT 1
No dusty that's not exactly correct. You should have two wires from the connector, a black wire and an orange wire.
The black wire grounds onto the frame. you can see the wire ground to the chassis using the button head allen bolt in the picture.
Just like you said the orange wire go's to connector on a coil and is then bridged to the other coil.
My coils are bolted directly to the frame so they could be earthing or not i never paid attention to that aspect.
Post by stusco on Nov 2, 2017 9:12:04 GMT 1
When fitted flat you need to have them touching or they rattle of your tank and drive you insane
Post by skint on Nov 2, 2017 9:28:49 GMT 1
I used a double bullet connector from the orange loom wire then taking a wire to each coil and earthed the black wire to the mounting bracket. Works fine.
Post by dusty350 on Nov 2, 2017 16:18:25 GMT 1
Cheers everyone Think I've got it now ! A job for tomorrow, hopefully Dusty
