Post by proam350 on Sept 15, 2014 20:16:46 GMT 1
Hi all I have a 1980 lc350 she cracks the header pipes all time even later type 2 pipes had a set of swarbricks on as well but they wore out on flange fittings bad vibes as well fitted new engine damper mounts still no better tryed to find a later frame with tie bars or scrap frame with tie bar brackets fitted any one any ideas pls
Sent from my iPhone using Tapatalk
Post by Delbert on Sept 15, 2014 20:33:33 GMT 1
There is a mod you can do to the rear mounting ,, I done mine ... iirc you remove the steel dowl from the rubber bush & cut it down ,, I got 5mm in me head but stand to be corrected
Post by Tone on Sept 15, 2014 21:18:08 GMT 1
Found an old Yamaha Service Bulletin that was sent out to dealers ref RD250/350LC Exhaust Gasket Leakage and it suggests to cut the metal collar in the rear rubber mount from 22mm down to 20mm.
Post by Delbert on Sept 15, 2014 21:53:14 GMT 1
Found an old Yamaha Service Bulletin that was sent out to dealers ref RD250/350LC Exhaust Gasket Leakage and it suggests to cut the metal collar in the rear rubber mount from 22mm down to 20mm. There you go proam350 2mm not 5 .. cheers Tone
Post by 4l04ever on Sept 15, 2014 23:13:31 GMT 1
If the vibration is excessive, it could be the crank or flywheel are out of balance, or the crank could be out of true.
Post by proam350 on Sept 16, 2014 0:44:24 GMT 1
No motor had a full rebuild
Post by steven on Sept 16, 2014 0:52:24 GMT 1
Hi, As has already been said above, there was a Yamaha Service Information buletin about cutting the collar in the exhaust hanger, I called them "top hats" but im not sure of their correct name off hand. I cut my top hats too, by the reccomended amount. I was sure I had it on my PC amoungst some of the other ones, but cant find it just now, it is on the net somewhere im sure. Here are the other ones I have regarding the exhausts. steven.
Post by proam350 on Sept 16, 2014 14:23:22 GMT 1
Thanks lads will try mod on rear mounts see how that goes if not check crack for trueness
Post by shane250 on Sept 16, 2014 19:59:31 GMT 1
how do you check for trueness?
Post by shane250 on Sept 16, 2014 20:19:00 GMT 1
over my head i think.thanks
Post by slinger on Sept 17, 2014 21:02:26 GMT 1
Like pointed out could be the crank, or how was the clutch assembled? where the steel plates fitted correctly.
Post by midlifecrisisrd on Sept 17, 2014 21:12:20 GMT 1
You say you changed the rubber mounts, do you mean the ones pressed into the cases.
Did you replace the disc ones that fit on rear right and front left. I take it they are on lo as well as ypvs. Some fit 4 of them.
