Post by Topman350 on Aug 28, 2018 21:56:14 GMT 1
Baz was right you can't silver solder Ally to mild although I did find a video on YouTube for muggy weld solder rods, that show's it can be done but can't be bothered trying to buy them as they come from the USA and pricey too, so as in the pics shown you can silver solder mild on mild and SS on mild and the strength is really good I tried to break the SS plate and it bent and still wouldn't crack or come apart well impressed with it so here we go again making even more brackets π€ feck sake lol π π www.dropbox.com/s/em57cr1h1dq93ph/IMG_20180828_213709.jpg?dl=0
Post by Topman350 on Aug 29, 2018 20:41:49 GMT 1
Post by Topman350 on Sept 1, 2018 0:16:15 GMT 1
Post by Topman350 on Sept 16, 2018 19:04:14 GMT 1
Post by Topman350 on Jan 28, 2019 20:44:37 GMT 1
Hi guys not been on for a while just starting to tackle the wiring and the harness I have has been played about with so does anyone have a pic of the front end that would show what colours go where as I'm colour blind this would help a treat thanks in advance ππ
Post by Topman350 on Feb 20, 2019 22:14:40 GMT 1
Post by tacky1 on Feb 20, 2019 22:39:43 GMT 1
Post by Topman350 on Apr 20, 2019 19:28:25 GMT 1
She's running only for a bit though for some reason flywheel came off advanced the ignition couldn't stop it so pulled the fuel lines what a panic π±
First time for this to happen π
Post by Topman350 on Apr 20, 2019 19:34:16 GMT 1
Have to sort the settings but it's great to here it runs π also refit the flywheel must have been tampered with previously should have checked it school boy era lol photos.app.goo.gl/i5PMNcv1YtBtxvtw7
Post by dusty350 on Apr 20, 2019 20:29:39 GMT 1
Sounds lovely Topman Are they Higgspeeds ?? Dusty
Post by Yogi on Apr 20, 2019 20:35:30 GMT 1
Hi Chris I just thought it was a blurred picture Does sound nice though,they do look like Higgs and quite close to the swinger Matt
Post by Topman350 on Apr 20, 2019 21:28:29 GMT 1
Hi Chris I just thought it was a blurred picture Does sound nice though,they do look like Higgs and quite close to the swinger Matt Hi Matt yes they are made a bit shorter and to look more parallel from the rear think the baffle wadding needs to come out thoughπ
Post by Topman350 on Apr 20, 2019 21:33:30 GMT 1
Sounds lovely Topman Are they Higgspeeds ?? Dusty Hi Dusty they are Higgs needs to be a bit loader though like the old school sound π
Post by Yogi on Apr 20, 2019 21:36:21 GMT 1
Hi Chris I just thought it was a blurred picture Does sound nice though,they do look like Higgs and quite close to the swinger Matt Hi Matt yes they are made a bit shorter and to look more parallel from the rear think the baffle wadding needs to come out thoughπ They do sound a bit muted,take the wadding out I love the higgspeed crackle itβs ear piercing Matt
Post by Topman350 on Apr 20, 2019 22:26:42 GMT 1
Hi Matt yes they are made a bit shorter and to look more parallel from the rear think the baffle wadding needs to come out thoughπ They do sound a bit muted,take the wadding out I love the higgspeed crackle itβs ear piercing Matt My thoughts exactly mate will post another video when it's done π
Post by shandyboy on Apr 22, 2019 22:09:28 GMT 1
Topman they sound good as they are !!
What sort of cost for the exhausts ? and are they stainless mate?
Alan
Post by Topman350 on Apr 23, 2019 9:49:57 GMT 1
Topman they sound good as they are !! What sort of cost for the exhausts ? and are they stainless mate? Alan Hi Alan around Β£560 mark stainless and they did some alterations for me, they do sound good but I do like the crackley sound π if you look at their site Higgspeed they have lots of videos for you to hear them. π
Post by shandyboy on Apr 23, 2019 12:48:11 GMT 1
sound
Post by Topman350 on Apr 27, 2019 21:45:13 GMT 1
Post by Topman350 on Apr 29, 2019 21:28:26 GMT 1
Dropped off the sprocket carrier today couple of things need doing sprocket itself needs sit 4:5mm nearer the swinger so having offset spacers made,the standard studs are 12mm these are being reduced halfway down for 10mm/1.25 pitch/gold titanium nuts and the sprocket countersunk for the nuts to sit back again giving clearance for the swinger hopefully back in a week or so will then post some pics π
Post by 4l04ever on Apr 30, 2019 10:17:26 GMT 1
You could use countersunk bolts instead of nuts and studs to give more clearance.
Post by Topman350 on Apr 30, 2019 19:51:15 GMT 1
You could use countersunk bolts instead of nuts and studs to give more clearance. Granted mate but the issue I have is the carrier is 12mm and need to reduce the outer thread so the nuts don't look too big π
Post by 4l04ever on May 1, 2019 9:49:23 GMT 1
You can also use half nuts, like on a 250LC.
Post by Topman350 on May 2, 2019 7:53:16 GMT 1
You can also use half nuts, like on a 250LC. Half nuts would work better mate see how I get on when the items come back fingers crossed all should be ok π
Post by Topman350 on May 4, 2019 21:20:32 GMT 1
Glad to say it's running ok after the issue with the flywheel, can tinker with the carbs at a later date, just waiting on the rear sprocket hub from the engineer to see if all aligns up straight....bit of welding to finish off, wiring head light, clocks retro or digital? Bleed rear brake, tank and plasitics on sort the seat and take it up the road a few times when I'm happy comes the major strip and rebuild wash polish and paint ready for the summer ππ
Is there another way to add pics and videos?
Post by Topman350 on May 4, 2019 21:22:13 GMT 1
Post by tipfinchy on May 4, 2019 22:07:14 GMT 1
love it , regards clocks I think you could get away with either retro suits 2T but if its looking modern...
front and rear end are blinding
mart
Post by Topman350 on May 4, 2019 23:03:27 GMT 1
love it , regards clocks I think you could get away with either retro suits 2T but if its looking modern... front and rear end are blinding mart Hey thanks mate was thinking digital but want something cool that's not the norm if it's possible π€
Post by Topman350 on Jun 3, 2019 22:01:33 GMT 1
Had an issue with the chain fowling the exhaust so been trying to sort a solution so added a rivet nut to left side of the swing arm made up a rough bracket and bought a roller see pic does the job fine will now need to make it so it looks factory....also had a go at finishing the seat it taking a better shape now and starting to look part of the lines...I did manage to get the rear hub and sprocket done and very happy with the results I'll post some of that tomorrow. photos.app.goo.gl/XBt8MUN61KfzRS4R6
Post by Topman350 on Jun 14, 2019 14:47:31 GMT 1
Had some parts yesterday but will have some hassle fitting the rad grill, horns went on ok and did some work on the seat but will do it again as the foam is a little off taking shape though not far off been able to go for a spin see how it feels. π photos.app.goo.gl/vAYDFZxAjRo7ALgj7
