Post by jessy03 on Aug 27, 2019 16:42:41 GMT 1
Why do you need a bleed pipe? If you take your in-line stat apart you may find it has a hole in it, as a bypass. Jess
Post by headcoats on Aug 27, 2019 17:34:02 GMT 1
There is but I like the idea of the pipe fitted LOL
Post by headcoats on Aug 28, 2019 9:36:27 GMT 1
If I have one hose going higher than the return pipe to the radiator, will this cause an air lock ?
Post by headcoats on Aug 30, 2019 15:35:44 GMT 1
Post by donkeychomp on Sept 2, 2019 22:13:50 GMT 1
That looks fine to me...
Post by headcoats on Sept 3, 2019 14:55:34 GMT 1
I'll let you know when the other bend turns up 😂
Post by zig on Sept 3, 2019 22:04:03 GMT 1
What a cracking informative thread Headcoats...cant wait to see the finished results ZiG
Post by headcoats on Sept 4, 2019 14:37:57 GMT 1
Not the best pic but the other 180 bend turned up Chopped about an inch off to tuck it in and could probably tuck it in a bit more but it fits and hopefully be ok
On the top run you can see the "T" piece for the bleed pipe
As its flexible I should be able to push it out the way to get at the head nuts
Trimmed a bit more with all the clamps fitted and the bypass pipe
Post by wallcraft on Sept 4, 2019 18:52:43 GMT 1
If ever you run it without the kart stat, Martin at MB designs dose a perfect s bend.
Post by headcoats on Sept 4, 2019 19:31:59 GMT 1
I know but I'm awkward LOL
Post by headcoats on Sept 6, 2019 11:27:12 GMT 1
I bought 2 of these donkeys a go as they come in a pair and with the intention of selling one Glad I didn't ! Need to get some HT lead and hopefully the bloke up the local garage will lend me the crimp tool to fit the ends
Post by headcoats on Sept 6, 2019 16:18:09 GMT 1
Couldn't get the rear light to work and after a lot of head scratching it turns out it was a crap earth
I had sprayed the rear reflector silver and covered where the earth connector is DOH !
Made me realise having a good earth is pretty important LOL
Did the wire for the front brake light switch too and could have fitted the headlamp shell if I had a bulb ....
Post by headcoats on Sept 6, 2019 18:22:08 GMT 1
Tried the tank and one side panel ! Been on top of the wardrobe for about 2 years and needed a dust LOL
Still got to get front mudguard done in black
Got standard rad guard to go on too
Plus the brake hoses that I still seem to be putting off !
Kenny is doing the end cans
Post by headcoats on Sept 6, 2019 19:08:56 GMT 1
It has YPVS on the side panels as 2 years a go that was the way I was going with a full YPVS motor but then went the Athena route
I can always tell the non believers that it has a YPVS bottom end LOL
Or if it shits itself like poor Marsbar350's Athena motor, then the side panel will make sense when it reverts back !
Post by dusty350 on Sept 6, 2019 19:10:05 GMT 1
That's looking great I like that front muddie - really suits it. Dusty
Post by headcoats on Sept 6, 2019 19:31:06 GMT 1
Thanks Dusty Means alot coming from you
Post by headcoats on Sept 6, 2019 19:46:42 GMT 1
LC clocks LC indicators LC horns !
Post by headcoats on Sept 7, 2019 11:36:49 GMT 1
Tried the tail unit and seat Still alot to do !
You can see the 5 spokes better in this pic
Post by headcoats on Sept 10, 2019 12:04:03 GMT 1
Oi Kunty ! When are yer going to finish me yer feckin sloth LOL
Post by veg on Sept 14, 2019 9:13:56 GMT 1
Love the Kr1s bits I reckon far better than the rgv, love this part of the build just when you’re getting there, the difficulty I have is not rushing to finish it. Looks really good.
Post by Tobyjugs on Sept 14, 2019 18:39:15 GMT 1
Love the 5 spokes.
Post by headcoats on Sept 20, 2019 11:16:23 GMT 1
Done the wiring I think ! I need less than half the wires on the Zeeltronic ! I had the unit with power valve programming incase i reverted back to standard barrels ,so tucked them away for now The red wire is still flapping about LOL
Post by headcoats on Sept 21, 2019 14:08:10 GMT 1
Torqued up the front sprocket (always a good thing to do !) and re sealed the exhausts on the manifolds
Now if I can find someone with some crimps to put the terminals on my HT leads . I may be not far from starting it EEK !!!
Post by headcoats on Nov 4, 2019 11:18:42 GMT 1
Nothing much to report but now have brake lines fitted ! The banjo for the radial master cylinder needed a 20 degree side bend and a 20 degree downwards bend Had them from HEL and they were very helpful as I think I sent about 20 messages LOL
Used the original RGV brake splitter to keep one line from the master cylinder
Post by headcoats on Nov 13, 2019 14:04:45 GMT 1
Just arrived ! I had them made longer as Ramair can do this for you
Post by headcoats on Nov 13, 2019 14:07:46 GMT 1
Just pushed on to check the fit
Probably could have gone another 10mm on the length but more area than standard
I think when I measured up for these I didn't allow the fact they slip onto the back of the carbs "length" which is about 10mm ...
You can see in the pic too that I don't paint the top case on the YPVS engine as it holds up well in bare alloy and hardly needs any elbow grease to keep it looking good
Post by LC_BOTT on Nov 13, 2019 14:45:05 GMT 1
Not long now until it's ready to ride by the looks of it?? Just looked through the other pics too, did you set the ride height and drill the rear shock mount fixing, as it looks way higher at the rear compared to my RGV swingarm set-up. I do like a yellow paint job
Post by headcoats on Nov 16, 2019 11:41:29 GMT 1
Rear hose needs looking at I can swivel the hose to the right and loop the hose up a bit to miss the swinger ?
Post by sidney81 on Nov 16, 2019 17:04:09 GMT 1
looks awesome
Post by headcoats on Nov 26, 2019 9:10:57 GMT 1
Many Thanks !
19000 views now ! WOW
Not that I'm counting LOL
Shows even the Trolls are having a peak ! and you know who you are ....
