Post by russpuss on Jun 26, 2017 21:03:29 GMT 1
The riddler tank has been flushed on several occasions with vinegar and nuts and then petrol, but it's still clogging filters, any advice on how to clean out tank better without affecting paint lads?
Post by midlifecrisisrd on Jun 26, 2017 21:09:01 GMT 1
Have you tried using the metal ready stage of the por 15 kit
Post by russpuss on Jun 26, 2017 21:14:02 GMT 1
Have you tried using the metal ready stage of the por 15 kit Steve No just the above mentioned, can that be used and got out without damaging the paint?
Post by midlifecrisisrd on Jun 26, 2017 21:35:09 GMT 1
I'd have to see if I still have some and read the label.
I know the marine clean is a strong alkali and could but can't remember about the other stuff.
Deox c is also really good for de rusting and is safe on paint
Post by russpuss on Jun 26, 2017 21:47:12 GMT 1
I'd have to see if I still have some and read the label. I know the marine clean is a strong alkali and could but can't remember about the other stuff. Deox c is also really good for de rusting and is safe on paint Steve Thanks I've ordered some deox c off the bay, got to be worth try.
Post by midlifecrisisrd on Jun 26, 2017 21:52:09 GMT 1
It's really good stuff.
I got a 20L drum from work and keep it in there.
Mix it with warm water as it dissolves better.
Not just for tanks, will derust anything steel
Post by jon on Jun 26, 2017 21:52:15 GMT 1
Deox C works better if warm. Stick a fish tank heater inside.
Good stuff, highly recommended.
Next time I'm going to try electrolysis, just to compare the two.
Post by russpuss on Jun 26, 2017 21:53:40 GMT 1
Deox C works better if warm. Stick a fish tank heater inside. Good stuff, highly recommended. Next time I'm going to try electrolysis, just to compare the two. Jon Nice 1 I have 1 of those in the mancave so I'll try that with it.
Post by stusco on Jun 26, 2017 22:11:14 GMT 1
I used deox on a freshly painted mark cordwell paint job I was shitting myself but all was fine
Post by russpuss on Jun 26, 2017 22:13:24 GMT 1
I used deox on a freshly painted mark cordwell paint job I was shitting myself but all was fine It's for my riddler hybrid so to say I'm crapping it is an understatement! Had major issues with my last resto with tank sh1t so don't need it again, just ordered 50 inline fuel filters from china so I'll use them too.
Post by midlifecrisisrd on Jun 26, 2017 22:19:24 GMT 1
I used it on a newly painted tank as well without damage
I deox'd it then emptied and stuck a hose in the filler and ran water through it for 5 mins then drained then emptied a can of wd40 into it to disperse the water, emptied then put it somewhere warm to dry
It never rusted and I always stick 50ml of oil in each tankful to keep rust at bay
Post by bare on Jun 27, 2017 1:26:20 GMT 1
GOOGLE: derusting a tank using electrolysis. Easy Cheap AND it works. You will/may have to deal with crappy perforated tank metal afterwards though. But your Tank Will be rust free.
Post by steeley on Jun 27, 2017 6:38:07 GMT 1
Citric acid is the stuff . 10 to 20 grams per ltr at 28c works best. as said earlier fish tank heater to warm it up. cleaned loads of tanks with this stuff inside and out. oh also used on painted tanks no problem.
Post by tony1964 on Jun 27, 2017 10:09:40 GMT 1
When i cleaned my tank out prior to lining it i put 20 self tapping screws in it as well as the metal agent and shook it for ages, screws helped remove any crap in the tank.
Post by steven on Jun 27, 2017 12:35:33 GMT 1
Post by russpuss on Jun 28, 2017 21:47:11 GMT 1
Deox c and fish tank heater in now, see what happens in the morning.
Post by botty on Jun 29, 2017 0:03:40 GMT 1
Deox c and fish tank heater in now, see what happens in the morning. Looking forward to the results. Morning checklist. 1. Kettle on 2. Check tank 3. Drink tea smiling with achievement.
Post by jon on Jun 29, 2017 19:37:18 GMT 1
Deox c and fish tank heater in now, see what happens in the morning. You will see good results overnight, but even better in a few days. Jon
Post by russpuss on Jun 30, 2017 17:51:10 GMT 1
Tank is now happy, thanks for the help chaps.
Post by scootjockey on Jul 8, 2017 21:15:31 GMT 1
Tank is now happy, thanks for the help chaps. I've got the same issue with a fuel tank for my FZ400R just so I've got this right you put the fuel tank in a fish tank with the Doex c and a heater ? Or poured the Deox C in the fuel tank with a fish tank heater ??
Post by russpuss on Jul 8, 2017 21:17:02 GMT 1
Tank is now happy, thanks for the help chaps. I've got the same issue with a fuel tank for my FZ400R just so I've got this right you put the fuel tank in a fish tank with the Doex c and a heater ? Or poured the Deox C in the fuel tank with a fish tank heater ?? Boiling water mixed in tank then added a fish tank heater to tank and left overnight.
Post by stusco on Jul 8, 2017 21:31:30 GMT 1
It still works without the heater
Post by datacol on Jul 9, 2017 11:58:14 GMT 1
secure to (not in!) a concrete mixer with chain and 500ml of diesel inside. an hour should do it.
Post by jon on Jul 9, 2017 18:41:55 GMT 1
It still works without the heater Stusco, I know it does, but the instructions suggest it works 'better' at higher temperatures. If you have a spare fish tank heater why not? Jon
Post by stusco on Jul 9, 2017 19:01:45 GMT 1
It still works without the heater Stusco, I know it does, but the instructions suggest it works 'better' at higher temperatures. If you have a spare fish tank heater why not? Jon I've just bought one from eBay £6 worth a try
nigep
Post by nigep on Jul 9, 2017 19:21:35 GMT 1
We're in the middle of summer enjoying a heatwave. Wtf do you want a heater?
Post by stusco on Jul 9, 2017 20:01:44 GMT 1
pissing down here in edinburgh
Post by scootjockey on Jul 9, 2017 20:45:45 GMT 1
We're in the middle of summer enjoying a heatwave. Wtf do you want a heater? If only that were true here on Tyneside !
Post by mellow on Sept 10, 2018 17:27:44 GMT 1
Just to revive this........I have a tank with some light rust inside i want to treat......should i clean out with chain/gravel/screws etc then rinse then Deox c or Deox c first? what would you say best procedure?
Post by oldelsieboy on Sept 10, 2018 17:36:06 GMT 1
Just to revive this........I have a tank with some light rust inside i want to treat......should i clean out with chain/gravel/screws etc then rinse then Deox c or Deox c first? what would you say best procedure? Deox-c is all you will need. OEB
