Post by phil1rowe4 on Apr 25, 2017 7:14:45 GMT 1
Hi lb,
Thanks mate. I'm in Brisbane
Phil
Post by phil1rowe4 on Apr 25, 2017 14:04:45 GMT 1
A successful weekend tinkering in the garage.
Pistons delivered to machinist to have the bores sized for the new pistons. New clutch basket fitted. Started going through the bags of parts to start cleaning them up. Polished the power valve covers and thermostat housing and started cleaning up several bits for painting. Ended up sandblasting the covers to remove a previous owner's spray can antics! Also cleaned up the sloppy power valve joiner in the mill to re-face the flat section the valves locate on and the two joint faces so it closes on the valves more effectively. It's now a good solid joint with no play between the valves.
Post by Deleted on Apr 26, 2017 4:38:05 GMT 1
Allens performance will do your needles
I have a spare set if you need to check them out
You have my number on a PM
Post by phil1rowe4 on May 1, 2017 3:15:37 GMT 1
Here's the results of the weekend.
I've painted the side covers to try and match the engine cases and cleaned up the barrels. The barrels will go off for vapour blasting to get the gunk I couldn't get.
I've also matched the transfer ports and found some issues with the exhaust stud threads that have been butchered by a previous owner. One will need a thread insert and the other needs filling and redrilling as it's on a significant angle.
Also waiting on more bits from the US and UK before I can start the engine rebuild. I managed to find a brake lever to fit the RGV Master cylinder and just need to find a master cylinder rebuild kit now.
Post by yamark on May 1, 2017 17:18:32 GMT 1
Looking very smart. Great work. It's going to be a stunner
Post by copper99 on May 1, 2017 18:00:44 GMT 1
Looking very smart. Great work. It's going to be a stunner My thoughts exactly, great build mate.
Post by mouse on May 2, 2017 7:33:56 GMT 1
Really like that, the silver finish looks great!
Mouse
Post by phil1rowe4 on May 2, 2017 9:35:34 GMT 1
Thanks guys. It has a matt clear coat on it so hopefully will withstand some wear and tear. It'll be inside the fairing so shouldn't get too many knocks & chips.
Post by phil1rowe4 on May 9, 2017 10:59:04 GMT 1
Just got some shiny bits from Norbo and threw them together for a quick mockup.
Now have all the bits to start rebuilding the motor over the weekend.
Have also finished with the frame and it's off to be sand blasted tomorrow and start priming it over the weekend.
Post by phil1rowe4 on May 15, 2017 14:02:20 GMT 1
Progress update: Motor has gone together pretty well so far. Discovered I had the wrong head cups, so trying to organise some replacements.
Frame has been bead blasted and front brake caliper and master cylinder refurb kits arrived. Lots to do.
Post by stusco on May 15, 2017 14:11:20 GMT 1
Are you doing an air test?
Post by phil1rowe4 on May 15, 2017 14:35:36 GMT 1
Air test?
I am getting the bits together to make a leak down tester, for when the assembly is completed.
Post by stusco on May 15, 2017 16:44:26 GMT 1
You must be confident I did that then had to strip it all down,I would test it before fitting the clutch and stator so you can see if it leaks
Post by phil1rowe4 on May 16, 2017 5:48:09 GMT 1
I'm either naive or confident. I'll let you know after the test! 😯
Post by phil1rowe4 on May 21, 2017 14:24:00 GMT 1
While waiting for some final engine parts to arrive, I've started on the frame and some other jobs. The frame is now bead blasted, rust treated and undercoated, and should be painted by next weekend. I'll have to setup a temporary spray booth in my garage which takes a bit of time.
I've also opened up the front calipers and master cylinder and they were a mess of old congealed brake fluid, so should work much better after a clean and rebuild kits fitted.
Post by lb on May 23, 2017 0:07:11 GMT 1
Geez Phil you font muck around lol. I found this & thought it might be similar in the paint style your looking for. Found it on North American rz fb page. On that same fb page look for David Zilla project. I think it very close to fairing you're using. Cant hurt to have a chat with him & exchange idea's.
Post by phil1rowe4 on May 23, 2017 3:56:22 GMT 1
Thanks mate,
That's amazingly close to the result I'm looking for. Just shows that its all been done before!
I'd be very pleased if it turned out like that.
Cheers, Phil
Post by phil1rowe4 on May 27, 2017 13:06:16 GMT 1
I have too much crap in my garage! It took quite a bit to make enough space to setup the spray booth, but I finally got there. Couple of bikes parked on the deck and the other half of the garage is an occupational safety nightmare! A day and a half to build it and 5 minutes to tear it down!
The frame is now painted and ready to start bolting bits back on. It's a milestone in the project, so I'm pretty chuffed (pleased!). (just hope I haven't forgotten a bracket!)
Have also started rebuilding the front calipers and got one side blasted in the cabinet.
Post by phil1rowe4 on May 28, 2017 9:33:57 GMT 1
Swing arm and rear shock bolted in.
Post by mouse on May 28, 2017 11:37:24 GMT 1
Looks great! That is some shine on the swingarm!
Mouse
Post by yamark on May 28, 2017 19:28:14 GMT 1
Looking superb, great work
Mark
Post by doohanno1 on May 28, 2017 20:42:59 GMT 1
That looks great. Handy having all that workshop equipment at your disposal and of course the skills to use them..🏍
Post by phil1rowe4 on May 29, 2017 3:33:22 GMT 1
Looks great! That is some shine on the swingarm! Mouse I cheated with the swingarm. I normally do my own polishing but outsourced the swingarm to a professional polishing place. They did a good job.
Post by phil1rowe4 on May 29, 2017 3:38:03 GMT 1
That looks great. Handy having all that workshop equipment at your disposal and of course the skills to use them..🏍 I enjoy the fabricating and building as much as the riding. I'm currently rebuilding bikes from my mis-spent youth, but the next project will be different again.
Post by phil1rowe4 on May 29, 2017 13:09:02 GMT 1
I couldn't resist having a play....
Post by phil1rowe4 on Jun 5, 2017 10:39:17 GMT 1
Latest update: The new Cool head domes arrived last week so after some time messing around measuring squish I have the motor all buttoned up. I then did a pressure test and found some leaks around the power valves and exhaust joints. Fixed those up and it tested ok.
The motor is now in the bike and the clutch cover temporarily attached to see how it looks. The forks are being now being reconditioned and the calipers painted. The fork oil was some of the dirtiest, smelliest oil I've seen and definitely needed replacing! Does anyone have any advice/tips about getting the old fork seals out of the RGV forks to separate the inner and out tubes?
Lots of little jobs now cleaning up and painting parts. Thinking about a new ignition/PV system with Banshee coils, but I don't have a dyno or know of anyone local with 2T experience, so I'm not sure how easy they will be to setup from scratch. Any advice?
Post by mouse on Jun 5, 2017 13:17:19 GMT 1
That is looking very, very nice. Love the red frame against the silver engine
Mouse
Post by phil1rowe4 on Jun 6, 2017 14:34:56 GMT 1
Thanks Mouse,
It's shame to hide it behind a fairing.... maybe a half fairing?
Post by mouse on Jun 7, 2017 6:58:24 GMT 1
Thanks Mouse,
No, i like the full fairing. Not sure the pipes look quite right though, sorry, they look a bit long and low, but that is only my opinion Mouse
Post by dusty350 on Jun 7, 2017 7:31:10 GMT 1
Hi Great skills It's gonna be a stunning special ! Well done Dusty
