Post by ianboom on Nov 26, 2019 15:16:42 GMT 1
Looking really good, have you started it yet :-) Could you put a P clip through the hole on the tabs on the swingarm to position the hose?
Post by headcoats on Nov 26, 2019 15:28:15 GMT 1
I have some P clips and I had the hose made a bit longer so hopefully I can space the hose to the right and have a slight loop as it approaches the master cylinder ?
Not started it yet ! Ignorance is bliss on the teething problems LOL
Like I mentioned too about running it this time of year, I didn't want to fill the engine with condensation :-( I will only be doing heat cycles as it still needs UK registering etc
Post by stusco on Nov 26, 2019 17:21:54 GMT 1
Post by headcoats on Feb 24, 2020 18:25:25 GMT 1
Just a build update I have removed the layer of dust off the bodywork on top of the wardrobe
Post by sidney81 on Feb 24, 2020 18:38:37 GMT 1
Just a build update I have removed the layer of dust off the bodywork on top of the wardrobe makes the dusting more interesting 🤣
Post by Yogi on Feb 24, 2020 20:42:30 GMT 1
🤣🤣 glad it’s not just me taking over the wardrobe tops
Post by headcoats on Feb 24, 2020 20:49:09 GMT 1
How often do you dust LOL
Post by Yogi on Feb 24, 2020 21:14:44 GMT 1
How often do you dust LOL Lol,not enough apparently 🤣 there covered in it 🥴
Post by veg on Feb 25, 2020 14:22:22 GMT 1
Pink walls jesus H, those wardrobes hiding your negligee and slip on mules?
Post by headcoats on Feb 25, 2020 14:55:15 GMT 1
Pink walls jesus H, those wardrobes hiding your negligee and slip on mules? I didn't want to mention it !
Must be his inner unicorn LOL
Post by midlifecrisisrd on Feb 25, 2020 17:09:22 GMT 1
And you think those pretty little storage bags are more masculine 🤔 Steve
Post by headcoats on Feb 25, 2020 17:15:51 GMT 1
CDs and bike stash lie within LOL
Post by Yogi on Feb 25, 2020 22:24:50 GMT 1
Pink walls jesus H, those wardrobes hiding your negligee and slip on mules? Only real men can get away with pink 💪 The missus made me do it 🧒🏻. Honest 🥴
Post by Yogi on Feb 25, 2020 22:27:04 GMT 1
Post by headcoats on Mar 2, 2020 13:06:25 GMT 1
Got the end cans from Kenny yesterday He resleeved in carbon for me
Post by donkeychomp on Mar 4, 2020 0:04:26 GMT 1
Can porn.
Post by Mr Kipling on Mar 4, 2020 19:47:27 GMT 1
Looking great....
Post by headcoats on Mar 17, 2020 13:03:33 GMT 1
Just done the brakes and what a pain in the arse that was ! Rear wasn't too bad but just spent hours getting the fronts to pump up properly Got to man up and try to start it next LOL
Post by headcoats on Mar 19, 2020 12:05:15 GMT 1
Bit of an issue with the tail unit, it is carbon fibre but the mould doesn't seem to have been a "true" mould as in just laid over top of an original plastic !
This means i can't properly pull the tail piece in as carbon doesn't like being bent ?
It needs pulling in about 5mm each side
Post by midlifecrisisrd on Mar 20, 2020 10:53:12 GMT 1
I'd be putting some 5mm spacers between the cowl and the subframe
Post by headcoats on Mar 20, 2020 11:15:45 GMT 1
I have some rubber spacers to try and as long as it can be pulled in to be flush with the seat then I will stop at that
Helpful Gentleman PM'ed me to say a bit of heat off a hairdryer can bend it a bit , so maybe put it on and get it under tension and get the hairdryer out ?
Post by midlifecrisisrd on Mar 20, 2020 11:33:42 GMT 1
Post by headcoats on Mar 20, 2020 11:45:19 GMT 1
I wasn't going to use the grabrail but if I was . it would need pulling in properly, see how it goes
Post by reggieperrin on Mar 20, 2020 12:59:35 GMT 1
Heat will soften the resin slightly to allow it to move a bit. Avoid too much heat as you'll destabilise the bond and create bubbles inside.
Looks like the mould was just badly made.
It should flex enough to be pulled in.
Post by headcoats on Mar 20, 2020 22:38:53 GMT 1
Post by headcoats on Mar 28, 2020 12:22:58 GMT 1
New stainless pistons and seals in from a different supplier F##kin ground hog day !
Post by headcoats on Mar 28, 2020 12:42:08 GMT 1
Got the tail piece on too
With the Gilly seat (can't spell it !) , like on my red LC I had to put washers under the seat latches on the seat base to get the seat to "click" down
Post by donkeychomp on Mar 28, 2020 23:24:30 GMT 1
Thought you were junking that seat?
Post by headcoats on Mar 29, 2020 8:31:26 GMT 1
The seat ? No I was always going to fit it Bought it years ago from a bloke in Germany , he didn't really want to post to UK !
Post by headcoats on Mar 31, 2020 14:52:36 GMT 1
My Birthday today ,spent half the morning bleeding brakes then an argument with neighbours about their selfish smoking shite !
