Post by muttsnuts on Jul 20, 2016 13:31:11 GMT 1
Anybody got the carb specs/differences for the RD125LC 10W and 12A carbs, got a 12A carb in that is going onto a 10W engine, currently the bike doesn't run too well or rev out, I suspect the internal specs are very different so looking to modify the 12A carb to match the 10W one
If not, does anyone know of an alternative carb for the 10W that will work well ?
Post by Tone on Jul 20, 2016 15:32:02 GMT 1
I've got a Yamaha service data book that gives the carb specs for the 12A and 10W models as:
RD125LC (12A) RD125LC (10W)
Carb Type/Make/I.D Mark VM24SS/MIKUNI/12A VM24SS/MIKUNI/10W
Main Jet 195 155
Jet Needle/Clip Position 5GN36 - 4 5GN36 - 3
Needle Jet 0-2 0-8
Cutaway 1.5 1.5
Pilot Jet 20 20
Air Screw (Turns Out) 1 and 1/2 1 and 1/2
Float Height 21mm +/- 1mm 21mm +/- 1mm
Idle Speed 1,300 r/min 1,300 r/min
Hope this helps
Tone
Post by muttsnuts on Jul 20, 2016 17:37:07 GMT 1
excellent, cheers
Post by ethan on Jun 18, 2019 17:15:34 GMT 1
Hello did you sort this as thinking of doing it myself but struggling to source the 0-8 needle jet. Sourced an original 12A 00 carb. Any help appreciated. Thank you
Post by looey on Jun 19, 2019 12:30:28 GMT 1
If it's any help, I've had 125LC's on and off for over 30yrs and no matter what anybody says, they will perform pretty much the same with any model of 125LC carb as long as the main jet and needle clip position is correct for your setup.
I've run 12A, 10W and 11A carbs on them and they will all give roughly the same performance.
Post by raven13 on Jun 19, 2019 13:41:34 GMT 1
If it's any help, I've had 125LC's on and off for over 30yrs and no matter what anybody says, they will perform pretty much the same with any model of 125LC carb as long as the main jet and needle clip position is correct for your setup. I've run 12A, 10W and 11A carbs on them and they will all give roughly the same performance. I'm with you on this one Looey, set the carb up to the engine and performance is pretty much the same
Post by rich on Jun 19, 2019 19:39:19 GMT 1
Anyone tried running a 125 on a single PWK28?
Post by looey on Jun 19, 2019 20:15:00 GMT 1
Anyone tried running a 125 on a single PWK28? It's a good call. I've got some PWK28's on my Hyybrid but sold my last 125LC recently
Post by tsa on Jun 20, 2019 11:43:07 GMT 1
The air jet in the 10W is much smaller too. The Ledar kit was either 1mm or 1.2mm ish
