Post by unrealedd on Oct 18, 2016 19:20:33 GMT 1
Well that bike completely made the trip to the show worthwhile, i went there especially to see it and have to say it didn't disappoint. So chuffed for you and it just works you are a true talent and inspiration and well done on yet another top shelf build. Didn't think you could better your first creation but this second is out the park, god only knows what you can achieve for the 3rd. Fantastic job on a fantastic bike you should be so proud i just wish i had even a little of your skills.
Post by Topman350 on Oct 18, 2016 20:02:59 GMT 1
Well that bike completely made the trip to the show worthwhile, i went there especially to see it and have to say it didn't disappoint. So chuffed for you and it just works you are a true talent and inspiration and well done on yet another top shelf build. Didn't think you could better your first creation but this second is out the park, god only knows what you can achieve for the 3rd. Fantastic job on a fantastic bike you should be so proud i just wish i had even a little of your skills. Thank you so much buddy I really do appreciate those comments I worked so hard on this build to get it ready for the show I'd didn't recieve a prise this time but you can't have everything but the remarks I've received on the forum more than made up for it so cheers again and I promise the 3rd will be a step up again and different :-)
Post by 1966baz on Oct 18, 2016 20:10:04 GMT 1
Another great build Topman, well done. Love the attention to detail.
Post by yazza54 on Oct 26, 2016 13:39:37 GMT 1
Don't want to sound like a dick because I do really like the bike and your attention to detail.
But I can't get my head around the shock mounting, it doesn't look safe to me? I've never seen a shock mounted to a subframe, furthermore it's a bolt on subframe, if you took the two lower brackets out of the equation the whole thing would just pivot. So there must be a lot of faith put in those lower brackets?
Post by Topman350 on Oct 26, 2016 23:27:36 GMT 1
Don't want to sound like a dick because I do really like the bike and your attention to detail. But I can't get my head around the shock mounting, it doesn't look safe to me? I've never seen a shock mounted to a subframe, furthermore it's a bolt on subframe, if you took the two lower brackets out of the equation the whole thing would just pivot. So there must be a lot of faith put in those lower brackets? Thanks for your opinion fella I can assure you it's a solid unit bolted I've a mate in engineering and we discussed a few options because I didn't want any welds and like any subframe there's always a Strain at the fixing points welded or not you mention the lower bars not being there and would pivot what would happen to any subframe if you removed the lower supports the upper would stress and break all or most subframe have 4 mounting points this one is solid and works well my builds will never go the easy route I like to be different wait till you see the 3rd :-)
Post by Bertie Wooster on Oct 27, 2016 3:23:52 GMT 1
Looked great in the flesh when I saw this at Stafford +10 to you on the build
Post by arrow on Oct 27, 2016 15:23:17 GMT 1
Wow, very nice.
Post by yazza54 on Oct 27, 2016 22:08:05 GMT 1
Don't want to sound like a dick because I do really like the bike and your attention to detail. But I can't get my head around the shock mounting, it doesn't look safe to me? I've never seen a shock mounted to a subframe, furthermore it's a bolt on subframe, if you took the two lower brackets out of the equation the whole thing would just pivot. So there must be a lot of faith put in those lower brackets? Thanks for your opinion fella I can assure you it's a solid unit bolted I've a mate in engineering and we discussed a few options because I didn't want any welds and like any subframe there's always a Strain at the fixing points welded or not you mention the lower bars not being there and would pivot what would happen to any subframe if you removed the lower supports the upper would stress and break all or most subframe have 4 mounting points this one is solid and works well my builds will never go the easy route I like to be different wait till you see the 3rd :-) It would happen to any bolted in subframe, but my point is that no other sub frame would normally have a shock mounted to it, because it's not structural. I'm sure you've looked into it so hopefully it holds up, but sometimes I think there's a reason why you've never seen certain things done before.
Post by rostrumorhospital on Nov 6, 2016 20:08:28 GMT 1
Just seen the bike sitting at £8250 on ebay with just under 1/2 hour left, hope you get close to the £10000 orginal price, great bike
Post by Topman350 on Nov 7, 2016 21:37:43 GMT 1
Just seen the bike sitting at £8250 on ebay with just under 1/2 hour left, hope you get close to the £10000 orginal price, great bike Cheers mate still trying to get close been offered £8500 but it's worth more we'll see and if I don't make the asking price I'm well happy to keep it till spring 17 :-)
Post by Topman350 on Feb 27, 2017 20:11:32 GMT 1
Bike is now sold lads too some lucky guy in the North on its way to him as we speak sad to see it go but onto the next build but won't be starting the 3rd project until April so at the moment scouting for parts etc been in touch :-)
Topman
