robw
Post by robw on Feb 16, 2014 10:16:53 GMT 1
Hi, Cadwell Park beginning of August, Spa beginning of July. Plus others run by Classic trackdays and No limits. Rob
Post by 1966baz on Mar 29, 2014 23:20:38 GMT 1
Grunt, the 33mm CRS were running 125 mains and needle position was 2nd from top. This worked fine with the GPZ 1170 with big valves and polished out inlets and exhaust ports. Hope tis helps.Cheers Nick.
Post by 1966baz on Aug 1, 2017 12:30:05 GMT 1
Hi everyone Aquick uodate as photo bucket is not working now.
Post by 1966baz on Aug 1, 2017 12:31:31 GMT 1
Hope this works .Up date of the Zed
Post by Haggler on Aug 3, 2017 21:23:52 GMT 1
Looking good there
Post by headcoats on Aug 5, 2017 19:49:27 GMT 1
Nice
I have those carbs on my 2002 Bonneville but 35mm version 58 pilots, 122 mains and needle on 4th from top clip
You must be the Hulk to pull the throttle , pulling 4 carbs !
Post by spondon440 on Aug 6, 2017 20:36:12 GMT 1
Hi Rob, Did Kip supply you with those yokes? I used to make most of his stuff but he has been ill which forced him to wind up his business and I haven't seen him since, you heard anything about how he is? Andy My ELR getting ready for the upcoming track days Rob
robw
Post by robw on Aug 7, 2017 13:31:26 GMT 1
Hi Andy, I did get a set of him for my endurance bike, a couple of years ago. As far as I am aware, Alan suffered from a heart attack last year and has to give up work. Really sad as I had met him a couple of times and he helped me with some set up problems and he was always really helpful and a genuinely a nice guy. Rib
Post by spondon440 on Aug 7, 2017 21:26:59 GMT 1
Yea, top bloke, carrying a very lot of lumber though, holding down a full time job and doing bike bits till all hours of the night whilst eating stress morning noon and night, a recipe for disaster, no one has seen him anywhere though which is a worry.
I have some parts if you know of anyone in the market.
Nice bike though Rob.
Andy
robw
Post by robw on Aug 22, 2017 20:54:59 GMT 1
Andy, if you let me know what parts you have I can put them on the Z1OC website, to see if anyone wants them. Very sad to see Alan go like this, he was extremely helpful and when I chatted to him always a nice guy. Rob
will27
Post by will27 on Sept 12, 2017 22:33:34 GMT 1
Just bought a z1000j in Lawson colours π No where near the standard of yours but will work on it π
Post by 1966baz on Sept 13, 2017 18:03:53 GMT 1
Just bought a z1000j in Lawson colours π No where near the standard of yours but will work on it π Cheers, enjoy your big Zed, they will always look cool.
will27
Post by will27 on Sept 13, 2017 20:49:23 GMT 1
Bought a gs 1000 as well going to get them both up and running properly then compare them the gs has got the noisy clutch issue π
Post by spondon440 on Sept 30, 2017 21:52:32 GMT 1
Hi Rob, Took me a while to get this all together but here goes: I have three sets that are 210mm hole centre x 39mm fork clamp and one set that are 210mm hole centre and 43mm fork clamp, they would be supplied with the steel stem fitted. I'm after Β£300 a pair for them because I want to get rid of them. I did quite a lot of parts for Kip so if anyone is stuck for information I may be able to help. Regards Andy
robw
Post by robw on Oct 1, 2017 21:52:16 GMT 1
Hi Andy, if you pm me contact details I will put them on a couple of sites if that's ok. Rob
robw
Post by robw on Oct 1, 2017 22:02:57 GMT 1
will27
Post by will27 on Oct 2, 2017 21:32:19 GMT 1
Has anyone got good fuel tap for z1000j and the clamps for carbs to inlet rubbers π
robw
Post by robw on Oct 3, 2017 6:58:58 GMT 1
Will, use a Pingel fuel tap, I get mine from Grumpy 1260 performance spares and the carb clamps you can get from Cradley Heath Kawasaki. I will find the part number for you. Rob
will27
Post by will27 on Oct 5, 2017 21:43:29 GMT 1
Cheers Rob mine has new inlet rubbers but jubilee clips and air leak , I think the jubilee clips are to wide and not making good seal does the pingel tap have reserve π
robw
Post by robw on Oct 5, 2017 21:54:51 GMT 1
Pingel come in different types, you can have twin or single oulet and with or without reserve.This is the number for the clamps of a z1000j which i think is the same as the ones you need. 92037201 Rob
will27
Post by will27 on Feb 18, 2018 21:49:32 GMT 1
Working on my ELR project I need fairing and square headlight assembly brackets etc anyone got any leads or contacts been searching eBay etc for months
Post by bigkenx on Jul 10, 2019 14:42:53 GMT 1
Post by bigkenx on Jul 10, 2019 14:44:31 GMT 1
Had this a while needs to be out more always a trick to starting one massive carb
Post by 1966baz on Aug 27, 2019 11:58:28 GMT 1
Nice one Iigkenx. Sorry I haven't a fairing.
robw
Post by robw on Aug 30, 2019 7:28:04 GMT 1
Skidmarks do the fairings. Headlights you can get as patterns. I made up a couple of brackets for the fairing out of sheet metal. Also join the Z1OC for advice and parts. Rob
Post by 1966baz on Oct 30, 2019 18:41:19 GMT 1
Here it is.
Post by 1966baz on Oct 30, 2019 18:57:40 GMT 1
Bought about 8 years ago. All the importmant bits are stashed in the loft. One the the GPZ aswell, as photobucket is playing up. The last one was 22 years ago when I build her.
Post by bigkenx on Mar 2, 2020 6:15:28 GMT 1
I thought mine was a gpz b3 but looked at the log book and itβs a z1100 r1 result
Post by bigkenx on Mar 2, 2020 6:56:06 GMT 1
Bought about 8 years ago. All the importmant bits are stashed in the loft. One the the GPZ aswell, as photobucket is playing up. The last one was 22 years ago when I build her. Really like that fella , flatsides beasts
