Post by midlifecrisisrd on Oct 7, 2014 8:01:51 GMT 1
I don't have a template, I just got a bit of 10mm plate, held it against the rgv hanger and traced found it before getting an engineering shop to cut it.
When I get the final spacers made while it is off I will draw round it on a bit of card then I can post it down to you.
Post by deanord on Oct 10, 2014 7:19:05 GMT 1
Cheers Steve,
Bandit 400 sprocket carrier arrived yesterday - not had chance to check it over but defo looks thinner!
The Mrs has now decided decorating the louge has priority... AAAARRRGGHHH!
One day i may even get it finished!
Post by deanord on Dec 14, 2014 19:12:51 GMT 1
Steve, got the bandit 400 sprocket carrier in place - fits really well and corrects the chain line nicely! almost there now! apart from the fact that muppet features here chopped the spacer down that goes between the caliper carrier and the wheel bearing.. any chance you could get me some measurements off your spacer please (the original suzuki one)? only really need the width - i can guestimate the rest.. will be getting one made as i cant find any on ebay at all - unless someone has one kicking around? ? almost there.... cheers Jon
Post by midlifecrisisrd on Dec 14, 2014 19:47:29 GMT 1
Steve, got the GS500 sprocket carrier in place - fits really well and corrects the chain line nicely! almost there now! apart from the fact that muppet features here chopped the spacer down that goes between the caliper carrier and the wheel bearing.. any chance you could get me some measurements off your spacer please? only really need the width - i can guestimate the rest.. will be getting one made. almost there.... cheers Jon Should it not be the bandit400 carrier? Not got a spacer out to check and bike is in vac bag. It is the same as the Rgv one, I bought a full alloy set for mine from eBay. You can buy them there or the tuning works site. The carrier bracket is 30mm so you may be able to get it from that. I also fitted a seal on the rh side of the wheel bearing Steve
Post by midlifecrisisrd on Dec 14, 2014 19:49:33 GMT 1
Sorry but should have sain the gsxr rh spacer is the same width but with a flange.
I fitted the Rgv one hence the seal was fitted.
Post by deanord on Dec 14, 2014 21:57:06 GMT 1
Yep - my mistake - Bandit carrier NOT GS!
think i'm going to have to buy a set of spacers or a genuine one from Suzuki as OEB says. Seen them on Ebay for £30 - may well be cheaper than genuine!
cant wait to have this sorted.. then i can put a chain on it for the first time in 6 years!
Cheers all!
Post by deanord on Dec 24, 2014 8:32:45 GMT 1
So, to retain suzuki parts you have to have a right hand rear wheel spacer made that is 6mm wider than standard, and remove 6mm from the right hand side of the caliper mounting, with 3mm taken off the lug on the inside of the swingarm that stops the caliper holder rotating.
I'll post a pic once i have it made, and after i work out how to post a pic on here!
Merry christmas all!
Post by deanord on Feb 1, 2015 21:48:41 GMT 1
Finished!
had a new RH inner spacer made 6mm longer than standard, the had 6mm machined off the outer edge of the caliper carrier to align the caliper over the disc. This presented the final proble with the locating lug for the caliper carrier - i nipped 3mm off this, the ground back the shoulder of the tab to allow the carrier to fit on and be perpendicular to the axle. Result!
Now, rear sprockets - steve- how are you getting on with your 41T rear? JonW - have you tried the 38T in anger yet?
I've just ordered a 41T Talon from Dennis trollope racing, but wonder if on a standard engine it would work well on fast roads? Obviously its going to be on 17" rims too! my feeble brain cant work out the counteracting effects of more teeth on the rear versus smaller diameter rim - effectively cancelling out each other - ish..
Post by midlifecrisisrd on Feb 1, 2015 22:20:24 GMT 1
had a 41t with the Rev set up and it topped out about 115 at red line in top.
Kept the 41t set up with the gsxr as using a 70 profile tyre, not had it on the road since, only on the dynamic but should be 120 now.
It is great on the road other than on the motorway where 70 is around 6k
I do have a 39t to try. Very cheap option as the gs500 is 39t 520 as standard.
Post by jon on Feb 7, 2015 12:44:19 GMT 1
Jon, good to hear you got it sorted now.
Steve, where did you get those chain pulls, I have been looking for some time.
Post by midlifecrisisrd on Feb 7, 2015 12:57:56 GMT 1
Jon, good to hear you got it sorted now. Steve, where did you get those chain pulls, I have been looking for some time. Was long time ago from the old Rd forum. Think someone made a batch. Think somethingelsie on here did the adjusters nuts. Nk racing and rgv250.com do other ones Steve
Post by jon on Feb 7, 2015 13:46:16 GMT 1
I've seen the NK racing ones, but would have preferred the ones you have.
On a slightly different note, how did you know where to position the caliper?
It easy on a duel opposed piston to work it out, but not on a floating one.
Did you know the distance between the metal carrier and the disk from a standard RGV?
Post by midlifecrisisrd on Feb 7, 2015 13:55:12 GMT 1
I've seen the NK racing ones, but would have preferred the ones you have. On a slightly different note, how did you know where to position the caliper? It easy on a duel opposed piston to work it out, but not on a floating one. Did you know the distance between the metal carrier and the disk from a standard RGV? I did measure an rgv wheel but double checked by making the hanger plate out of 10mm plate the fitting everything and measuring the spacer sizes the fitting them th the plate with roll pins. Plate was made by simply drawing round the original carrier Steve
Post by jon on Feb 7, 2015 13:57:50 GMT 1
What is the distance between the steel floating plate (not the alloy spacer) and the disk with new pads in.
Post by midlifecrisisrd on Feb 7, 2015 14:27:33 GMT 1
It is only 1-2 mm from the disc bolt heads
Not a lot of space.
Post by deanord on Feb 7, 2015 15:40:27 GMT 1
i guessed... measured the width of the aperture on the caliper divide by 2, then position the caliper.. measure.. looks right ;-)
Post by loudpipes on Feb 28, 2015 16:41:00 GMT 1
Good info here fellas, im doing this conversion at the moment, have any of you got any sizes of wheel spacers to use, i keep reading this thread and get mixed up every time at the moment i have a gk76 rear wheel and bandit 400 carrier. cheers.
Post by midlifecrisisrd on Mar 1, 2015 0:25:06 GMT 1
Good info here fellas, im doing this conversion at the moment, have any of you got any sizes of wheel spacers to use, i keep reading this thread and get mixed up every time at the moment i have a gk76 rear wheel and bandit 400 carrier. cheers. The standard rgv and gsx spacers are the same width so either will do. I used one of the alloy rgv kits off eBay Steve
Post by loudpipes on Mar 1, 2015 8:01:52 GMT 1
Cheers i will get a set ordered have you got any pics of the wheels finished in the bike. what gearing and tyre sizes are you using now. thanks
Dave
Post by midlifecrisisrd on Mar 1, 2015 12:14:45 GMT 1
Cheers i will get a set ordered have you got any pics of the wheels finished in the bike. what gearing and tyre sizes are you using now. thanks Dave Pics of wheels fitted in the finished build section under "385 ypvs" I have 2 wheel/tyre/sprocket options. 1st is a gk76 wheel (4.5 rim) with a 150/60 2nd is a 400 bandit wheel (4 inch rim ) with a 140/70 One sprocket carrier is bandit 400 with a gs 500 39t steel sprocket and the other is a machined down gk76 carrier with a 41t alloy sv650 race sprocket The gs ones are cheap as chips Steve
Post by loudpipes on Mar 1, 2015 17:22:17 GMT 1
Thanks may try and fit the gk76 (3.50) front aswell have you looked into this?
Dave
Post by midlifecrisisrd on Mar 1, 2015 17:36:00 GMT 1
Thanks may try and fit the gk76 (3.50) front aswell have you looked into this? Dave Gk76 front is same as vj22 Have an early bandit front in mine just now but needed different bearings, spacers, disc spacers and the wheel modded at the speedo drive Steve
Post by loudpipes on Mar 1, 2015 17:53:33 GMT 1
Thought that was the case but read on other forums rgv were 3.00 front. cheers.
Dave
Post by dangerousal on Sept 29, 2016 22:38:25 GMT 1
This is really useful info, can I just check gk76 rear wheel with 400 bandit carrier will fit a vj22 swing arm giving same sprocket offset as the vj22 wheel?
Post by midlifecrisisrd on Sept 30, 2016 9:39:42 GMT 1
This is really useful info, can I just check gk76 rear wheel with 400 bandit carrier will fit a vj22 swing arm giving same sprocket offset as the vj22 wheel? Yes this is correct Just the brake carrier to sort Steve
Post by dangerousal on Sept 30, 2016 10:26:24 GMT 1
This is really useful info, can I just check gk76 rear wheel with 400 bandit carrier will fit a vj22 swing arm giving same sprocket offset as the vj22 wheel? Yes this is correct Just the brake carrier to sort Steve Brilliant thank you!
Post by dangerousal on Dec 25, 2016 15:53:10 GMT 1
So i now have the vj22 swing arm, gsxr 400 rear wheel, and bandit sprocket carrier, had to machine out the sprocket carrier inner spacer to fit the vj22 swing arm, so now i am going to order the bolt on kit from NK racing and begin work on the back end...anyone have any experience on these kits?
Post by dangerousal on Sept 19, 2017 22:10:34 GMT 1
Hi I have mine all together...I have a question, how many links in the chain with sv rear sprocket setup?...also what size chain?..i have a 160 on the rear wheel and a tiny amount of chain clearance...
Post by midlifecrisisrd on Sept 20, 2017 8:20:59 GMT 1
Buy a 120 chain and cut to size mate
Post by spacejunkie on Nov 23, 2017 21:43:34 GMT 1
Is there anyway some of the pictures could be put back up using flicker on this thread I am hoping to do this mod in the future would help a lot if the pictures were on.
