Post by Yogi on Dec 4, 2016 0:07:34 GMT 1
I'll be expecting get the drab olive bits then π You ok for engine bolts and screws Steve I replied on page one mate but forgot to quote Matt
Post by midlifecrisisrd on Dec 4, 2016 12:14:23 GMT 1
Hi Steve Your right they will be winging there way to Scotland They might be coming with the tdr if that's going to yours Quite a lot of olive on these mate as you already know Is the clock surround meant to be olive? Can I send the brake pedal,headlight bezel,kickstart,gear linkage and other big bits? Engine bolts I'm not sure cos I need a set for the lc2 afterwards Are you doing more?.. Matt Yes the Tdr is coming to mine so box the bits up and send them along. Not a problem to send the kick-start,brake pedal and tail light bracket along with the bolts. Sometimes bigger bits don't plate correctly in the barrel but he's good at keeping trying. My kick-start and brake pedal came out fine. Top clock cover is satin black and headlight surround should be black too. Think originally is black passivated so you can either paint it or they are still available new. Gear linkage should be chrome along with the rest of it I'm sure. Think it was the f2 that went to olive. Other olive bits should be disc bolts, caliper bolts, banjo bolts,brake line banjo's and brake line guides, Clock mount bolts, engine mount plates and the other usual fixings. Yellow is tail light bracket bolts, seat catches (on seat), catch bolts and screws,servo mount screws,cdi, coil and regulator fixings and suspension bolts. All rest clear zinc from memory but my n1 build should show the majority. Send me the lot if you like, just bag up in the different colours for separate batches. Engine bolt set wise I think I may have one full kit. Got a load of other screws as i bought 100 of each size so would have to look at what I've got Not a problem to get another batch done if you supply head bolts. Steve
Post by Yogi on Dec 5, 2016 10:27:03 GMT 1
No prizes for guessing who used to live in the airbox Thankfully it's long gone Matt
Post by Yogi on Dec 6, 2016 11:24:58 GMT 1
Hidden amongst all the grease and crap on the bike I found this white power shock Needs a bit of cleaning but in really good condition Happy days Matt
Post by midlifecrisisrd on Dec 6, 2016 15:17:50 GMT 1
Jammy b4st4rd
Post by fozzy17 on Dec 6, 2016 15:57:47 GMT 1
you cant say white power now, its racist, its WP now
Post by Yogi on Dec 6, 2016 17:13:47 GMT 1
Post by lrcarl on Dec 6, 2016 17:51:01 GMT 1
Result
Post by yamark on Dec 6, 2016 18:57:58 GMT 1
Jammy git Matt , great result. Looks a serious bit of kit. Keep up the great work mate
Post by dusty350 on Dec 6, 2016 19:10:24 GMT 1
That was a nice surprise. It's cleaned up like new Great result Dusty
Post by Yogi on Dec 7, 2016 20:35:54 GMT 1
Cheers guys
It's nice to get a result sometimes
Matt
Post by Yogi on Dec 28, 2016 16:15:38 GMT 1
Hi All Parts have started coming back now Powdercoaters done a lovely job in just 4 days . Whilst waiting on the bolts etc I had time to strip the engine Ready for vapour blasting Turnt up some surprises though Ball bearing,adjuster nut and washer in the bottom of the side casing Two bolts and springs missing from the clutch,odd Pistons,no jointing piece on the pvs and dodgey fixings everywhere They really shouldn't sell tools to gorillas Matt
Post by iwantalc on Dec 28, 2016 17:00:25 GMT 1
so onwards and upwards matt, thought you had gone to sleep on this one , hope you had a good xmas all the best for 2017 des..
Post by Yogi on Dec 28, 2016 17:16:11 GMT 1
Hi des Does seem a while since any updates Everythings been away getting sorted I need this one ready for spring cos it's gonna be my weekly hack,not a shed ornament That said it will still be restored properly,just not totally standard The rebuild will be full steam ahead soon mate Hope your Xmas was good too,mine was but with no shed action unfortunately Have a good 2017 mate Atb Matt
Post by Yogi on Dec 28, 2016 20:19:34 GMT 1
Post by fozzy17 on Dec 28, 2016 23:10:33 GMT 1
Me thinks his is gong to be a minter, great to see you will be using it every day
Post by midlifecrisisrd on Dec 29, 2016 8:59:53 GMT 1
Powdered parts look like a really good job
You are very welcome with the plated parts, glad to help
Oh and you are not stuck, you can bolt the tail light bracket on lol
Post by Yogi on Dec 29, 2016 11:08:19 GMT 1
Powdered parts look like a really good job You are very welcome with the plated parts, glad to help Oh and you are not stuck, you can bolt the tail light bracket on lol Steve Loads to do mate I can bolt the tail light on too Don't think I can use the olive tail bracket but I did get one coated I'll probably use it as it will look better although not right Was thinking of getting one satin black powder-coated to try? Matt
Post by midlifecrisisrd on Dec 29, 2016 11:20:28 GMT 1
Bugger about the bracket
Can you not paint the inner face with Matt black and use it
The shape of it makes it a nightmare to plate then ΓΎhe zinc won't take the dye.
He did say ideally if it was blasted first it may take better and stop the patching.
I usually just powder them as well but found an original finish one for my current build.
Post by Yogi on Dec 29, 2016 11:32:22 GMT 1
It's not just the inner there's bad bits on the outer curves that are seen No worries I'll use the powder one for now while I'm using it
When I get the lc2 parts done I'll send two that have been blasted,then keep my fingers crossed Bottom yokes coated two so will need to get one done as well I ain't got a set of standard pipes for it yet so until then I'll use it with allspeeds
Cheers Matt
Post by Yogi on Dec 31, 2016 18:46:13 GMT 1
Managed to get a few bits done Ended up using the olive bracket because I had an f2 one coated by mistake Actually looks ok Both stands on with new bolts and springs New steering lock Most of the rear suspensions in And made a start on the electrics,donor front ends on for now Just a back wheel and I can move it about Happy days Matt
Post by yamark on Dec 31, 2016 19:51:09 GMT 1
Brilliant Matt. I never tire of your superb resto's, great progress, great pictures. The plating looks perfect as does the powdercoating. I remember you saying my triple will be finished before your resto- I think you've done 3 bikes since
Keep us posted mate - love this build
ATB Mark
Post by Yogi on Jan 1, 2017 9:13:16 GMT 1
ATB Mark Hi Mark Thanks for the encouragement mate Im just restoring art Your creating a Masterpiece Atb Matt
nij
Post by nij on Jan 1, 2017 14:53:37 GMT 1
Wow great build, if mine gets anywhere near close I'll be very happy!
Post by Yogi on Jan 1, 2017 15:03:35 GMT 1
Wow great build, if mine gets anywhere near close I'll be very happy! Thanks mate and welcome aboard There's nothing stopping yours being as good or better Any help you need just ask away Matt
Post by scootjockey on Jan 2, 2017 21:00:21 GMT 1
Yogi where do you get all the nuts bolts clips etc from ? Are these all new and replated or old existing parts redone ?
Post by Yogi on Jan 2, 2017 22:14:17 GMT 1
Hi mate There old parts degreased,buffed on a wire wheel and replated Matt
kopite30
http://www.motomovers.uk
Post by kopite30 on Jan 3, 2017 21:37:21 GMT 1
Looking brilliant you ain't hanged around bud nice one
eddiekidd
Just had a go firt kick started right up and ran on both cycinders briefly and wiht a ilttle trottle
Post by eddiekidd on Jan 3, 2017 22:36:15 GMT 1
Finally picked up the N1 today Although I'm gonna restore it I thought I'd see what I'm up against first I found that the cdi was missing along with the temp sender,carbs balance pipe,self cancelling unit and carbs retaining clips It got me wondering what state the engine and electrics were in I borrowed the cdi from my F1 build,fitted the other missing parts along with an aux petrol tank Then set about trying to fire it up Happy to say after about 50 kicks it burst into life and all the electrics seem to work It's misfiring a bit on the right side but sweet when firing it sounds ok Here's a pic of it on eBay Here's a pic of it running Although the seat will be replaced in red,I had to remove them hideous Yamahas I've already sent an N1 body kit to Cordwells so won't have to wait for it like usual Cheer Matt Looks SWEET.
Post by Yogi on Jan 3, 2017 23:25:50 GMT 1
Looking brilliant you ain't hanged around bud nice one No time to hang around mate
