Post by brownsauce on Nov 6, 2013 16:37:48 GMT 1
I need to reprint my 250lc exhausts, just wondering what paint is best for standard finnish. Last time I did them I used some paint from yambits which looked really good untill I used the bike then it went patchy. Any ideas?
Post by arrow on Nov 6, 2013 16:52:09 GMT 1
Post by brownsauce on Nov 6, 2013 16:59:15 GMT 1
Thanks looks good , have you used them? What they like price wise?
Post by arrow on Nov 6, 2013 17:02:30 GMT 1
Two week turn around. £160 plus vat for complete job (but I took mine there as only 20 miles away). Good for 1000 degrees C headers still like new. Its a long lasting finish.
Post by rich on Nov 6, 2013 17:03:54 GMT 1
Thanks looks good , have you used them? What they like price wise? Prices are on their website and don't look that bad. Anyone know if they can coat expansion chambers that have been used?
Post by arrow on Nov 6, 2013 17:09:38 GMT 1
They bake the pipes first before application of the coating. No worries if oil is in them. They do exhaust manifolds for cars to so I think not a problem with your expansions, give them a call. Decent helpful bloke on the end of the phone too.
phil38
Post by phil38 on Nov 6, 2013 20:47:10 GMT 1
Plastikote BBQ paint works well. Needs curing within 8 hours. I did mine like this (after de-cokeing!)
Post by brownsauce on Nov 6, 2013 23:11:24 GMT 1
Plastikote BBQ paint works well. Needs curing within 8 hours. I did mine like this (after de-cokeing!) Cheers mate, how many cans did you use?
jools
Post by jools on Nov 7, 2013 11:04:28 GMT 1
I used this ceramic engine enamel from Duplicolour as a trial on my RZ pipes. Also used it on engine cases. The semi matt is nice and the gloss isn't too shiny either www.duplicolor.com/products/enginePaint/
Post by shaunthe2nd on Nov 7, 2013 15:35:23 GMT 1
We have a powder coating paint line at work. Occasionally we do a run on black. I've been thinking about putting my LC pipes through it sometime.
Do you think a powder paint finish will be heat resistant, particularly for the down pipes?
Post by looey on Nov 7, 2013 15:49:19 GMT 1
I've learnt the hard way and through experience that the Plasticote BBQ paint either needs to be cured withing the 8 hours or left for several weeks before running up to temperature on the bike. If you don't either cure it straight away, or leave it a few weeks, it will bubble and blister just like any other non heat resistant paint . I usually paint my exhaust when I'm not going to be using the bike for a few weeks and the paint stays perfect The heat gun is a good idea though, as longs as it doesn't catch fire and burn the Garage down.....
adz
Post by adz on Nov 7, 2013 21:26:43 GMT 1
Hi what type of temp and time to cure BBQ paint?
Post by brownsauce on Nov 9, 2013 9:28:50 GMT 1
Thanks guys, I think I'll try the plastikote this time, I'll let you know how I get on.
Post by Ragger rd on Nov 9, 2013 9:53:11 GMT 1
I had my pipes powder coated,bloke said would be fine and would not come off or bubble as they melt after 300 degrees of heat ,don't no how much heat comes off a running bike
Post by shaunthe2nd on Nov 9, 2013 11:58:29 GMT 1
I had my pipes powder coated,bloke said would be fine and would not come off or bubble as they melt after 300 degrees of heat ,don't no how much heat comes off a running bike Do they still look good after use? Do you know what they did to prepare the pipes before powder coating? Cheers
phil38
Post by phil38 on Nov 9, 2013 15:23:52 GMT 1
Cheers mate, how many cans did you use? I think it took nearly two cans with lots of thin coats
phil38
Post by phil38 on Nov 9, 2013 15:25:00 GMT 1
I had my pipes powder coated,bloke said would be fine and would not come off or bubble as they melt after 300 degrees of heat ,don't no how much heat comes off a running bike Do they still look good after use? Do you know what they did to prepare the pipes before powder coating? Cheers Exhaust temp is way above 300deg!
Post by Eyrey1 on Nov 9, 2013 15:32:58 GMT 1
I had my pipes powder coated,bloke said would be fine and would not come off or bubble as they melt after 300 degrees of heat ,don't no how much heat comes off a running bike im sure its 7-800 deg at the top of the headers
Post by chippy348 on Nov 14, 2013 0:41:09 GMT 1
I have used Dupli-color supertherm with good results, but with painting exhausts i have found prep is key and not laying to much on, build up the layers slowly.
hrc43
Post by hrc43 on Nov 14, 2013 20:51:47 GMT 1
ive used pj1 fast black in the past and got good results and its cheap and does up to 816 degrees as you can see from my avatar they used to do it in yellow but i dont know if there is a call for it anymore
Post by spencerd on Nov 15, 2013 22:42:13 GMT 1
BBQ paint!
jools
Post by jools on Nov 26, 2013 10:55:39 GMT 1
I don't know if this is true, but while in the UK recently (got back this morning) I visited several B&Q stores to get some Plasticote Satin BBQ paint. Not one of them had any. As a final resort I tried Homebase with the same result and to be told by the assistant that they are no longer making it What gives ? everytime a decent paint is found they stop making it !!!!
Post by Roofmonster on Nov 26, 2013 10:59:23 GMT 1
I wonder if they have just stopped stocking it during the winter months due to people not using their BBQs ect. Halfords are still stocking the Hammerite BBQ paint - I've not used it but it can't be much different from the B&Q stuff.
Post by shaunthe2nd on Nov 26, 2013 11:00:51 GMT 1
Post by shaunthe2nd on Nov 26, 2013 11:06:18 GMT 1
higgsy
Post by higgsy on Nov 26, 2013 12:06:52 GMT 1
I've used the Techcote Satin black that Busters and M&P sell, couldn't find the B&Q, Wilkos or Plasticote BBQ paint anywhere! Seems pretty good, gives a nice finish but you need to build it up in layers, cured it with a hot air gun so we'll see how it lasts
Post by rdcaferacer on Nov 26, 2013 17:18:30 GMT 1
Hi,
I also used the head gut to "burn" the paint in... It´s a good method!!
Peter
Post by brownsauce on Nov 27, 2013 10:43:24 GMT 1
One down one to go, looks good so far first time using plasti kote bbq paint I'm impressed
Post by shaunthe2nd on Nov 27, 2013 11:01:24 GMT 1
One down one to go, looks good so far first time using plasti kote bbq paint I'm impressed Not sure how my H&S guy at work would perceive this! Lol. Looks good though. Did you de-coke them first? I've just bought some Hycote VHT paint and going to give that a go on a sample piece of tube first. We have a big oven at work as part of our paint track, so going to put the pipes in there to cure once i get round to painting them. I think i'm going to decoke with caustic soda first though.
Post by brownsauce on Nov 27, 2013 11:15:45 GMT 1
One down one to go, looks good so far first time using plasti kote bbq paint I'm impressed Not sure how my H&S guy at work would perceive this! Lol. Looks good though. Did you de-coke them first? I've just bought some Hycote VHT paint and going to give that a go on a sample piece of tube first. We have a big oven at work as part of our paint track, so going to put pipes in there to cure once i get round to painting them. I think i'm going to decoke with caustic soda first though. Yeah decoked them with the heat gun steamed to work ok, stand back I had flames shooting out. I did the same tried it on a piece of tube first. Not sure what they would say at work if they new what I was doing eather, but only 2 of us here today and the other one is my dad so we'll be ok.
