Post by crash on May 23, 2006 22:08:11 GMT 1
???can any one please tell me if removing the reed valve stopper plates{cutting off} will aid more, safe flow to my lc125 motor, as i have seen several reed blocks for sale with these removed?
Post by Norbo on May 24, 2006 8:21:10 GMT 1
As above mate. You wont get any more power and it just mite weeken the pettels and if they brake its going to cost you a lot to fix the engin when they brake and go up the cylinder. If its more safe power you want, you need Racing reeds, lightened fly wheel, after market pipe, skimed head, 1 tooth down on the front sprocket. You will knotice a good diference with that lot .
Post by Norbo on May 24, 2006 8:21:27 GMT 1
And welcome he he he
Post by pablo on May 24, 2006 15:57:15 GMT 1
metal reeds can fatigue and fail,causing damage to the motor,the fibre ones are less likely to do any damage if they get in there...the stops are there for a reason,to stop 'flutter'...you can raise the stops slightly to gain a bit of lift or gently increase the curve...reeds also have a life expectancy...they dont last forever...more lift,shorter life.without the stops you may find they dont work as well...
Post by jacobeana on May 24, 2006 21:28:43 GMT 1
I would not remove the stops the reeds will brake
Post by Norbo on May 25, 2006 18:39:26 GMT 1
I bend my'n back untill i can here them tuching the sides at i put the block back in but never remove them .
von
Post by von on Aug 13, 2006 14:25:34 GMT 1
Hi what reeds u guys use now we used to use Hitecks or boysons.as the host says we bent the stops right back.what the view on these two reeds??Are there any better ones on the market ???Are there any carbon ones out there if so how do they act??
Post by Norbo on Aug 14, 2006 11:54:32 GMT 1
Any after market reeds are better them sdtandard ones . You can get carbon ones i stock them as well as the standard fiber ones .
von
Post by von on Aug 14, 2006 19:00:21 GMT 1
Hi Norbo you sorted out the price for them bits we talked about??
Post by Norbo on Aug 14, 2006 19:14:23 GMT 1
I sent a mail i asoom you didnt get it . I was wondering why you didnt get back to me .
You will have to remined me what the list was now .
I still have the swinger parts price , but cant remember the rest
von
Post by von on Aug 14, 2006 19:22:22 GMT 1
Hi m8 full swinger set including chain rubber. tapered head set and hold the fork stantions might get a new gen yammy set for 80 quid my m8 knows he got a set just cant find the buggers.Remember MK1.you still want them TZ bits??Talking about carbon reeds how do they go?? ive never used em before.Are they thinner if so do you get flutter with them with the stops RIGHT back ??
von
Post by von on Aug 14, 2006 19:36:50 GMT 1
Just remembered we run our 250lc without stops but bonded a piece of tunstan wire to the petals this worked great and no flutter we used Hiteck reeds but it was over 20 years ago.i have just found them so they didnt break.But i can say they worked great but we got done with em Proddy racing 8-)as you do.
Post by pablo on Aug 15, 2006 15:16:25 GMT 1
like to see a piccy if you can manage it von
von
Post by von on Aug 16, 2006 19:07:25 GMT 1
Hi Pablo.Ill try at sort it soon m8.Looking at them now they look as good as new.We had lots of trouble with getting the wire to say on and move as the reeds.Im not going to tell you what we used and how we did it but take it from me many a petal went through the bench engine ;D.I think we must of spent 6 months plus sorting it all out.My wife came up with the answer as a non tec head and it was so simple {the bitch}we never heard the last of it for ages LOL.
Post by pablo on Aug 16, 2006 19:14:23 GMT 1
;D ;D ;D...im even more intrigued now
von
Post by von on Aug 16, 2006 22:23:00 GMT 1
Pablo as Email ;D
Post by mellow on Aug 16, 2006 22:25:53 GMT 1
post em ere for the rest of us then ;D
von
Post by von on Aug 16, 2006 23:35:45 GMT 1
Can do but ive got to get a copywright 1st ;Dwhen done will post as many pics as you want Von
