filters
Jun 27, 2016 16:26:56 GMT 1
via mobile
Post by greeny on Jun 27, 2016 16:26:56 GMT 1
Hey up. I am getting continuous crap in carbs. Bike is running like a bag of s#!t Ive removed the tank emptied ready to give it a thorough clean. My question.
Are you ok using in line filters between tap and carbs just so i can keep an eye on any muck coming through. Its very fine and silty.
Any recommendations on filters? Also cleaning?? Thanks E
filters
Jun 27, 2016 17:45:05 GMT 1
Post by bare on Jun 27, 2016 17:45:05 GMT 1
Inline Filters near the carb inlets are Mandatory on these Bikes. Bike's tanks too often have a surprising amount of silt in them... as well as rust, from water in the fuel. Often filling up at a gas station injects a fresh silt load Inground fuel storage tanks (gas stations) are Notorious for this. Notably Aged Metal ones. Also the OEM fuel taps have a Fine mesh filter that typically crumbles in place. Washing out the tank won't be wasted effort, nor will buying a 'decent' quality replacement fuel tap assembly. Unless you like cleaning carbs... indefinitely :-)
filters
Jun 27, 2016 18:08:52 GMT 1
via mobile
Post by greeny on Jun 27, 2016 18:08:52 GMT 1
Cheers for info Bare. Any particular filter you can recommend? E
filters
Jun 27, 2016 20:26:32 GMT 1
Post by headcoats on Jun 27, 2016 20:26:32 GMT 1
filters
Jun 27, 2016 20:44:32 GMT 1
via mobile
Post by greeny on Jun 27, 2016 20:44:32 GMT 1
Thanks for info.
Next is tank cleaning. Any advice welcome... Cheers E
filters
Jun 27, 2016 20:46:57 GMT 1
via mobile
Post by midlifecrisisrd on Jun 27, 2016 20:46:57 GMT 1
Get some deox c in the tank.
Will get all the rust and crap out
filters
Jun 28, 2016 8:56:05 GMT 1
via mobile
Post by greeny on Jun 28, 2016 8:56:05 GMT 1
Cheers E
filters
Jan 20, 2018 19:31:14 GMT 1
Post by earthman on Jan 20, 2018 19:31:14 GMT 1
Would you happen to have a new link to these filters please?
filters
Jan 20, 2018 20:14:10 GMT 1
Post by headcoats on Jan 20, 2018 20:14:10 GMT 1
filters
Jan 20, 2018 20:21:02 GMT 1
Post by earthman on Jan 20, 2018 20:21:02 GMT 1
filters
Jan 20, 2018 21:45:34 GMT 1
Post by Tobyjugs on Jan 20, 2018 21:45:34 GMT 1
When i first started using my LC i also used mini filters. The filters were old and caused no problems. I decided to do a small service on the bike and also changed the filters for some new ones. The bike ended up seizing on one cylinder and the only thing i could find was the fuel filter for that cylinder was partially blocked. I now run all my engines without filters and prefer to clean the tank properly instead of use filters. The carbs on my bikes never seem to stay closed for long so if any debris is found it is removed straight away. In the last three years i have only had one issue with dirt which was causing the needle valve to stay open.
filters
Jan 21, 2018 10:40:59 GMT 1
Post by earthman on Jan 21, 2018 10:40:59 GMT 1
I'm wondering if there's a filter with twin inlet & outlet stubs?
That could be placed closer to the tank and if it did get blocked, both cylinders would stop firing, preventing the possibility of the other one seizing??
filters
Jan 21, 2018 11:16:40 GMT 1
Post by Tobyjugs on Jan 21, 2018 11:16:40 GMT 1
One larger filter with Tee fitting either side
Post by lrcarl on Jan 21, 2018 11:22:26 GMT 1
I'm wondering if there's a filter with twin inlet & outlet stubs? That could be placed closer to the tank and if it did get blocked, both cylinders would stop firing, preventing the possibility of the other one seizing?? Check out pingle fuel filters they have what You need but expensive Carl
Post by earthman on Jan 21, 2018 11:25:03 GMT 1
One larger filter with Tee fitting either side Yes, that's certainly an option. I've just found a single feed, twin outlets filter so only one T piece needed in that case.
filters
Jan 21, 2018 15:10:49 GMT 1
Post by Tobyjugs on Jan 21, 2018 15:10:49 GMT 1
How about the sugestion from Mutts, R6 tap one pipe fitting going to your double exit filter
filters
Jan 21, 2018 15:26:12 GMT 1
Post by earthman on Jan 21, 2018 15:26:12 GMT 1
How about the sugestion from Mutts, R6 tap one pipe fitting going to your double exit filter That's certainly something to consider too.
filters
Jan 21, 2018 21:23:00 GMT 1
Post by earthman on Jan 21, 2018 21:23:00 GMT 1
Post by stusco on Jan 23, 2018 7:57:10 GMT 1
I’ve got the single outlet Pingle does the job I used to check it after every ride but my tank must be clean now as the filter is always clean now
Post by earthman on Jan 23, 2018 8:21:14 GMT 1
I’ve got the single outlet Pingle does the job I used to check it after every ride but my tank must be clean now as the filter is always clean now I don't suppose that you could post a picture of it in situ sometime? I take it that you used a T piece to connect it to the two carbs.
Post by lcyoungboy on Jan 23, 2018 13:10:01 GMT 1
Need to get some of these
filters
Jan 23, 2018 15:44:38 GMT 1
Post by stusco on Jan 23, 2018 15:44:38 GMT 1
I’ve got the single outlet Pingle does the job I used to check it after every ride but my tank must be clean now as the filter is always clean now I don't suppose that you could post a picture of it in situ sometime? I take it that you used a T piece to connect it to the two carbs. Yes I have a high flow single outlet tap so a tee piece is required
Post by badger69 on Aug 7, 2020 13:25:58 GMT 1
Total novice here, I have rd lc 250, I wish to fit fuel filter, do I fit it between tap and left carb, also can someone give a live link to show best type to buy, thanks and sorry for the stupid question, I'm trying to learn though, all help appreciated.
