Post by 1966baz on Apr 14, 2017 20:38:05 GMT 1
Loads of work and attention to detail here, Well done gonna be a cracking bike Andrew.
Post by mouse on Apr 15, 2017 7:23:02 GMT 1
Loads of work and attention to detail here, Well done gonna be a cracking bike Andrew. Many thanks 1966Baz, it's great fun! Mouse
Post by mouse on Apr 15, 2017 7:30:56 GMT 1
Right, here are a couple of pics of the rear caliper and hanger Hopefully in this first one you can see how far out the mounting hole is, the reason being the caliper is hitting the hanger at the top (the rounded part, where the piston is) , under the 'Tyga' and in this pic, you can just see the top right edge of the pad, which overlaps the painted area of the disc, so even if the caliper fitted the pads would bite into this area when the brake was applied, not right!
As i mentioned the disc is NOS RGV the hanger is for an RGV and brand new, the caliper is brand new too, have i got the wrong caliper?, i did not buy it, it was supplied with the forks and other bits i got.
Any help, much appreciated
Mouse
Post by dusty350 on Apr 15, 2017 7:51:15 GMT 1
Morning mate Looks like the wrong caliper. Just took a pic of mine - not easy to do laying on the floor with phone in one hand and Vernier in the other so excuse the crappy pic, but centres on the caliper should be 85mm; It wont be the disc, and unlikely the carrier if everything bolts together as it should. Weird ! Dusty
Post by Tobyjugs on Apr 15, 2017 7:58:22 GMT 1
There should be an id number on the Brembo
Post by mouse on Apr 15, 2017 19:12:41 GMT 1
There should be an id number on the Brembo Great idea, thanks. Found the number, i'm thinking i have the wrong caliper, going to have to do more investigating Mouse
Post by mouse on Apr 15, 2017 19:20:48 GMT 1
Post by spudmab on Apr 15, 2017 19:42:54 GMT 1
Looking good mate, coming on leads and bounds now,
1 question whats the red bit on the Sidestand, got any better pictures of it
Post by dusty350 on Apr 15, 2017 20:08:42 GMT 1
Looks great mate Glad there was no dramas with the engine - lots of pipe lagging gives you some leeway you'll have this finished in no time !! Keep up the good work Dusty
Post by mouse on Apr 15, 2017 20:08:54 GMT 1
Looking good mate, coming on leads and bounds now, 1 question whats the red bit on the Sidestand, got any better pictures of it Hi there, it's just an aluminium washer, another pro bolt purchase! Mouse
Post by Yogi on Apr 15, 2017 20:14:23 GMT 1
Hi mate Your flying along now and the bikes looking brilliant,some proper nice bling on it Didn't realise the mouse was Speedy Gonzales Keep it up mate Atb Matt
Post by Tobyjugs on Apr 15, 2017 20:30:32 GMT 1
Maybe dusty has got a number for you from his caliper
Post by dusty350 on Apr 15, 2017 20:58:17 GMT 1
Hi Yea, we spoke this morning about the caliper. Mine has a different code on it compared to Mouse's. Could be a slightly different shaped casting that's causing it to fowl the carrier. Mouse was gonna investigate it further. Any luck with that Andrew ? Dusty
Post by Eyrey1 on Apr 15, 2017 21:11:10 GMT 1
sell me that black hybrid ? seriously
Post by mouse on Apr 16, 2017 6:55:46 GMT 1
Hi Yea, we spoke this morning about the caliper. Mine has a different code on it compared to Mouse's. Could be a slightly different shaped casting that's causing it to fowl the carrier. Mouse was gonna investigate it further. Any luck with that Andrew ? Dusty Hi Dusty, no not yet, will try and sort this week Mouse
Post by mouse on Apr 16, 2017 7:01:45 GMT 1
Hi mate Your flying along now and the bikes looking brilliant,some proper nice bling on it Didn't realise the mouse was Speedy Gonzales Keep it up mate Atb Matt Cheers Yogi, that made me laugh! still not up to your pace! the only reason it is going quickly is i have been amassing parts ready for the build and been in the garage by 7-8ish and worked all day for the last two days, the only hiccup being the rear caliper! Mouse
Post by mouse on Apr 16, 2017 7:02:28 GMT 1
sell me that black hybrid ? seriously Think i may have broken it, you wouldn't want it! Mouse
Post by mouse on Apr 16, 2017 18:04:42 GMT 1
Post by stusco on Apr 16, 2017 18:09:58 GMT 1
You might want to check it with the exhaust on before you decide what your going to do the spacers on your rear sets are quite thick maybe they can be altered
Post by Tobyjugs on Apr 16, 2017 19:00:18 GMT 1
It looks like your side stand is lifting up to far. maybe some more experienced members can comment on this, and is it the right side stand for that model?
Post by mouse on Apr 17, 2017 9:15:03 GMT 1
You might want to check it with the exhaust on before you decide what your going to do the spacers on your rear sets are quite thick maybe they can be altered Good point, yes get the pipes made first and then sort the stand. The spacers are thick because i did not want to cut off any of the 31k brackets and on the right there are all the brake mounts. This is so that at any time this could be returned to a standard 31k Mouse
Post by mouse on Apr 17, 2017 9:19:01 GMT 1
It looks like your side stand is lifting up to far. maybe some more experienced members can comment on this, and is it the right side stand for that model? I think you are right on the stand angle, yes as far as i am aware it is the right stand for a 31k. I do now remember when i built my 4LO hybrid i had the same problem! But i did get it sorted. Mouse
Post by phil1rowe4 on Apr 17, 2017 13:33:13 GMT 1
Hi Mouse,
That's looking Very Nice! I love the attention to detail.
Phil.
Post by yamark on Apr 17, 2017 19:08:48 GMT 1
Looking really good Mouse.
I would have thought a couple of bits of weld on your sidestand to build up the stop should do it. At least that way your not damaging the frame paintwork. Sort it when the exhausts are fitted
Great build mate
Post by 4l04ever on Apr 17, 2017 19:18:07 GMT 1
It looks like the side stand mount may have been rewelded at some point, as the weld does not look factory. Perhaps it was put on at a different angle to standard? You can cut the sidestand off at the end of the tube part and modify the angle it is fitted at then reweld and powder coat again, but do this after you have exhausts etc fitted to make sure it clears everything as has already been stated. :-)
Post by jessy03 on Apr 17, 2017 19:39:37 GMT 1
Good work coming together nicely, just one thing, I think the loom should run on the inside of the frame above the radiator, worth checking.
jess
Post by Mr Kipling on Apr 17, 2017 20:33:51 GMT 1
Looking good there Andrew , keep it coming...
Post by mouse on Apr 18, 2017 7:34:13 GMT 1
It looks like the side stand mount may have been rewelded at some point, as the weld does not look factory. Perhaps it was put on at a different angle to standard? You can cut the sidestand off at the end of the tube part and modify the angle it is fitted at then reweld and powder coat again, but do this after you have exhausts etc fitted to make sure it clears everything as has already been stated. :-) Thanks for that, all good points. I will address the stand issue once the pipes are done. I do have another stand which could be cut and modified. Mouse
Post by mouse on Apr 18, 2017 7:36:07 GMT 1
Great build mate Cheers Mark, A good idea, but like you say will wait till pipes are done first, which hopefully will not be too long! Mouse
Post by mouse on Apr 18, 2017 7:37:01 GMT 1
Good work coming together nicely, just one thing, I think the loom should run on the inside of the frame above the radiator, worth checking. jess Thanks Jess, you might be right, I should have taken more photos! Mouse
