Post by dusty350 on Oct 14, 2018 15:58:21 GMT 1
Much better !! Dusty
Post by headcoats on Oct 14, 2018 18:19:07 GMT 1
Yes better shorter and in carbon It adds to contrast as the pipes are silver and footrest hangers the same
Post by donkeychomp on Oct 14, 2018 23:01:18 GMT 1
Steve what's that front caliper?
Post by midlifecrisisrd on Oct 14, 2018 23:05:08 GMT 1
Steve what's that front caliper? Alex It's a radial monoblock set on adaptor brackets Steve
Post by donkeychomp on Oct 15, 2018 0:33:35 GMT 1
Looks bonkers I love it!
Post by headcoats on Oct 15, 2018 9:21:45 GMT 1
Got to be 180mm Steve Steve do you have any pics of how the left pipe fits the frame ?
Do you have rubber isolators damping the exhaust ?
Just asked Kenny to do some 180mm carbon sleeves
Post by midlifecrisisrd on Oct 15, 2018 10:35:38 GMT 1
Hi The nk hangers have rubber mounts on them Left hand pics Steve
Post by midlifecrisisrd on Oct 15, 2018 10:37:42 GMT 1
Last pic a little dark, here's another Steve
Post by headcoats on Oct 15, 2018 11:48:33 GMT 1
Cheers
Nice design of the NK hangers
Was looking at some KTM exhaust dampers to mount on the left hanger lower bolt
Post by midlifecrisisrd on Oct 15, 2018 11:54:27 GMT 1
Post by headcoats on Oct 15, 2018 12:18:03 GMT 1
This is what I was looking at but got to find a UK supplier Yes I looked at those and they are certainly an easy to get part
Post by midlifecrisisrd on Oct 15, 2018 12:27:30 GMT 1
Post by headcoats on Oct 17, 2018 11:38:04 GMT 1
The thin strip of yellow tape tape is showing 180mm length !
richb
Post by richb on Oct 17, 2018 13:17:30 GMT 1
Nice looking red rd, personally leave cans long they look fine to me but I will say do something with the rear mudguard that just looks wrong. Guess you will say only dry fitted and will be adjusted though. Looking good all the same will be nice when finished anyway.
Post by headcoats on Oct 17, 2018 13:25:50 GMT 1
Yes the rear mudguard may change :-) With the reg plate on though you don't see that much I don't like the recessed tail light either and I use that space for the 2 stroke bottles foe premix
Cans don't look too bad in pics but one is dented anyway (got it cheap) so needs to be changed , still want carbon though !
Post by jessy03 on Oct 17, 2018 22:25:06 GMT 1
R1 exhaust mount might work?
Post by headcoats on Oct 17, 2018 23:59:41 GMT 1
That looks sturdy Jessy :-)
Post by headcoats on Oct 26, 2018 11:02:52 GMT 1
Making a list to what I want powder coated
Seems a lot ! Frame Swing arm Bottom yoke Rear subframe Lifting handle horn bracket footrest brackets X4 Clock bracket Engine brackets Rear m.cylinder bracket for YPVS MC Tie bar brackets Rear caliper bracket clutch cover side stand Lomas left mount bracket RGV chain adjusters Front indicator stalks Foot brake
Anything else !
All in satin black too
Post by donkeychomp on Oct 26, 2018 22:27:26 GMT 1
The chain adjusters? Will they fit afterwards?
ps yes, that's a lot!
Post by headcoats on Oct 27, 2018 10:00:45 GMT 1
You are probably right Donk :-)
Just remembered the grab rail too !
Post by headcoats on Nov 16, 2018 21:25:12 GMT 1
Stripping it back down for powder coating !
So I needed to tackle the German steering lock
Marked it up and drilled it and elongated the hole as the pin of the lock has flat sides
Got it spot on but found a problem DOH !
As it's an RGV steering stem I have had to mod, I think outside diameter of the stem is thinner than an LC one because the pin of the lock doesn't go deep enough
Only thing I can think of is to weld a thick washer on with an elongated hole ? The stem is thinner in the middle so the lower bearing will Passover , maybe keep it 3mm thick ?
Anyone have the OD of an LC steering stem please
The RGV one is 25.48mm
Post by Trubrit on Nov 17, 2018 7:30:51 GMT 1
LC Stem = 29.5mm
Post by headcoats on Nov 17, 2018 8:48:19 GMT 1
That's the problem then !
Post by headcoats on Nov 19, 2018 10:55:20 GMT 1
This is how I hope to fix the problem Cut the same slot in a bit of tube , then shorten it, split it at the back and bend it round the stem and get it welded Any other ideas ? I think too the steering locks come in different lengths but finding the correct one would be hard
Post by headcoats on Nov 22, 2018 20:48:49 GMT 1
Thought I could just slit the back of the tube but the bearing wouldn't pass over that way , so chopped the sides off and now the bearing passing over is fine
Just need to get the fecker welded now !
Post by headcoats on Nov 25, 2018 15:02:57 GMT 1
Got it welded on , so onwards and upwards !
Basically it has just made the tube the same diameter as the LC one in the locking hole area
Post by headcoats on Nov 26, 2018 10:25:27 GMT 1
Fitted the lock and it works OK but have a bit of slop , as in the bars move side to side a bit with the pin locked
There is no play in the slot in the stem I cut, I was careful about that , but the play looks like it's in the key barrel as it sits in the frame
Don't know if I can fix that , or ask the powder coaters to coat inside the barrel hole on the frame to close the gap up LOL
Post by headcoats on Dec 7, 2018 12:40:32 GMT 1
Making a list to what I want powder coated Seems a lot ! Frame Swing arm Bottom yoke Rear subframe Lifting handle X2 horn bracket footrest brackets X4 Clock bracket Engine brackets Rear m.cylinder bracket for YPVS MC Tie bar brackets Rear caliper bracket clutch coverAlternator cover side stand Lomas left mount bracket RGV chain adjusters Front indicator stalks Foot brakeGrab rail X2Headlamp rim X2£155 all in Satin black Anything else ! All in satin black too
Post by headcoats on Dec 12, 2018 22:22:11 GMT 1
Bollox Bollox Bollox ARGGGHH!!!!!
Seems I have lost one of my N K Racing Headlamp clamps to fit the RGV forks FFS
I had them anodised black too
Really hacked off, looked everywhere
So I need to ask Nigel if he can make one but then it will need anodising black to match the other 3 or do I get 4 made in bare billet alloy
I bet getting one done with anodising wouldn't be much less than 4 made ?
Will have to see but that is a bummer man :-(
Post by wallcraft on Dec 12, 2018 23:26:06 GMT 1
Bet it's either under the work bench or in the wheelie bin going by my mis-laid items!!
