Post by vin on Nov 18, 2006 13:50:08 GMT 1
I've just done a plug chop on my F2 and for peace of mind just would like your opinions? I believe they are fine! I have grafted some JL end cans onto my standard pipes but everything else is standard apart from 200 mains (thanks Drew :wink: ) I hope I did this right? With new plugs I gave the bike a good thrashing through the gears (felt good too ) and then coasted to a stop very quickly with the clutch in!
Post by jacobeana on Nov 18, 2006 14:09:03 GMT 1
To do a proper plug chop you need to be on full throttle for approx five seconds hit the kill switch and pull the clutch in at the same time.
Should be done on nearly new plugs
looking at your plugs in the pic you are running a bit rich which is ok
Post by pablo on Nov 18, 2006 18:33:00 GMT 1
its not always as easy it sounds to do a decent plug chop...i find it a bit like juggling ...cant do that properly either ;D sound advice is to start a couple of sizes bigger then work back as too small runs too lean which makes the bike run hot and gives the problems a bit too big will just run a bit flatter,but shouldnt endanger the engine...
Post by vin on Nov 18, 2006 19:35:08 GMT 1
Cheers for the replies guys Pabs I've changed the mains from 185 standard to 200 but felt the bike was running rich on standard trim (probably me being a pussy ) jacobeana,so many theory's of how to do this it gets a bit confusing Right then guy's I've tried to take some better pictures of the plugs because the first one wasn't a truly good picture of them....bloody camera or is it me And trust me they are brand new!! what I think I did do wrong is although I warmed the engine up with old plugs I put the new ones in when I left the house and had to go down a few lanes before I could get out onto the stretch of road :oops: so tomorrow I will clean them back up and change the plugs at the road side and pick a longer road (not sure about 6 miles though :? ) and have another go! I tried to take some more better pictures but again not brilliant:roll:
Post by pablo on Nov 18, 2006 20:20:14 GMT 1
reading plugs with any degree of accuracy is a skill in itself vin...i think theres a great guide to jetting and plug chops on the home-page somewhere,written by our very own jim-jam...i'll see if i can find it mate
Post by pablo on Nov 18, 2006 20:28:07 GMT 1
dunno where its gone...it was good tho...PM the 'one-armed-bandit mate'...ask him... ;D
Post by mellow on Nov 18, 2006 21:05:32 GMT 1
i find the BEST way to do a plug chop is to use an angle grinder tryin to chop a plug with an axe no matter how sharp it is just isnt good enough ;D
Post by scott on Nov 18, 2006 21:08:35 GMT 1
i find the BEST way to do a plug chop is to use an angle grinder tryin to chop a plug with an axe no matter how sharp it is just isnt good enough ;D theres allways 1 ::)and it's usually 1 of 2
Post by mellow on Nov 18, 2006 21:10:37 GMT 1
Post by scott on Nov 18, 2006 21:13:15 GMT 1
allright mukka ;)how am ya
Post by mellow on Nov 18, 2006 21:19:23 GMT 1
skiddly daddly ta bert u?
Post by scott on Nov 18, 2006 21:27:13 GMT 1
not to bad m8,picked me oil seals and gasket set up ready for the engine re-build,just waitin for some tacho bits to come off norbo
Post by mellow on Nov 18, 2006 21:28:06 GMT 1
he will b a while m8 trainin to wank with his other arm ;D
Post by scott on Nov 18, 2006 21:32:46 GMT 1
he will b a while m8 trainin to wank with his other arm ;D lol ;D ;D
Post by nuttytart350 on Nov 18, 2006 21:47:49 GMT 1
i hate to be the odd one out here muckers....but i have always done plug chops on old plugs with a few deposites on....recon u get a better reading.....
Post by scott on Nov 18, 2006 21:49:34 GMT 1
i hate to be the odd one out here muckers....but i have always done plug chops on old plugs with a few deposites on....recon u get a better reading..... theres allways 1 who has to be different
Post by mellow on Nov 18, 2006 21:52:20 GMT 1
wots she know...................never had a bike at more than quarter throttle
Post by nuttytart350 on Nov 18, 2006 21:52:36 GMT 1
soz.....but i'm sure u need a few deposites to "catch" the colour of the burn....
Post by mellow on Nov 18, 2006 21:53:46 GMT 1
il give u sum deposit
Post by nuttytart350 on Nov 18, 2006 21:53:59 GMT 1
wots she know...................never had a bike at more than quarter throttle OI.....i used 2 b a right little tearaway.....
Post by mellow on Nov 18, 2006 21:54:58 GMT 1
well u aint since i known ya..............thinkin of gettin a puch maxi so u can keep up
Post by nuttytart350 on Nov 18, 2006 21:55:13 GMT 1
il give u sum deposit ......its not yur birthday till next week.... ;D
Post by mellow on Nov 18, 2006 21:56:36 GMT 1
eye roll
Post by jacobeana on Nov 18, 2006 22:35:57 GMT 1
Cheers for the replies guys Pabs I've changed the mains from 185 standard to 200 but felt the bike was running rich on standard trim (probably me being a pussy ) jacobeana,so many theory's of how to do this it gets a bit confusing Right then guy's I've tried to take some better pictures of the plugs because the first one wasn't a truly good picture of them....bloody camera or is it me And trust me they are brand new!! what I think I did do wrong is although I warmed the engine up with old plugs I put the new ones in when I left the house and had to go down a few lanes before I could get out onto the stretch of road :oops: so tomorrow I will clean them back up and change the plugs at the road side and pick a longer road (not sure about 6 miles though :? ) and have another go! I tried to take some more better pictures but again not brilliant:roll: Vin Trust me i was taught how to due a plug chop by a two stroke tuner and i did tons of plug chops on a rolling road You should always use plugs which have done a few miles the plugs should already have colour on them, the darkest plugs will always change colour when you do a plug chop new plugs will not give you a correct result as you will see white porcelain Run the bike on full throttle for a min five seconds hit the cut out switch and pull the clutch in a perfect set up the plug should be biscuit brown, you should also be looking into the plug at the base of the porcelain, you can also check if your timing is correct, look at the top of the electrode with a magnifying glass you should see a silver ring round the edge If you try again tomorrow wear something warm it going to be cold ;D
Post by nuttytart350 on Nov 18, 2006 22:42:07 GMT 1
Oooooo......would that be hob nobs....or rich tea.....wot sort of buscuits do u buy..... ;D
Post by nuttytart350 on Nov 18, 2006 22:42:59 GMT 1
soz.....but i'm sure u need a few deposites to "catch" the colour of the burn.... thats wot i said..... ;D
Post by jacobeana on Nov 19, 2006 11:29:39 GMT 1
Oooooo......would that be hob nobs....or rich tea.....wot sort of buscuits do u buy..... ;D Shorties would be to weak rich tea would be spot on ;D Bourbons would be to rich
Post by vin on Nov 19, 2006 12:47:22 GMT 1
jacobeana, I didn't mean to question your knowledge mate just you here a different way to do a chop and you would think it would be a generic one Anyway your method sounds fine too me and again your right about the cold........too bloody cold for me so it will have to wait
Post by mellow on Nov 19, 2006 21:37:19 GMT 1
how do mine look jim
Post by nuttytart350 on Nov 20, 2006 22:07:11 GMT 1
To be honest Mellow, I'm strugging to get past having to describe your brown ring and tiny electrode. pmsl..... ;D ;D ;D
