Post by veg on Sept 22, 2018 17:12:02 GMT 1
Post by donkeychomp on Sept 22, 2018 22:27:16 GMT 1
That's very neat I like it. Nice going matey.
Post by Tobyjugs on Sept 26, 2018 8:32:54 GMT 1
Looking good Veg, love the drop handle bars.
Post by veg on Nov 11, 2018 14:10:03 GMT 1
Post by Tobyjugs on Nov 11, 2018 15:43:23 GMT 1
Where did the radiator come from?
Post by veg on Nov 11, 2018 15:54:18 GMT 1
Where did the radiator come from? Bought it from Morgy on here i suspect it was a cheap chinese copy it needed lots of heat and persuasion with a hammer and dolly to reshape where it fits the top part of the frame, however it is more in keeping with the look for me
Post by morgy on Nov 11, 2018 20:38:37 GMT 1
Where did the radiator come from? Bought it from Morgy on here i suspect it was a cheap chinese copy it needed lots of heat and persuasion with a hammer and dolly to reshape where it fits the top part of the frame, however it is more in keeping with the look for me I got it with my project so not sure who made it or where it came from..
Post by veg on Nov 11, 2018 21:51:24 GMT 1
I noticed it was on your project how did it fit? As it was a right bugger for me, I know you hadn’t bought it and it came with the hybrid.
Post by dusty350 on Nov 11, 2018 21:57:27 GMT 1
Looking good Veg That is one of the problems with the Chinese rads - some need persuading to fit, and some bolt straight on ! Very much "lucky dip" but still worth the minimal outlay to take a chance Dusty
Post by morgy on Nov 12, 2018 9:38:47 GMT 1
I noticed it was on your project how did it fit? As it was a right bugger for me, I know you hadn’t bought it and it came with the hybrid. It fitted... I had to tweek the rad mounts a little but My spondon yokes hit the top of the rad.. I think my frame also has bracing under the headstock as well pushing it further forward.. If your not happy with it mate i can take it back. Regards Mark
Post by veg on Nov 12, 2018 10:09:04 GMT 1
Happy with it mark just shows you the difference between bikes I had to peen a concave of about 20mm into my t so it fitted my 4lo Bizarre cheers
Post by 1966baz on Nov 12, 2018 10:09:40 GMT 1
Hi mate, any chance you could put up a pic or 2 of the rear brake torque arm set up as I am currently doing a marsbar 4l0 with a belgarda rear wheel in a JMC arm. Cheers. Your bike looks great, keep up the good work!
Post by 1966baz on Nov 12, 2018 10:15:14 GMT 1
Also can you show a pic of the front wheel in the forks at the speedo drive area. I couldn't fit a begarda wheel with speedo drive in standard YPVS forks. Cheers mate, I don't ask for much do I.
Post by veg on Nov 12, 2018 11:00:31 GMT 1
Also can you show a pic of the front wheel in the forks at the speedo drive area. I couldn't fit a begarda wheel with speedo drive in standard YPVS forks. Cheers mate, I don't ask for much do I. Will do I’m away at the moment with work so will be next weekend. I am running an electronic speedo as the wheels Honda rs125 race bike magnesium do not have a speedo drive HTH
Post by 1966baz on Nov 12, 2018 17:26:42 GMT 1
Thanks mate.
Post by Yogi on Nov 12, 2018 18:01:30 GMT 1
Coming along nicely mr veg
Post by veg on Nov 25, 2018 13:11:40 GMT 1
Renamed as nothing is bloody easy with this build. So my radiator guard has fought me all the way I swapped the insert but that didn’t fit so I had to re drill and tap new holes and screw it into place. On top of fighting with the radiator. I now also realise the radiator has a smaller cap than standard. So I wheel the bike around and the rad guard massively interferes with right lock on the anti dive. Ok so I will sort that. Then I decide to fit the belly pan but the Tz pipes interferes with the belly pan consequently I cannot fit the belly pan. Onwards and upwards
Post by veg on Nov 25, 2018 13:13:34 GMT 1
Post by tipfinchy on Nov 25, 2018 13:59:53 GMT 1
like your onwards and upwards attitude is it one of norbos carbon pans ,is it the back that's stopping it fit, I ask as I really fancy one myself and my pipes look fairly similar to yours
cheers mart
Post by veg on Nov 25, 2018 14:27:35 GMT 1
It is one of norbo pans my pipes though are Tz race pipes so probably bigger than normal I know they normally fit with allspeeds and most expansion chambers
Post by veg on Nov 27, 2018 16:33:31 GMT 1
So couple more days in the garage Belly pan now fitted absolute ball ache had to cut it down so hole saw and hack saw later done Measured up the radiator cap and it’s tiny so went to my local motor factors and they let me measure up lots of different caps and bingo little jap family car later and it looks vaguely Tz ish so I’m happy Still lots of pissy little jobs to do but fingers crossed I can get it running before Xmas Now got to face re wiring which I can and have done before but I absolutely hate it so lots of new fittings ordered then on to it And because of the chain run had to turn rear wheel upside as the chain was hitting the spannies
Post by donkeychomp on Nov 27, 2018 23:28:57 GMT 1
How are you going to overcome the anti dive hitting the rad? Apart from that hiccup she looks fan bleedin' tastic!
Post by dusty350 on Nov 28, 2018 8:19:17 GMT 1
Hi Veg Have you tried compressing the forks to see if the rad guard is gonna contact the mudguard ? Those deeper rads - allied with a spaced out rad guard come much closer to the back of the muddie. Hard to tell from the pics but it looks close already ?? Bike looks awesome mate Dusty
Post by veg on Nov 28, 2018 10:50:28 GMT 1
Thanks chaps I have compressed the forks they are ok it’s tight but clear the anti dive is the restriction on right hand lock I may have to turn the rad cover spacers down by 50% and maybe even bevel the mounting point.
Post by veg on Dec 16, 2018 16:47:00 GMT 1
So the rear master cylinder was a hrc type bought from NK but the pipe was sweating fluid so bought the correct pipe then decided to fit a proper master cylinder and brake light switch so had to strip it all down again and fab an aluminium bracket to mount the master cylinder Decided to replace the front master as well but of course the union was wrong so had to order the correct one Had to bevel the anti dive mount as it interfered with the rad cover Then had to reduce the spacer size on rad guard as it still interferes with the right lock Mounted speedo pick up and magnets Fitted a new temp gauge koso one then fitted the sensor so had to remove radiator again Always 2 steps forward one step back Replaced all the std bolts screws that I bought new from norbo where possible with drilled titanium just for the look and re lock wired everything Finally see light at the end of the tunnel
Post by Mr Kipling on Dec 16, 2018 17:05:45 GMT 1
Looking real sweet there Veg !!!!
Post by donkeychomp on Dec 16, 2018 23:17:59 GMT 1
Titanium! Bleeding 'eck mate. On a windy day you'll have to tie it down so it doesn't float away...
Post by veg on Dec 17, 2018 0:03:18 GMT 1
Its the fat pie eater riding it that needs to lose the weight
Post by Tobyjugs on Dec 17, 2018 12:23:56 GMT 1
Can't wait to see this one up and running.
Post by veg on Dec 17, 2018 12:25:31 GMT 1
Can't wait to see this one up and running. Nor can I tony not can I. Got to finish the wiring then get it off to Dave for set up and dyno
