Post by mouse on Feb 24, 2018 17:37:52 GMT 1
Horn bracket is brilliant Dusty, really good.
The bike looks c**p though!!!
Mouse
Post by dusty350 on Feb 24, 2018 18:09:58 GMT 1
Haha, cheers mate I must try harder !! Fitted the horn bracket this morning. Not a job I would care to do again !! It helped having the other bike to copy, thankfully. The Rgv bottom yoke has a concave curved shape, so you need to space the bracket away from it so the horns clear the fork legs. The spacers are just ally tube that has a chamfer at one end allowing the bracket to sit square to the curved yoke. Luckily I had some ally tube that was the right internal and external diameter. I found the angle of the chamfer - 15 degrees - and cut the 2 pieces of tube on my drop saw as it has an all purpose blade that will cut metal as well as wood. I now had the components to allow me to drill the mounting holes in the yoke; 20180224_121039 by David Miller, on Flickr I offered the bracket up and marked where I needed to drill. I centre punched the yoke, and started off with a pilot drill, then up to a 6mm. Once done, and happy it was at the correct angle, I tapped the hole. Did he same the other side; 20180224_120116 by David Miller, on Flickr And then bolted on the bracket; 20180224_115940 by David Miller, on Flickr 20180224_115931 by David Miller, on Flickr And the end result; 20180224_130548 by David Miller, on Flickr Bracket will now get a final rub down for paint, spacer tubes will get polished and I will sort out some matching fasteners. Gonna order some better horns too. Dusty
Post by yamark on Feb 24, 2018 18:27:12 GMT 1
Great work on the horn bracket mate, it looks very trick. Expect a call from Norbo to go into production
Post by dusty350 on Feb 24, 2018 18:37:07 GMT 1
Post by Mr Kipling on Feb 24, 2018 20:10:31 GMT 1
Looking Sweet !!! there Dusty...
Post by dono on Feb 25, 2018 11:51:59 GMT 1
Nice horn Bracket Dusty, looks great, that’s a job I need to tackle on mine too.... wanted to make a comment about your swinger, yes it looks a lot shorter but isn’t that how the original Lc was? ( I’m sure it was) I think we have all, got used to seeing hybrids with longer back ends and started to like the look...... the shorter back end has its advantages though, the front end will be a lot lighter and more prone to getting airborne which is one of the hooligan qualities we all enjoyed back in the day so it’s a bonus :-)
Post by dusty350 on Feb 25, 2018 14:10:23 GMT 1
Hi Mark The Metmachex keeps the lc wheelbase standard whereas an rgv arm makes it around 4 inches longer. I dont mind the look of the longer wheelbase with rgv gear though.
Dusty😁
Post by mouse on Feb 25, 2018 17:44:51 GMT 1
Beautiful job Dusty, as good as anything i've seen.
Mouse
Post by dusty350 on Mar 1, 2018 22:17:38 GMT 1
Cheers mate Finished now; 20180301_160209 by David Miller, on Flickr Painted gloss black, and I lightly polished the ally spacers and the Ypvs logo plate. Used some dome nuts to tidy it up too. Dusty
Post by donkeychomp on Mar 2, 2018 0:20:36 GMT 1
Sweet! Looks better than a factory part, great job mate.
Post by dono on Mar 2, 2018 19:52:00 GMT 1
Cheers mate 😊 Finished now; 20180301_160209 by David Miller, on Flickr Painted gloss black, and I lightly polished the ally spacers and the Ypvs logo plate. Used some dome nuts to tidy it up too. Dusty What a fantastic job Dusty, mind you I shouldn’t of expected anything less having looked at your previous work, will be great with a pair of chrome horns.. cheers Mark
Post by dusty350 on Mar 2, 2018 23:42:44 GMT 1
Cheers fellas Pretty pleased with the way the bracket turned out, especially for £2 !! The fold in the bracket makes it really strong and it mimics the look of a standard bracket at first glance. I was thinking about the bike today, and the fact it will run premix. The oil tank made way for the electrics plate under the side panel, but I would still prefer to run a pump, especially after Arrow has rebuilt it. So I'm now thinking of making a template for an oil tank that will mount to the side of the rad, maybe. I used a fella in Wales for a bespoke tank in the past, and will see what I can come up with. Dusty
Post by donkeychomp on Mar 3, 2018 0:58:35 GMT 1
Now that's something I've never seen before. That would look very trick.
Post by dusty350 on Mar 3, 2018 9:44:04 GMT 1
Hi Alex, There are a few different ideas for oil tanks. The hardest bit is finding somewhere to mount it so it looks good and functions properly. I want something that blends in as much as possible. I was really pleased with the tank I had made before, but that tucked up inside the back of the frame on a pv, and I don't have that option on the Lc. I know Mutts had a cylindrical type tank on his pv that looks good, and it seems an obvious place to mount a cylinder style tank if you have no other option. I saw this on ebay last night, and may give it a try; www.ebay.co.uk/itm/Universal-14-Ounces-2-x-10-2-x-10-Aluminum-Radiator-Overflow-Tank-Catch-Can/281665809629?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649They do different sizes, and the bottom would need modding to a single spigot, but probably cheaper to do that than get a bespoke tank made from scratch. I don't need a big cylinder so it would probably fit in well, and not be too obvious at first glance. Dusty
Post by 17again on Mar 3, 2018 10:14:45 GMT 1
Nice job dusty.
Some of the guys here could do nice business with the products
Post by donkeychomp on Mar 3, 2018 13:40:03 GMT 1
I like that Dusty. Look forward to you fitting it.
Post by dusty350 on Mar 3, 2018 15:17:45 GMT 1
I wont be fitting the one I've linked as it's going to be too tall - just wont look right. Something about 8"x2" would be better. Filler cap at top, single feed for an oil line at the bottom, a vent, and a sight tube would be nice but not essential. I will keep looking but think I will end up getting the cardboard out again !! Dusty
Post by andy748 on Mar 3, 2018 17:08:35 GMT 1
Lovely job Dusty, hope mine turns out half as nice! Andy.
Post by wangwang on Mar 3, 2018 19:00:12 GMT 1
Very nice.
Post by philmill on Mar 3, 2018 19:57:07 GMT 1
It does look the part, a nice finishing touch.
Phil
Post by dusty350 on Mar 12, 2018 21:02:34 GMT 1
Messed around with the numberplate again the other day. I wanted a smaller plate as it improves the look of the back end. I tried all sorts to get it looking right, but in the end I had to cut down my numberplate bracket. It had already been cut for the recessed rear light, so I didn't feel bad about it !! I cut off just enough to mount the 7x5 plate; 20180308_160939 by David Miller, on Flickr One job leads to another of course, and now need to make a smaller bracket for the indicators, so it doesn't stick out so far ! Also need to dig out my pv oil pump for a rebuild. I'm waiting on an ally reservoir from China to arrive to see if it's suitable for use as an oil tank, or maybe modded to work. That might take a month to get here. Dusty
Post by donkeychomp on Mar 12, 2018 22:08:28 GMT 1
Looks so much better Dusty. Is the bike called Pepe? Alex
Post by earthman on Mar 12, 2018 22:34:28 GMT 1
Messed around with the numberplate again the other day. I wanted a smaller plate as it improves the look of the back end. I tried all sorts to get it looking right, but in the end I had to cut down my numberplate bracket. It had already been cut for the recessed rear light, so I didn't feel bad about it !! I cut off just enough to mount the 7x5 plate; 20180308_160939 by David Miller, on Flickr One job leads to another of course, and now need to make a smaller bracket for the indicators, so it doesn't stick out so far ! Also need to dig out my pv oil pump for a rebuild. I'm waiting on an ally reservoir from China to arrive to see if it's suitable for use as an oil tank, or maybe modded to work. That might take a month to get here. Dusty When it comes to MOT time, do you just change that plate back to a 'normal' size one,....what about a rear reflector, where are you going to mount that?
Post by Deleted on Mar 13, 2018 0:42:31 GMT 1
Thats a sharp looking bike. Well done.
Post by donkeychomp on Mar 13, 2018 1:00:52 GMT 1
MOT won't bother with size of the plate. Plod will. Not sure about the reflector for an MOT though...
Post by earthman on Mar 13, 2018 8:30:04 GMT 1
MOT won't bother with size of the plate. Plod will. Not sure about the reflector for an MOT though... Alex Rear reflector is a requirement, I had to buy one and quickly attach it during an MOT. I'm surprised that the size of the plate won't fail it, surely it should because it's not road legal at the end of the day?
Post by donkeychomp on Mar 13, 2018 12:49:25 GMT 1
Well I've never had an issue, with bikes and cars come MOT time. But I was fined £60 for having an incorrect rear plate on my car a few years ago!
Post by dusty350 on Mar 13, 2018 18:16:06 GMT 1
Hi I've got the full sized plate and proper rear reflector that will go on for the MOT. I will take my chances after that !! Dusty
Post by dono on Mar 13, 2018 18:25:15 GMT 1
Looking fantastic, you won’t have any trouble with your mot re the plate size, both my bikes have the same size plate and have never had an issue. I did have a comment off the rozzers once but he said he was a nice police man and would only do me for speeding and he wouldn’t bother about the plate size haha
Post by dusty350 on Mar 13, 2018 18:46:50 GMT 1
Thanks to my knackered back and now knee, the chances of me riding much are greatly reduced unfortunately, so the small plate will stay on after the MOT. Still got my Fire Service I.D, and that's got me out of trouble in the past Dusty
