Post by noonster on Oct 4, 2016 11:28:42 GMT 1
Started my bike up for the first time last night and the joint between the down pipe and silencer was leaking. When I pushed the two together all I had was a nylon insert inside( worn ) which I pushed upto the flange on the down pipe and the outer rubber joint cover with a spring either side.
When I look on ebay etc I can see the same rubber outer seal,but it as a paper gasket inside.
have I got the wrong seal and do you use silicone as an extra sealing precaution when putting back
Which is right.
Noonster
Post by paulsx on Oct 4, 2016 15:46:54 GMT 1
What exhausts are they?
Post by noonster on Oct 5, 2016 9:48:23 GMT 1
R29
lance
Post by lance on Oct 6, 2016 6:03:07 GMT 1
Did u have the aluminium seal
Post by noonster on Oct 6, 2016 22:47:31 GMT 1
No
2 worn nylon inserts,tried some silicone.
Have seen gambits sell a aluminium insert
Post by Ozhammer on Oct 7, 2016 1:43:24 GMT 1
I use the Yambits aluminium joint seals on my 2R9 exhausts and find them better than the alternatives. They do wear out though, due to the movement between the donwpipe and muffler, so will last around 5,000 kms from my experience.
Rgds Ozhammer
lance
Post by lance on Oct 7, 2016 6:00:30 GMT 1
As above I use them they are sacrificial as they wear out and not your exausts
fogggy
Post by fogggy on Jan 15, 2017 20:06:50 GMT 1
Always had this problem back in the 80s, I guess there is no new alternative
