Post by midlifecrisisrd on Jan 21, 2016 21:49:55 GMT 1
Looking good Steve...Home straight now surely..!! Gav Hopefully so Just a big jigsaw now. Just the little details take ages. Spent 30 min tonight trying to work out the clutch cable route. Thought I knew but have 2 nos one's which are identical but seem short when I fit them how I think they go. I'll leave it for now, just needed it fitted to the arm so I can fit the carbs as a pain if left to after Steve
Post by yamark on Jan 21, 2016 22:20:04 GMT 1
Steve, breathtaking build. I can't tell the bike from new, except your finish looks better.
Great write up as well.
Cheers Mark
Post by midlifecrisisrd on Mar 4, 2016 16:43:15 GMT 1
Been busy with other stuff but got an hour or so the other night Got the stator fitted and put the clutch cable on to stop fiddling after carbs are fitted New fuel lines, clips, tee and vent/drain hoses. Really need to put some major time into this Steve
Post by markhoopy on Mar 4, 2016 17:14:30 GMT 1
Really need to put some major time into this Steve Seems to be going perfectly well as it is to me
Post by midlifecrisisrd on Mar 21, 2016 10:47:49 GMT 1
Built the clocks up the other night. NOS speedo, Tacho, top plate and damper rings. Steve
Post by markhoopy on Mar 21, 2016 12:22:37 GMT 1
A set of clocks in that condition must have cost a few quid to put together! Great rebuild that will look stunning once finished
Post by midlifecrisisrd on Mar 21, 2016 13:47:40 GMT 1
A set of clocks in that condition must have cost a few quid to put together! Great rebuild that will look stunning once finished Cheers Mark. Yes a few quid spent but totally worth it. I feel the handlebar area is what you are staring at all the time so a mint resto has to be perfect in this area hence all the nos clocks and switchgear The instruments were a really lucky find but surprisingly the damper rings were available but not where you'd expect. Need to get it done and sold as already bought my next project lol Steve
Post by budgie on Mar 21, 2016 20:39:51 GMT 1
Stunning...nothing else...just stunning...!! Your attention to detail is superb.... Looking forward to the end result...
Gav
Post by lrcarl on Mar 21, 2016 23:11:45 GMT 1
top draw this one,going to be a stunner
carl
Post by lb on Mar 31, 2016 7:04:47 GMT 1
Built the clocks up the other night. NOS speedo, Tacho, top plate and damper rings. Steve I keep doing what Mark suggested ages ago,search on part numbers but i cant find a N1 top plate lol. That one is very nicely done.
Post by midlifecrisisrd on Apr 14, 2016 22:49:45 GMT 1
Another few hours in the shed tonight Kickstart fitted with repair kit, Brake res and pipe fitted with new clips. Chain fitted and new chain guard NOS steering lock fitted with re plated flap. No real need as Iggy switch has a lock too but for some reason they had both NOS switchgear along with new grips, bar ends, lever and pivot. Correct NOS 1AR clutch cable. Refurbished master cylinder and correct NOS 57v throttle cable. Also fitted the clocks Steve
Post by midlifecrisisrd on Apr 15, 2016 22:43:44 GMT 1
Ended up back at it tonight. Supposed to be getting the Lc2 running but after whipping the top end off it turns out the PV's and all bushes/seals are gubbed so shelved for now. I painted the rad yesterday so fitted it tonight and plumbed it all up. The Matt silicone hoses look good And yes its supposed to have the jubilee clips on the top hose couplings but yes they look crap. The mix and match is a strange one Even managed to find a NOS pipe for the expansion tank. Well not totally true, it's off a 125 lc but is the right shape, just a little too long so needs trimming. Went to fit the oil pump next but I cant find my tubing to go to the carbs. Then tried to fit the coil but one plug cap is knackered so called it a night. Steve
Post by doohanno1 on Apr 15, 2016 23:39:30 GMT 1
Stunning..!!!!!!
Post by sp885 on Apr 16, 2016 3:41:49 GMT 1
Lovely job
Post by arahim66 on Apr 16, 2016 5:02:03 GMT 1
Built the clocks up the other night. NOS speedo, Tacho, top plate and damper rings. Steve .Hi Steve, the clock rebuild looks stunning. I thinking of DIY mine rd350lc clock too but needed some tutorial guide on how to do it, especially to adjust the odometer to zero and replace the dial face? Is there any link I can read for this rebuild.Regards Rahim.
Post by midlifecrisisrd on Apr 16, 2016 9:13:53 GMT 1
Hi Rahim,
Cheated this time using new clocks but have in the past done diy
There are threads on here about doing it, probably in some of the rebuilds. Think dusty did one or jonw
Biggest issue is getting the needle off. The lc ones are very tight and brittle so break when they fly off so do it into a pillow case or a bag.
Simon wells does new faces (not decals). He is kateannwells on ebay.
As for resetting if you gently separate the dials with a thin knife to disengage the cogs you can reset each dial to 0.
I would also advise making a mark on the speedo mechanism to show where 0mph was as you need a reference of where it was before refitting the needle.
I test before with a drill and note the speed then again after to check it's the same.
Think replacement needles are available on eBay for xt/dt
Hope that helps Steve
Post by arahim66 on Apr 16, 2016 14:57:27 GMT 1
Thanks Steve for the advice. Regards Rahim.
Post by midlifecrisisrd on Apr 16, 2016 22:35:56 GMT 1
Got the footplates and pegs fitted tonight. Exhaust mount bushes went in hitch free, biggest hassle was getting the screws out the rear rubbers. Front pegs, and plates were NOS, had rear pegs with good chrome so just fitted new screws, pins and springs Again had to source a good gear change as original was a rust fest so just had to fit a new rubber Steve
Post by anthonyr on Apr 21, 2016 2:28:12 GMT 1
Hi Nice job, did you set yourself a budget for this.
Post by jon on Apr 21, 2016 7:38:13 GMT 1
What's a 'budget' ? Jon
Post by midlifecrisisrd on Apr 21, 2016 8:38:36 GMT 1
Hi Nice job, did you set yourself a budget for this. Budget lol The plan changed from what I intended. Original plan was to get it into a rideable bike. Certainly no show bike. I didn't used to be an "anorak" kind of restorer but after doing a couple of bikes for other people who wanted "as it left the factory" builds I found I enjoyed finding out what parts should be what and hunting for them When I started finding so much new or mint parts I decided the challenge would be to get it as new and original as possible. Budget has moved 3 times and now don't want to know total but certainly ain't gonna make money when I sell it. Strangely I read an article about a bike restoration company quoting £7k minimum for parts and labour to restore a 2 stroke twin Steve
Post by KevtheRev on Apr 21, 2016 10:54:33 GMT 1
Hi Steve , that's beautiful work there man . Thanks for the inspirational thread and best of luck with the bike . It's absolutely stunning .
Post by seanclarky on Apr 22, 2016 8:49:34 GMT 1
looking really good steve, well done
Post by arrow on Apr 22, 2016 10:10:38 GMT 1
Fantastic work. Well done.
Post by lb on Apr 25, 2016 14:39:29 GMT 1
Steve amazing standard you've set here with this rebuild,finding it hard to read that you'd sell it.....i couldn't do it lol. Just had to say thats the money shot below & have to ask if you could pm me about those clock rubbers please? You have to keep it man..... Also fitted the clocks Steve
Post by midlifecrisisrd on Apr 25, 2016 15:38:48 GMT 1
Thanks for the comments guys
Yes Jason unbelievably I will part with it at some point, it was not planned as a keeper. Done for the challenge and satisfaction of it.
Don't get me wrong it won't be cheap but not making money as you can imagine what the parts bill has been like.
Don't think I could use it and ruin all that nos lol. Going to do my latest lc2 accusition as a standard but usable bike.
Yes I'll pm you the part numbers shortly when I get to my laptop.
Post by midlifecrisisrd on Jun 3, 2016 21:47:51 GMT 1
Been grabbing the odd half hour here and there New inner and outer rims and fixings and finally a UK pattern Koito headlight and new genuine indicators Battery in with the correct leads, NOS band, new strap and the best cover I could find. Its took 3 evenings but finally got some brakes on it. Not very good ones but new pads/second hand discs should bed and improve. Tried everything. Vacuum pump, normal bleed method, reverse bleed. Rear ended up cracking the banjo at the rear master before got any joy out of it. F*cking hate bleeding brakes. All filled with fluids now. Makes a difference on the warm evenings working outside Ready now to fit these Then it will be remote tank and the moment of truth Steve
Post by midlifecrisisrd on Jun 18, 2016 20:20:50 GMT 1
Fitted the pipes and rigged up the remote tank with some premix........... ...........It lives! Fitted the new rad cover, front muddy and tail/grab rail Would have got it finished if the parcel from Fowler's had turned up as it has the fuel tap screws in it. Funny how it sometimes comes next day and sometimes takes 3. Steve
Post by yamark on Jun 18, 2016 21:02:58 GMT 1
Awesome build, I'm going to run out of superlatives for this bike
Great work Steve
Post by fatfastroger on Jun 19, 2016 13:34:57 GMT 1
Looking great , lovely job you've done with it. Pipes look perfect.
