norbo
Mar 6, 2006 18:40:18 GMT 1
Post by ozzy on Mar 6, 2006 18:40:18 GMT 1
andy do you do the middle barrel link connector for the powervalves? as i see you do the rubbers. cheers oz
norbo
Mar 7, 2006 19:14:25 GMT 1
Post by Norbo on Mar 7, 2006 19:14:25 GMT 1
Are you missing yours or is it just worn.
norbo
Mar 8, 2006 2:54:11 GMT 1
Post by ozzy on Mar 8, 2006 2:54:11 GMT 1
for the rebuild looks like the pv end as dug into it just will add to my list i intend to hit you with later. cheers oz
norbo
Mar 8, 2006 13:57:35 GMT 1
Post by Norbo on Mar 8, 2006 13:57:35 GMT 1
They are all worn theys days . You can put a bit of silicone on the one you have and put a bit cut of a drinks can in the bit that clamps the valves and that will fix it and keep it tite.
norbo
Mar 8, 2006 22:58:56 GMT 1
Post by ozzy on Mar 8, 2006 22:58:56 GMT 1
cheers m8 may be a idea for another page / tips- page ! tip of the day- lol
norbo
Mar 8, 2006 23:19:20 GMT 1
Post by jacobeana on Mar 8, 2006 23:19:20 GMT 1
You can also get them from a yam dealer
norbo
Mar 11, 2006 0:46:34 GMT 1
Post by Norbo on Mar 11, 2006 0:46:34 GMT 1
Just trying to save you money . If you dont have to spend your money dont .
norbo
Mar 12, 2006 12:37:26 GMT 1
Post by mellow on Mar 12, 2006 12:37:26 GMT 1
just a thought.....................its been stated in haynes manual a small airlock can happen in top of caliper where pipe goes in..............says to remove the rear mounting bolt...........slacken the front one and pivot caliper so about 30% of pad material is in contact with disc then bleed it. just a thought n worth a try
norbo
Mar 13, 2006 12:33:06 GMT 1
Post by Norbo on Mar 13, 2006 12:33:06 GMT 1
Give that a go and if it does'nt fix it you can have a nether one for £10 i cant get a repair kit no one does one. sorry
norbo
Mar 13, 2006 18:23:45 GMT 1
Post by mellow on Mar 13, 2006 18:23:45 GMT 1
i find this strange how do yamaha decide which bits 2 discontinue...........u can get nearly every part n sum panels.............i enquired for a fuel tank in sheer desperation.............discontinued y sell other panels if the bit that rusts is discontinued wierd ok thats my little rant over
norbo
Mar 13, 2006 19:34:06 GMT 1
Post by Norbo on Mar 13, 2006 19:34:06 GMT 1
Yam has stoped making all lc parts . they become discontinued when the stocks run out.
norbo
Mar 13, 2006 20:01:18 GMT 1
Post by mellow on Mar 13, 2006 20:01:18 GMT 1
surely if theres a demand for them which there seems to be wouldnt it b in their interest to make sum more to fly their flag as it was
norbo
Mar 14, 2006 12:36:42 GMT 1
Post by Norbo on Mar 14, 2006 12:36:42 GMT 1
Not on the grand scall of things . They became obsoleet last year.
