Post by mattybeckett on Sept 11, 2016 22:00:23 GMT 1
When fuel tap is switched to the ON position the fuel only comes out for the left hand carb, but when switched to reserve it comes out of both. Got me confused.. any ideas what might be the problem before i strip it down to investigate? Cheers and look forwards to any advice.
Post by shaunthe2nd on Sept 11, 2016 22:06:46 GMT 1
Strange logic that. Likely to be dirt in the filter I reckon. Have you tried it with bike level, eg on centre stand and still get same result?
Post by mattybeckett on Sept 11, 2016 22:24:51 GMT 1
Same problem on center and side stand.. should the filter have a top hat type of cover on the filter as mine doesn't seem to have one, but don't think that will be causing the problem !!!
Post by headcoats on Sept 11, 2016 22:32:37 GMT 1
Can't quite remember but they can be assembled wrong as in the metal lever can sit in the plastic cone 180 degrees out ! Has it been apart ?
Post by shaunthe2nd on Sept 11, 2016 22:39:08 GMT 1
Good point by headcoats. Internal filter does have a hood/cover, but fuel enters from sides. Maybe if no cover muck comes in from top. Think you need to remove it and have a look. Not a big job.
Post by mattybeckett on Sept 12, 2016 12:17:05 GMT 1
Hi Headcoats it does seem as if something is 180degrees out. What are they like for stripping down...Cheers for the advice.
Post by mattybeckett on Sept 12, 2016 19:12:20 GMT 1
Thanks for all suggestions and much appreciated.. the man cave awaits a visit later this eve to strip tap down and have a look and also check out the new beer fridge is working ok :-)
Post by bare on Sept 12, 2016 19:57:57 GMT 1
Tread carefully. These fuel taps are of some Zinc Alloy (pretty well Chocolate IMO) And almost 40 years .. does take it's toll. Might keep buying a fresh New one in the back of your mind as an alternate solution.
Post by mattybeckett on Sept 13, 2016 19:11:22 GMT 1
I know exactly what you mean Bare. I decided to buy an apparently good working tap of Ebay as a back up before stripping.. but i did blast the airline up both outlets today while tank was of the bike and put a bit of pipe on and blew down each outlet and it seemed ok.. so might just of been a blockage hopefully..fingers crossed. Thanks.
Post by headcoats on Sept 13, 2016 19:41:13 GMT 1
Mine was bought brand new (genuine part) when I did the rebuild and that was about 6 years a go it was first put on the road and now the tap is so hard to move it's a feckin bad design or I suspect the ethanol has done some damage
I have always ran premix too , so that tap would have had a bit of lube
Need someone to come up with a solution so all I need to turn the tap would be my little pinky
Post by bare on Sept 13, 2016 22:43:23 GMT 1
As a possible? There are quite nice Ball type valves fitted to some Gardening equipment. Built for trouble free usages even when in the hands of uncaring employees. Still have to evolve an attachment to the tank method that wouldn't look like a preschooler made it. Hey! if all this Bike stuff was Easy.. anybody could do it :-)
Post by mattybeckett on Sept 15, 2016 19:04:18 GMT 1
Went out for test drive and still playing up while switched to ON position, turned to reserve and OK,,, hopefully back up tap will be here soon, so can strip down problem tap to investigate further.
Post by stusco on Sept 15, 2016 20:40:22 GMT 1
My new (norbo) TZ tap has just started leaking (6months old) through the actual tap not out the outlet is unleaded really that corrosive if so we need a better fuel tap
Post by earthman on Jan 20, 2018 19:25:34 GMT 1
When fuel tap is switched to the ON position the fuel only comes out for the left hand carb, but when switched to reserve it comes out of both. Got me confused.. any ideas what might be the problem before i strip it down to investigate? Cheers and look forwards to any advice. I noticed a similar problem today, whilst trying to drain the tank of it's fuel, I had the tank off the bike on a workmate, two tubes going down into a jerry can, turned the tap to reserve and fuel started to come down both pipes but stopped in one. I then tried the on position, same thing happened. I then turned the tap off, blocked both ends of the hoses with my thumb and turned the tap back on, fuel did flow down both hoses but I don't think that it stayed like that, sooner or later one stops flowing. The hoses weren't the same length, routed differently obviously,...is it just a case of the fuel taking the easiest flow route??
Post by mattybeckett on Jan 21, 2018 0:53:41 GMT 1
When fuel tap is switched to the ON position the fuel only comes out for the left hand carb, but when switched to reserve it comes out of both. Got me confused.. any ideas what might be the problem before i strip it down to investigate? Cheers and look forwards to any advice. I noticed a similar problem today, whilst trying to drain the tank of it's fuel, I had the tank off the bike on a workmate, two tubes going down into a jerry can, turned the tap to reserve and fuel started to come down both pipes but stopped in one. I then tried the on position, same thing happened. I then turned the tap off, blocked both ends of the hoses with my thumb and turned the tap back on, fuel did flow down both hoses but I don't think that it stayed like that, sooner or later one stops flowing. The hoses weren't the same length, routed differently obviously,...is it just a case of the fuel taking the easiest flow route?? Fitted a replacement tap and all was Ok, I completely stripped the offending one and left in ultrasonic cleaner for ages . Rebuilt with new seal and red rubber grease to enable easy tap operating. Refitted and worked fine . Got a spare on the shelf now just in case.
Post by robin on Jan 21, 2018 21:28:45 GMT 1
I had tap issues, sorted finally by making one good tap out of two very tight taps, I did look at the Pingel range of taps, but my credit card curled up and refused to come out of the corner. They look great, but Fffffing expensive. anyone fitted one?
Post by earthman on Jan 21, 2018 22:27:21 GMT 1
Post by stusco on Jan 21, 2018 22:32:45 GMT 1
I had tap issues, sorted finally by making one good tap out of two very tight taps, I did look at the Pingel range of taps, but my credit card curled up and refused to come out of the corner. They look great, but Fffffing expensive. anyone fitted one? I’ve just ordered one so I’ll let you know
Post by robin on Jan 21, 2018 22:35:10 GMT 1
I had tap issues, sorted finally by making one good tap out of two very tight taps, I did look at the Pingel range of taps, but my credit card curled up and refused to come out of the corner. They look great, but Fffffing expensive. anyone fitted one? I’ve just ordered one so I’ll let you know did you go for a dual outlet and a reserve setting?
Post by stusco on Jan 22, 2018 7:43:12 GMT 1
I went for the single feed and reserve,I already have a single feed hi flow tap but it leaks when in the off position
