oh no
Oct 9, 2017 10:51:49 GMT 1
Post by jollyr6 on Oct 9, 2017 10:51:49 GMT 1
Out with broughton yesterday for a bimble all run in last time i did a plug chop was running rich so left as is because ive got a gianelli pipe on,giving it some beans flew past him and a few cars then boom locked back wheel up took a nano second to comprehend what was happening brain kicks in while pulling a 20 mtr skip ferk pulled clutch in,pulled up thinking oh no.good old broughton had his trusty tool kit with him pulled plug out nice and grey n says youve seized it, i continue stripping by the roadside whenn waiting for a very nice man in a yellow van to turn up dropped water head off front of piston melted,looks like no damage to bore. question is this if bores not damaged can i just replace piston n rings or is it strip crank ?? ps my own fault i was caning it lol
oh no
Oct 9, 2017 15:36:59 GMT 1
Post by stusco on Oct 9, 2017 15:36:59 GMT 1
Is it holed? Did debis go down into the crank if it did could be a problem
oh no
Oct 9, 2017 17:01:17 GMT 1
via mobile
Post by jollyr6 on Oct 9, 2017 17:01:17 GMT 1
Is it holed? Did debis go down into the crank if it did could be a problem No not holed looks like rings are intact too will know later when I take head off
oh no
Oct 9, 2017 17:14:32 GMT 1
Post by stusco on Oct 9, 2017 17:14:32 GMT 1
In that case I would risk it
oh no
Oct 9, 2017 18:51:42 GMT 1
Post by looey on Oct 9, 2017 18:51:42 GMT 1
Bummer What's your setup (carb, jetting, airbox/pod etc.)?, they very rarely have timing/ignition issues and with the right jetting you can thrash them all day. I have thrashed mine to death for several thousand miles and it's been fine
oh no
Oct 9, 2017 20:17:39 GMT 1
via mobile
Post by jollyr6 on Oct 9, 2017 20:17:39 GMT 1
Bummer What's your setup (carb, jetting, airbox/pod etc.)?, they very rarely have timing/ignition issues and with the right jetting you can thrash them all day. I have thrashed mine to death for several thousand miles and it's been fine Used one of those eBay carbs so don't know what jets are in it looking at it it's been running lean slight melted piston top on bore hopefully be able to hone it
oh no
Oct 9, 2017 20:18:27 GMT 1
via mobile
Post by jollyr6 on Oct 9, 2017 20:18:27 GMT 1
If not anyone know where I can get a robore near Lincolnshire? ?
oh no
Oct 9, 2017 20:28:03 GMT 1
Post by looey on Oct 9, 2017 20:28:03 GMT 1
Bummer What's your setup (carb, jetting, airbox/pod etc.)?, they very rarely have timing/ignition issues and with the right jetting you can thrash them all day. I have thrashed mine to death for several thousand miles and it's been fine Used one of those eBay carbs so don't know what jets are in it looking at it it's been running lean slight melted piston top on bore hopefully be able to hone it Ouch, well there's ya problem. RD's need to be upjetted off the standard exhaust, I doubt any carb off eBay would be jetted right out the box. What type of carb is it ? 10W ? If you can post your barrel, I can put you in-touch with a decent bloke to do you a rebore & piston.
oh no
Oct 11, 2017 16:43:15 GMT 1
Post by mudguts on Oct 11, 2017 16:43:15 GMT 1
gianelli pipe always melt pistons, downpipe too narrow
