Post by ukcalling on Jun 4, 2017 20:39:35 GMT 1
Anyone know if the LH rear axle spacer is the same for a vj21 and a vj22?
Need on fir my hybrid and can get one off a vj21 but have a vj22 whee and arm
Thanks Nick
Post by Slabsideian on Jun 21, 2017 7:45:11 GMT 1
Don't know but look on mr cycles website. It gives you exploded views of all bikes and parts with part numbers etc 👍🏻
Post by yamark on Jun 24, 2017 17:32:42 GMT 1
Anyone know if the LH rear axle spacer is the same for a vj21 and a vj22? Need on fir my hybrid and can get one off a vj21 but have a vj22 whee and arm Thanks Nick Sorry I missed this Nick, yes the spacer is the same. Part number 6475122D00 is listed for both models.
HTH Mark
Post by ukcalling on Jun 29, 2017 14:58:25 GMT 1
Mark - got one for a vj21 and it appears circa 10mm (guess from memory) not wide enough.
Dont suppose you know what the dimension is as looks likley the one I have is not a vj21 one if you are right
Thanks Nick
Post by yamark on Jun 29, 2017 21:31:46 GMT 1
Hi Nick, I checked the part numbers for both models and I'm fairly sure they were the same. I might have a spacer spare; I'll check at the weekend for you.
Cheers Mark
Post by ukcalling on Jun 30, 2017 7:12:54 GMT 1
Brilliant thanks
I may be getting confused as looking at the 89 then 92 RGV on the CMSL website and they are different part numbers.
I am fitting the banana arm to my 4L0 so need the spacer to suit that
Appreciate your help
Thanks Nick
Post by yamark on Jun 30, 2017 21:46:49 GMT 1
Nick, you are right, the part numbers are different. I just checked and I have the later type spacer, and as luck would have it - it's just been freshly zinc plated The spacer I have is 20mm wide. Let me know if that's right. If it is correct, PM me your details and I'll get it in the post
Cheers, Mark
Post by ukcalling on Jul 1, 2017 9:00:56 GMT 1
Mark think I've sent you a pm, think its gone, or may have done it twice so if so apologies!
Thanks Nick
