Post by TZ750D on Dec 2, 2016 2:28:14 GMT 1
Post by veg on Dec 2, 2016 8:35:51 GMT 1
Lovely used to have an 1100 cracking bike. What's the spec?
Post by TZ750D on Dec 2, 2016 15:22:10 GMT 1
Lovely used to have an 1100 cracking bike. What's the Here it is Build list: Ohlins RSU Forks FS821ZB K-Factory Triple Tree, 28mm Offset Inserts WP Shocks Yoshimura TNR-MJN Carbs with Anodized Stacks, Ramair Foam Filters (Usually) Akrapovic Exhaust Galespeed Type C Wheels 3.5in/6in Galfer Wave Discs with Brembo Calipers (M4 100mm Front, Supersport Rear) Ladybird Rear Caliper Hanger and Torque Arm, Cleverwolf Front Adapters Brembo Brake and Clutch Master Cylinders with CRG Levers, Brembo Rear Master (R1) Over Type 9 Swingarm with Anodized Stand Lifters Stites Speedo Adapter/VFR Speedo Greg Couch Oil Lines, Rail, Filler Cap, Sprocket Cover, Fork Brace, Steering Damper Mount (Shaved to Clear the K-Factory Lower Triple) ZX11 Ignition Igniter Box with Cory’s Harness. ZX11 Clutch and Ignition Covers Kwick +4 Advancer and Petc**k Babyface Rearsets Supersprox Stealth Rear Sprocket 599 Headlight with ZX7 Bracket, Roland's Bypass Harness Traf-X X-Lite LED Signals Renthal Street Low Bars AIMS High Throttle Kit, Kwick Throttle Tube, Domino Kill Switch/Starter and MotoGP Grips
Post by veg on Dec 2, 2016 16:38:08 GMT 1
Some cash in that. Lovely looking example
Post by copper99 on Dec 2, 2016 16:58:00 GMT 1
Ohhhh, thats a beauty, great job mate.
Post by mouse on Dec 2, 2016 18:06:34 GMT 1
That is terrific!
Why on earth do you want to come back here, is it the climate!!!
Mouse
Post by TZ750D on Dec 2, 2016 18:36:43 GMT 1
That is terrific! Why on earth do you want to come back here, is it the climate!!! Mouse Trump's deporting us... Actually you can't get mushy peas here so we are heading home Thanks all for the comments. Looking forward to doing a good job on a hybrid one day. Tough to match some of the work on this forum though. ZRX wasn't difficult - just get your credit card out and bolt sparkly bits on it. Most of the stuff came from japan and UK, though some guys on the ZRX forum here in the US do make nice parts cheap like harnesses, fork brace, damper mount, sprocket cover, oil lines etc etc Cheers, Don
Post by unrealedd on Dec 3, 2016 10:52:03 GMT 1
That is a very nice muscle bike! best colour for a kwak too. One hell of a shopping list to boot.
