Post by botty on Feb 27, 2017 0:02:31 GMT 1
That's what I've got. Well, they are direct copies, I have put genuine needle, main , and pilots jets in them.
Post by Yogi on Mar 19, 2017 20:34:17 GMT 1
Quick update I spent Saturday getting it running and ready for an mot seeing as the 385 lump won't be done in time for the Southend shakedown Then today I decided to start building the 385 As usual I started by replacing the selector shaft bush for the longer type Then an upgraded bearing for the gear drum Replaced the gear shaft bearings Gen yam crank seals a must One last look at the 4mm hot rods crank And the cases are bolted together Needed a break from the n1 Matt
Post by Yogi on Mar 19, 2017 20:45:12 GMT 1
Lol,forgot the last pic Matt
Post by yamark on Mar 19, 2017 20:59:16 GMT 1
Looking bloody awesome Matt. That crank looks the dogs danglys , great work as ever
Post by dusty350 on Mar 19, 2017 21:11:29 GMT 1
+1 on that Looking really good Matt. Dusty
Post by Tobyjugs on Mar 20, 2017 15:53:39 GMT 1
I like that base gasket. Thats a sensible approach
Post by Yogi on Mar 20, 2017 16:12:15 GMT 1
+1 on that Looking really good Matt. Dusty Can't compare with the work you've done on the lc lump but I'm doing my best Matt
Post by Yogi on Mar 20, 2017 16:13:56 GMT 1
Looking bloody awesome Matt. That crank looks the dogs danglys , great work as ever Cheers mate The crank is the smoothest I've ever known,hardly any friction at all Matt
Post by Yogi on Mar 20, 2017 16:15:21 GMT 1
I like that base gasket. Thats a sensible approach Definitely no overlapping on this one Matt
Post by spudmab on Mar 20, 2017 17:00:04 GMT 1
Lol,forgot the last pic Matt Just out of interest what do you use to seal the cases,
Post by lrcarl on Mar 20, 2017 18:09:31 GMT 1
I like that base gasket. Thats a sensible approach Definitely no overlapping on this one Matt Base gasket looks spot on mine very thin between cylinders were crankcase Has been ported Carl
Post by Yogi on Mar 20, 2017 18:53:45 GMT 1
Definitely no overlapping on this one Matt Base gasket looks spot on mine very thin between cylinders were crankcase Has been ported Carl I must admit I was pleased when it was a single gasket Matt
Post by lrcarl on Mar 20, 2017 18:58:00 GMT 1
Where did you get it Martin? Carl
Post by Yogi on Mar 20, 2017 19:02:44 GMT 1
Where did you get it Martin? Carl Yes mate it was Martin at Mb-designs Matt
Post by lrcarl on Mar 20, 2017 19:08:18 GMT 1
Cheers Matt
Post by 1966baz on Mar 21, 2017 19:03:00 GMT 1
Looks great Matt, keep up the good work.
Post by Yogi on Mar 21, 2017 23:21:57 GMT 1
Looks great Matt, keep up the good work. Thanks for the encouragement mate I will hopefully do it justice Matt
Post by mouse on Mar 22, 2017 8:25:45 GMT 1
Yogi, this looks really exciting, which bike is this engine going in?
Mouse
Post by Yogi on Mar 22, 2017 8:45:50 GMT 1
Yogi, this looks really exciting, which bike is this engine going in? Mouse Thanks mate It's going in the red and white hybrid in the background Matt
Post by mouse on Mar 23, 2017 8:33:03 GMT 1
Yogi, this looks really exciting, which bike is this engine going in? Mouse Thanks mate It's going in the red and white hybrid in the background Matt Excellent! Can't wait to see it done Mouse
Post by Yogi on Mar 25, 2017 19:07:21 GMT 1
Well the bike is now ready for an mot with the original engine in for now As for the 385 engine I've put a Mitaka basket,new dampers,power plates and H/d springs Rebuilt the valves,forged pistons and a wicked head Just waiting on a 50c thermostat and spacer Done a leak test and typically for me the only thing leaking is the leak kit Matt
Post by spudmab on Mar 25, 2017 19:26:03 GMT 1
Looking very nice, quality parts used, should fly
Post by Yogi on Mar 25, 2017 19:30:58 GMT 1
Lol,forgot the last pic Matt Just out of interest what do you use to seal the cases, Sorry mate just noticed this post The stuff I use is called Wellseal ,I think I got it from Norbo a couple of years back Haven't had any problems with it Matt
Post by Yogi on Mar 25, 2017 19:33:11 GMT 1
Looking very nice, quality parts used, should fly Cheers mate I'm hoping it goes well Matt
Post by Tobyjugs on Mar 25, 2017 20:41:27 GMT 1
Those Wicked heads look great
Post by dusty350 on Mar 25, 2017 21:14:11 GMT 1
Engine looks awesome Matt, great work Those Wicked heads look... well....Wicked Dusty
Post by wallcraft on Mar 25, 2017 21:29:44 GMT 1
Well the bike is now ready for an mot with the original engine in for now As for the 385 engine I've put a Mitaka basket,new dampers,power plates and H/d springs Rebuilt the valves,forged pistons and a wicked head Just waiting on a 50c thermostat and spacer Done a leak test and typically for me the only thing leaking is the leak kit Matt I had that problem as well, mine leaked from the exhaust blanks, had to tighten the exhaust studs far to tightly for my likening. Where was yours leaking? Mark.
Post by Yogi on Mar 25, 2017 21:36:11 GMT 1
Cheers Tobyjugs and Dusty I'm well happy with the Wicked head,nice bit of bling
Hi Wallcraft mine are both leaking past the shreider valves in the inlet blanks Trying to work out the best way to seal them
Matt
Post by Tobyjugs on Mar 25, 2017 21:54:27 GMT 1
Try some latex fluid that they use in mountain bike tubes. Just brush a bit around the valve and pressurise it. I have used "Tyre Juice" In my LC wheels without inner tubes
Post by Yogi on Mar 26, 2017 14:22:07 GMT 1
Try some latex fluid that they use in mountain bike tubes. Just brush a bit around the valve and pressurise it. I have used "Tyre Juice" In my LC wheels without inner tubes Cheers mate I'll give it a go Matt
