Thanks for the comments. Heres the spec list
Chassis
Spondon TZ250 Chassis and Swingarm
2003 TZ bodywork
TZ Nissin calipers with SBS Duel carbon pads.
Ohlins Forks with modified 2017 R1 internals
Ohilins rear shock
Harris quick release clip ons
TZ quick action throttle / renthal grips
CRG clutch perch and lever
Brembo radial master cylinder and hel braided brake likes
Brembo integral rear master cylinder.
Custom made billet rear sets
RD 500 kick start
MBD Carbon fibre gear linkage
Dymag carbon fibre wheels with ceramic bearings
GMX Custom made radiator
EBC pro lite discs
Lithium battery
Translogic dashboard
Custom made wiring loom
RGV 500 steering damper
Pingle hi flow fuel tap
Engine
Cheetah cub cylinders
MBD modified wiseco pistons
MBD +4mm crank with Ceramic bearings
Wicked head with MBD Domes
MBD Billet thermostat holder
MBD Modified V force 4 reed blocks
MBD Modified 38mm mikuni TMX carbs
Pipercross air pod filters
MBD billet intakes
Nova close ratio gear box and all other parts super finished
Ceramic gearbox and water pump bearings
Nova straight cut primary
MBD billet clutch basket
MBD heavy duty clutch pack
Wicked clutch pusher
Billet shift star
Shift pro
Straight cut water pump gears
RS Racing Exhausts
Zeeltronic ignition
Pro Designs adjustable timing plate
