Post by ozzy on Jul 30, 2017 16:26:28 GMT 1
My kill switch not working 🤔 Any ideas lads. Checked connection s inside switch, connection in lamp, all good.
Ta.
Is it possible the switch is also earthed sat clamped on the bars, as mine have been power coated wonder if the paint thickness is stopping the switch working correctly.
Post by jorjasfather on Aug 2, 2017 18:41:57 GMT 1
Hi there I think that's your problem there is a contact on the edge inside the right hand switch which contacts with your handle bars and the paint is stopping it making contact
Post by Gunny on Aug 6, 2017 0:42:34 GMT 1
Just turn the key off instead ?
Post by smallstroker on Aug 7, 2017 21:44:37 GMT 1
My kill switch not working 🤔 Any ideas lads. Checked connection s inside switch, connection in lamp, all good. Ta. Is it possible the switch is also earthed sat clamped on the bars, as mine have been power coated wonder if the paint thickness is stopping the switch working correctly. Hi I have had this before could definitely be the powder coating, I have just had to use an over size drill bit on my earth screw hole to take the edge of the hole to bare metal.
Post by ozzy on Aug 8, 2017 23:53:15 GMT 1
Ya cheers lads thought may be the cause, yes gunny of course.👍🏻
