Post by Shytalk on Mar 18, 2006 10:39:03 GMT 1
Post by Norbo on Mar 18, 2006 12:58:46 GMT 1
Bloody hell . You have your work cut out dont you . you will have a lot to do but when its finished you can say you did it all. Its the sence of acheavment that i like when i finish a bike . Makes it more yours then just buying it , if you know what i meen
Post by jacobeana on Mar 18, 2006 18:08:27 GMT 1
I started a project very much the same, nearly complete now, well worh the effort
Post by Norbo on Mar 19, 2006 10:44:08 GMT 1
Your right . The sence of achevment when its all done makes it worth while.
Post by Shytalk on Mar 19, 2006 13:07:17 GMT 1
It did run before I bought it, but it had stood outside for a couple of years, the fuel lines had perished, so starting it up had petrol pi**ing all over the place!!! To be honest it does look bad initially but I think its basically sound just needs completely rebuilding I have got another tank for it, all the panels, fairing, belly pan, clocks, lights ..... the list is endless if I think about it I'm waiting for the weather to warm up a bit then I'll strip it down, I did the rear caliper last week when I took these pictures.... anyone got any caliper pistons in good nick??
Post by gaz1971 on Mar 19, 2006 20:08:56 GMT 1
i spent over 12 years adding bits and changing others but as time goes on you will get it how you want along as you are patient mate. gaz.
Post by scott on Mar 19, 2006 21:21:09 GMT 1
it's good to know someone's goin threw the same as me,good luck mate,we need to get these great bikes back on the road.take alook at my 3 projects in the hybrid page.
Post by scott on Mar 23, 2006 21:16:55 GMT 1
it's not to bad, mainly cosmetic 31k pv, good luck with it
