Post by Tobyjugs on Oct 8, 2015 19:40:43 GMT 1
Hi Eyrey Nice creation, are you sure premix is a better lubrication system. Your bottom cylinder is almost upside down. It would be a logical choice to feed oil to the big ends because gravity would pull any large quantity of oil down. This is me thinking out aloud, and would love to know the pro's and con's of the different methods
Post by Eyrey1 on Oct 8, 2015 23:26:59 GMT 1
Post by markhoopy on Oct 9, 2015 13:20:59 GMT 1
I'd been wondering how both carbs fit into such a small space between the V .. It all looks quite lovely.
Post by Eyrey1 on Oct 10, 2015 3:07:48 GMT 1
thanks mark im well happy with it im waiting on a mk2 front end so i can swap it for a mk1 front end as mk2 is better then i can get it properly fixed back in and put the pipes back on and hope the top pipe will be ok in the mk2 rear sub frame Ive just bought for it , so selling all the mk1 stuff i will ring this week and get that top end done for you , is that ok ?
Post by loctite on Oct 11, 2015 17:50:03 GMT 1
This will be great when completed lovely engine top marks
Post by markhoopy on Oct 19, 2015 10:48:41 GMT 1
i will ring this week and get that top end done for you , is that ok ? Yep whenever you want we've had a shift about so the shed is empty and I've got all the bits and a kettle and radio
Post by Eyrey1 on Nov 12, 2015 1:47:31 GMT 1
got a bit more done i can start to bolt everything on to it now and check everything fits and it runs ,then strip it again just orderd another inlet manifold as mine is a bit rough and got 2 nuts and 2 washers today $37 from usa pics look at all that shiney clean ally ! mk2 front end is on engine is sort of back in
Post by markhoopy on Nov 12, 2015 7:58:29 GMT 1
All very shiny indeed
Post by marsbar350 on Nov 12, 2015 15:35:05 GMT 1
too shiny needs some good old powder coat in places
Post by yazza54 on Nov 12, 2015 18:18:01 GMT 1
Sexy. What you expecting it to weigh Gary? Looks a big motor physically but well smart
Post by Eyrey1 on Nov 12, 2015 19:58:01 GMT 1
i dont think it will weigh as much as an lc engine it is big but thin , only as wide as a 250 barrel i will weigh it when its done it should be light its all aluminium/magnesium frame and swingarm etc the mk1 rs250's were 6k new and mk2 7k and full of top parts i dont think the engine will weigh much more if any than the rgv engine it came with im trying to buy 2 more engines at the minute for next projects
Post by 2banger on Nov 12, 2015 21:02:47 GMT 1
must have tools for any bike build , claw hammer and nackered screw driver. Love it
Post by ojay on Nov 12, 2015 21:56:02 GMT 1
That is looking very very special Gary . Top work . Looking forward seeing the remainder of the build thread!
OJ
Post by Eyrey1 on Nov 12, 2015 22:03:29 GMT 1
must have tools for any bike build , claw hammer and nackered screw driver. Love it as used to knock the bottom engine mount bolt into place ! as it happens they are the only tools ive used so far lol front end is only finger tight and thank you for the interest . i will try to get more done this weekend
Post by Eyrey1 on Nov 16, 2015 0:16:37 GMT 1
did a bit more
Post by yazza54 on Nov 16, 2015 10:44:49 GMT 1
Sexy
Post by stevebgt1 on Nov 16, 2015 12:58:16 GMT 1
Cant WAIT to see this finished !!
Post by disruptive on Nov 16, 2015 13:23:38 GMT 1
This makes me wanna buy one of those 130 motors and build one, looks awesome! Those pipes are something else
Post by Eyrey1 on Nov 16, 2015 19:42:21 GMT 1
This makes me wanna buy one of those 130 motors and build one, looks awesome! Those pipes are something else ive got a spare set of engine mounts
Post by pistanbroke on Nov 16, 2015 23:58:06 GMT 1
Gonnae look sweet Gary
Post by Eyrey1 on Nov 17, 2015 0:18:42 GMT 1
hello Donald ! it should look the bollocks when its done ,a long way to go yet im aiming for spring , as can't get the body work or it painted until then so going to get it running first , then nut and bolt it again into bits get it all plastic coated and painted , and do the final build .
Post by muttsnuts on Nov 17, 2015 16:47:45 GMT 1
looking good Gaz, I am sorting that package out for you, should be with me this weekend and then I'll get it sent to you, pm me your address details !
Post by Eyrey1 on Nov 17, 2015 17:24:06 GMT 1
ok
Post by Eyrey1 on Nov 19, 2015 0:23:31 GMT 1
got these today !ultra rare only set i have seen for sale. bimota inlet manifold and a pair of reed stuffers like they say its not what you know its who !
Post by yazza54 on Dec 1, 2015 14:18:57 GMT 1
any progress
tomh
Post by tomh on Dec 12, 2015 18:32:02 GMT 1
very nice build, can wait to hear it running!
Post by Eyrey1 on Dec 24, 2015 2:29:22 GMT 1
yes mate , got new starter motor ,just need to put it on got the zeel wired up just done it with bullet connectors at the minute using a loom adapter so it can all be unplugged and wires swapped if i have problems , but i doubt it as i had someone who knows what he s doing to sort that out need to put oil in the engine throttle cable on , sort the choke from plunger to both on cable put battery on , i bought a std v due battery that weighs 3kg and is massive and had no where to put it really so bought one of those expensive lithium jobs , off a new fireblade 1000 ,it only weighs 480g lol and is tiny and has no liquid in so can be put in upside down if needed power valve motor and cables ,coils and leads and caps and plumb in the new ally rad you told me to buy same as yours it fits perfectly just above top carb ,sort pipes on engine and i can start it then ! cant wait ive orderd body work and i should have it in february and is a bit nice , then take it all to bits again and get frame, swingarm and wheels plastic coated and anything else that doesnt look new .
Post by Eyrey1 on Jan 13, 2016 3:06:25 GMT 1
nearly ready to fire up im hoping this weekend or next
Post by JonW on Jan 14, 2016 1:40:48 GMT 1
exciting times!
Post by yazza54 on Jan 14, 2016 8:18:25 GMT 1
Remember Gary we need pics and videos
