tigwelder
Hello ..just got myself a rd350 ypvs hybrid project !!
Post by tigwelder on Nov 12, 2016 21:36:35 GMT 1
Hi.. anyone know what's the best nuts to use bolting the crank casing halfs together ? Plus do you use washers ? Nylock nuts? .... Thanks ..
Post by markhoopy on Nov 12, 2016 22:10:18 GMT 1
Original are M8 flange nuts with a 1.25 pitch thread and 12mm spanner size. Most of what you can buy on ebay are a 13mm spanner but the same in all other respects. Don't fit serrated flange nuts or use washers, and no need to use Nyloc nuts either.
Post by LC_BOTT on Nov 12, 2016 22:14:29 GMT 1
Are you sure, don't remember having flange nuts fitted (apart from barrels) just 8mm (12mm af) nuts/washers
Post by Tone on Nov 12, 2016 22:23:38 GMT 1
Looking at the parts lists the 1983/84 LC2 and F1/N1 used washers under the nuts for the crankcase then went to flanged nuts with built in washers on the later F2/N2 models.
Post by Mr Kipling on Nov 12, 2016 22:32:22 GMT 1
..early 31k engines have nuts an washers as standard , 86 on shouldered nut , on a lighter note nearly every replacement engine bolt kit ive seen or bought comes with serrated nuts with washers ...
Post by dusty350 on Nov 13, 2016 8:16:59 GMT 1
Hi I've always used stainless Nylocs and plain washers, regardless of engine model. Never had any problems Dusty
Post by Norbo on Nov 13, 2016 8:53:25 GMT 1
i use st/st nylocs as well
Post by LC_BOTT on Nov 13, 2016 9:15:00 GMT 1
Looking at the parts lists the 1983/84 LC2 and F1/N1 used washers under the nuts for the crankcase then went to flanged nuts with built in washers on the later F2/N2 models. Thanks, never had an F2 just LC's and 31K's, another learning day
Post by Yogi on Nov 13, 2016 9:41:40 GMT 1
Just to be different I sometimes use flanged nylocks
Post by markhoopy on Nov 13, 2016 11:02:07 GMT 1
Looking at the parts lists the 1983/84 LC2 and F1/N1 used washers under the nuts for the crankcase then went to flanged nuts with built in washers on the later F2/N2 models. Thanks, never had an F2 just LC's and 31K's, another learning day Learning day for me too but the other way round
Post by steven on Nov 13, 2016 13:11:48 GMT 1
Hi, On my 4L0,I used s/s plain washers, s/s plain nuts and finished it off with a s/s dome nuts. Probably a bit overkill, but Elsie is worth it !.... and it keeps the shite out the end of the thread on the studs, so that when it is stripped down the next time, it hopefully wont screw the studs out, and they will stay in the top half of the crank case. steven.
Post by LC_BOTT on Nov 13, 2016 13:47:45 GMT 1
Be aware of any speed bumps with that lot on
Post by steven on Nov 13, 2016 14:11:01 GMT 1
Post by bare on Nov 13, 2016 20:46:46 GMT 1
Wow ! Just like the fittings on a Public Urinal. Seemingly odd to think that that's viewed as an improvement though.
Post by 4l04ever on Nov 13, 2016 21:02:31 GMT 1
Post by 4l04ever on Nov 13, 2016 21:07:03 GMT 1
Post by steven on Nov 13, 2016 22:48:59 GMT 1
Wow ! Just like the fittings on a Public Urinal. .....Bare, You,v been hanging aboot the cludgies lookin at nuts again, havnt ye ? !
Post by tell7437 on Nov 13, 2016 23:02:42 GMT 1
I use stainless m8 rod connectors cut to length on anything where the thread is exposed, ypvs barrel base nuts & exhaust studs look far better & they keep the crap out
Post by jon on Nov 13, 2016 23:36:50 GMT 1
Wow ! Just like the fittings on a Public Urinal. Strange to notice trivial details about public toilets. Jon
Post by steven on Nov 13, 2016 23:40:41 GMT 1
Sorry for jumping on your thread Tigwelder, Tell, I have the same feelings regarding exposed threads. I also have stainless steel (flange nut/dome nut) "shite hoose" fixings on my exhaust studs, which are M8 x 45mm grub screws, so I can screw them in and out easily with an allen key. The extra weight isnt realy a problem, as I always make sure I go for a three coiler prior to going out on my LC !
Post by dusty350 on Nov 14, 2016 8:17:21 GMT 1
A "3 coiler" !! hahahah Dusty
Post by 4l04ever on Nov 14, 2016 15:01:22 GMT 1
A "3 coiler" !! hahahah Dusty Sounds very similar to a "walnut whip".... :-)
Post by Yogi on Nov 14, 2016 18:34:39 GMT 1
A "3 coiler" !! hahahah Dusty Sounds very similar to a "walnut whip".... :-) Guess it depends where you live I call it a Mr Whippy
