Post by Norbo on Jan 3, 2007 14:49:09 GMT 1
HELP wanted .
I am doing a spesh with a big 485cc tuned up engine in and dont whant it to run hot during the summer. I have fornd my standard ypvs sometines does in very hot days and this being bigger i think its more likely to get to hot .
The pont of this post is i have seen a few bikes that have had the RGV rad fitted and i dont know what has been done to make it work right .
I have had a look at a rad i have and other then the pipes facing the wrong way i dont see how to get the water to the head and the header bottle as the ypvs has 2 inlets in the middle and the RGV had just 1 at the side .
If you have done thos mod or just have some pics of someone that has please help if you can .
Cheers .
Post by vin on Jan 3, 2007 17:39:27 GMT 1
Sent you an E-mail Norbo that may help!
Post by tonkatoy on Jan 3, 2007 17:42:51 GMT 1
Sent you an E-mail Norbo that may help! vin's got his finger on the pulse
Post by vin on Jan 3, 2007 17:44:49 GMT 1
Not my work buddy but I know a man that can or rather have done ;D
Post by tonkatoy on Jan 3, 2007 17:49:59 GMT 1
Not my work buddy but I know a man that can or rather have done ;D you know what they say mate its not what you know !!!!! but who you know
Post by vin on Jan 3, 2007 17:52:15 GMT 1
Very true ;D
Post by alibongo on Jan 3, 2007 18:36:40 GMT 1
I know f**k-all, its great! ;D
Post by vin on Jan 3, 2007 19:50:02 GMT 1
I know f**k-all, its great! ;D ;D ;D ;D
Post by pablo on Jan 4, 2007 0:28:56 GMT 1
what about a flat-motor fan norbs?
Post by alibongo on Jan 4, 2007 11:45:23 GMT 1
But its not a radiator mate!
Post by pablo on Jan 4, 2007 20:50:59 GMT 1
i meant to aid cooling on the original rad before going to the trouble of a rad swap
Post by Norbo on Jan 4, 2007 22:55:44 GMT 1
The new RGV forks and front mudguard block the airflow and i have been toled by a couple of people since the swop on there bikes they have run hot.
Post by Dirtbag on Jan 5, 2007 8:39:43 GMT 1
There are a couple of very minor mods you can do Norbs....that will certainly help with the cooling..................
Run a cooler grade plug than normal ,
Increase the coolant to water ratio...i.e run 75% Glycol / Ethylene
There is also a product called water-wetter which increases the cooling ability enormously.........if I can find a link for a place that sells it - I'll post it up
Post by Dirtbag on Jan 5, 2007 9:13:50 GMT 1
