Post by richclare on Aug 18, 2016 19:04:56 GMT 1
Hi, Great forum - I have been looking at some of the other projects with a little envy! I live in France and I have just purchased an RD350LC 4L0 after a few months searching. She isn't in bad nick for 36 years old but needs some big love!! I would like to restore her to original condition but with some extra shiney bits, depending on budget. I have just started to strip the motor and found that the oil pump worm drive and gear inside the pump are pretty much shredded, not sure why yet? This would account for the seizure that occurred to the previous owner! It will be a longer term project but I will put photos on as things advance. Look forward to talking soon..... Just after I parted with my dosh. Discovery of chewed oil pump gear I've had a look at the pistons and one is badly scored, shame as the previous owner had just rebored! [/a]
Post by midlifecrisisrd on Aug 18, 2016 19:32:15 GMT 1
Welcome in, looks like a good starting point
Chewed pump and worm gear would suggest they are not matched. The 250 and 350 had different pumps and matched worm drive but can be bodged together.
The scoring after reborn suggests all is not well in the pump area too
User arrow on here refurbishes oil pumps for a very reasonable fee. I've had 3 done now
Post by dusty350 on Aug 18, 2016 19:48:23 GMT 1
Hi Welcome to the forum. The bike looks good to go as it is - great for it's age As Steve says, Arrow on this forum is your oil pump guru - they come back better than new, and what a nice fella too Enjoy the new bike and the forum ! Regards Dusty
Post by richclare on Aug 18, 2016 21:12:57 GMT 1
Thanks for your replies chaps..... I didn't know about the 250/350 oil pump differences, so good to know. I will contact Arrow to see if he can work some magic.
Thanks again.
Rich
Post by Yogi on Aug 18, 2016 21:17:46 GMT 1
Welcome aboard mate and good luck with the build Matt
Post by Gitram on Aug 19, 2016 10:36:27 GMT 1
Bon Jour
Post by arrow on Aug 19, 2016 13:11:33 GMT 1
Welcome to the forum. The mixing up of 250 and 350 oil pumps and drives is not uncommon on this model, but it can be sorted.
Post by richclare on Aug 19, 2016 19:43:47 GMT 1
Welcome to the forum. The mixing up of 250 and 350 oil pumps and drives is not uncommon on this model, but it can be sorted. Hi Arrow, thanks for your post. I believe you are the pump wizard!? Perhaps if I sent you some initial pics of the offending pump etc. and see if it's something you could fix/help with ? Cheers Rich
Post by jon on Aug 19, 2016 20:16:13 GMT 1
If arrow can't fix it no-one can.
2 pumps done by him so far, and 2 to get done at some point.
Post by skydemon on Aug 20, 2016 0:29:06 GMT 1
Welcome aboard :-) plus one for Arrow
Post by arrow on Aug 20, 2016 8:07:28 GMT 1
Welcome to the forum. The mixing up of 250 and 350 oil pumps and drives is not uncommon on this model, but it can be sorted. Hi Arrow, thanks for your post. I believe you are the pump wizard!? Perhaps if I sent you some initial pics of the offending pump etc. and see if it's something you could fix/help with ? Cheers Rich Hi, you can post some pics if you want, but between doing nothing and a complete replacement there will be a repair job.
Post by richclare on Aug 20, 2016 12:26:00 GMT 1
Hi Arrow, thanks for your post. I believe you are the pump wizard!? Perhaps if I sent you some initial pics of the offending pump etc. and see if it's something you could fix/help with ? Cheers Rich Hi, you can post some pics if you want, but between doing nothing and a complete replacement there will be a repair job. Hi, completely understand. I just wasn't sure that if the pump was a 250 whether you can still repair/convert it? If you can, then how do I send it to you? Can I call you next week? Thanks very much Rich
Post by arrow on Aug 20, 2016 14:48:56 GMT 1
Hi, you can post some pics if you want, but between doing nothing and a complete replacement there will be a repair job. Hi, completely understand. I just wasn't sure that if the pump was a 250 whether you can still repair/convert it? If you can, then how do I send it to you? Can I call you next week? Thanks very much Rich Relax Rich. Arrow does work of this nature on a regular basis! You have found an excellent forum here. There are MANY top notch guys on here that will help you out, covering the whole bike. That's what its all about. I sent you a private message (a pm).
Post by richclare on Sept 21, 2016 21:04:12 GMT 1
Been busy at work, but have taken some of the main bits off the body. Discovered a rather nice rewire on an unknown fusebox! Bike looks a little grim with everything black. Stripped some of the engine too but need an impact driver to continue. The pump is in Arrow's hands having some beauty treatment! Still enjoying the forum and all the pics. Rich
Post by arrow on Sept 21, 2016 21:30:53 GMT 1
Guy's, Arrow has done much head scratching over this particular job! Rich removed the worm from the bike which had the correct pitch for the 350, but it was the shorter worm from the A/C bikes. Has anyone ever seen this before? I will send the correct parts back. We never stop learning!
Post by shaunthe2nd on Sept 21, 2016 22:48:05 GMT 1
zut alors!
Post by KevtheRev on Sept 22, 2016 21:05:46 GMT 1
Sacre Blue !!
Post by richclare on Oct 1, 2016 18:12:05 GMT 1
Nice language skills chaps.... the frog's legs down here are delicious! I need some advice guys and gals (I am assuming there are some like-minded ladies ! ?). I am checking the engine components before placing a bank breaking parts order. The clutch basket has some indents on the lugs, they are not deep, but will they cause problems? What is the cause? Appreciate your comments as always. Many thanks. Rich
Post by richclare on Oct 2, 2016 7:57:30 GMT 1
Sorry, should have done a search first - found the answer! Have a good weekend. Rich
Post by richclare on Oct 22, 2016 17:15:21 GMT 1
Had the frame sand-blasted this week and will hopefully get it sprayed next week. Thinking about doing it matt black so the frame sits back and lets the shiney bits shine☺. Swing arm will be the same but maybe powder chrome - it might be a flip of a coin to decide. Rich
Post by richclare on Oct 23, 2016 18:47:21 GMT 1
Ev'nin chaps, before I take the plunge, has anyone had experience with matt black frame painting? Does it look OK or just plain stupid? More importantly does it show up imperfections more than satin or gloss? Would appreciate your thoughts.
Rich
Post by wwwRD350LCnet on Nov 5, 2016 21:07:57 GMT 1
Bonjour Rich, here is the RD250/350LC Oil pump difference: Is your bike a '80 model ? You can check my website for few information: www.RD350LC.net in French and English Xavier
Post by richclare on Nov 5, 2016 22:51:25 GMT 1
Salut Xavier,
Thanks for the info. Monsieur Arrow has renovated my pump and sent another worm drive to try. It should arrive next week so will know which one works. Yes my bike is a 1980 model. Thanks again for the info. I have visited your site already ☺ Do you live in France?
Cheers Rich
Post by davey on Nov 10, 2016 10:33:02 GMT 1
Hi rich , Welcome in , i live in france also (06) alpes maritime. Where are you living
Dave
Post by richclare on Nov 10, 2016 10:36:53 GMT 1
Hi Dave,
Not that far from you.... 13 bouche du Rhône.
Cheers, Rich
Post by Topman350 on Nov 10, 2016 21:57:56 GMT 1
Welcome fella doing a great job so far enjoy the Build its a great forum :-)
Post by Dangerous on Nov 12, 2016 8:13:01 GMT 1
Welcome to the forum, all the help you will ever need on here, good luck with the build😀
Post by richclare on Nov 12, 2016 18:19:34 GMT 1
Hi Everyone, Thanks for your friendly words of encouragement, much appreciated. Can anyone confirm if the dog gears, on my driveshaft, are in the correct orientation or not? In my photo they are in line but in other photos I've studied they are offset. Does it actually matter? Cheers Rich
Post by richclare on Nov 13, 2016 18:54:13 GMT 1
I got the frame back from being powder - coated this week. Very pleased with the finish and the guy was a bike nut too! I had some time this weekend to start putting things back together, makes a pleasant change from dismantling!.... Also received a rather nice delivery from Arrow (I know it's only a pump, but it's a work of art). Rich
Post by mags on Nov 13, 2016 21:03:39 GMT 1
lovely clean frame great result!
