Post by finnned on Dec 19, 2006 0:41:22 GMT 1
Whats the score with running a YPVS without a battery? I know it will run just by taking it off, but I've heard about a simple circuit that smoothes the voltage from the reg/rec and gives a better spark. Any ideas?
Post by Dirtbag on Dec 19, 2006 15:56:22 GMT 1
Why would you want to ? I thought it would mess up the YPVS servo and CDI settings
Post by mellow on Dec 19, 2006 22:54:08 GMT 1
u talkin bout a battery eliminator? im sure ypvs will run once running
Post by finnned on Dec 20, 2006 23:45:22 GMT 1
Yes, pv's go through cleaning cycle once started and then operate as normal, so I don't think it causes any problems with running. Just wanted to know pro's & con's and how you wire it up?
Post by mellow on Dec 20, 2006 23:50:34 GMT 1
norbo or one of the other clever gits need to give u that info m8
Post by nuttytart350 on Dec 21, 2006 0:02:14 GMT 1
norbo or one of the other clever gits need to give u that info m8 so thats either scott jaccobean alimongo pabs outa the frame then.... ;D
Post by finnned on Dec 21, 2006 0:17:00 GMT 1
If anyone has any ideas it'd be much appreciated...... It's supposed to be quite easy, but my wiring skills ran-out after 3 wires and a plug. Does anyone on here run without a battery?
Post by alibongo on Dec 21, 2006 10:43:31 GMT 1
norbo or one of the other clever gits need to give u that info m8 alimongo Slight spelling mistake there cheeky!
Post by pablo on Dec 21, 2006 19:38:10 GMT 1
If anyone has any ideas it'd be much appreciated...... It's supposed to be quite easy, but my wiring skills ran-out after 3 wires and a plug. Does anyone on here run without a battery? think someone who races them should be able to help
Post by pablo on Dec 21, 2006 19:38:48 GMT 1
norbo or one of the other clever gits need to give u that info m8 so thats either scott jaccobean alimongo pabs outa the frame then.... ;D very funny
Post by nuttytart350 on Dec 21, 2006 21:32:45 GMT 1
norbo or one of the other clever gits need to give u that info m8 alimongo Slight spelling mistake there cheeky! soz
Post by scott on Dec 21, 2006 21:38:59 GMT 1
norbo or one of the other clever gits need to give u that info m8 so thats either scott jaccobean alimongo pabs outa the frame then.... ;D just about to cross my name off then i saw the bottom bit ;D ;D ;D ;D
Post by mellow on Dec 21, 2006 21:42:32 GMT 1
well that went down like a lead balloon dint it gf ;D
Post by scott on Dec 21, 2006 21:45:21 GMT 1
well that went down like a lead balloon dint it gf ;D sorted it now
Post by Norbo on Dec 22, 2006 10:58:39 GMT 1
It will run fine with out a battery. The ypvs will run so long as the bike is running But the lights will go dim at lowrevs and flicker . You will not get a better spark and you will not feel the bike running better with a battery ilimator . You would be better ov fitting a V rated plug if thats what you whant but unless the bike is tuned even thats a wast of time .
