Post by x444guy on Feb 26, 2013 16:03:35 GMT 1
Trying to sort out my front brake must have to many bubbles
Post by flames on Feb 26, 2013 17:07:21 GMT 1
looks like they came up really well dude.
Post by jollyjoiner on Feb 26, 2013 19:12:43 GMT 1
I've put my crank case halfs back together today
Post by steeley on Feb 26, 2013 19:48:10 GMT 1
been in the garage today and finaly got my rebuilt tzr front caliper bled up.had the bike going and the screw fix battery i fitted on it looks like its gave up after 3 years ,bugger.
Post by deltadave on Feb 26, 2013 20:16:09 GMT 1
put some new rubber grommets on and put the rad on ,also recieved some new bits from Norbo ,cheers mate
Post by speedysquires on Feb 26, 2013 21:34:33 GMT 1
Ordered some parts for my LC then started stripping the TZR in readiness for my hybrid build All I need now is some cash, lol
Post by billbott on Feb 26, 2013 23:45:47 GMT 1
Walked past th'LC in the garage again.
m1ke
Post by m1ke on Feb 26, 2013 23:58:17 GMT 1
Forks rebuilt with new seals and progressive springs.
Post by raven13 on Feb 27, 2013 0:13:12 GMT 1
put the number plate on
Post by Bozzy on Feb 27, 2013 0:27:42 GMT 1
polished forks and rear break lever then realised I had just removed orginal green coating...doh.. bought a silver tyre pen ready for painting those tyre letters...
tripodtiger
Australian RD/RZ Owners Register
Post by tripodtiger on Feb 27, 2013 5:42:22 GMT 1
Tried to remove the seized bleed nipple in my caliper and subsequently snapped it off. Then I drilled it and put a screw extractor in it - which snapped off too. Now I have a very hard and undrillable extractor stuck too! I gave up and went back into the warm!! Anyone got any ideas how to get it out?? Try 'freeze & release' aerosol? Then try heat. Another drill extractor with an impact driver? Not today, but just the other one... Pulled the barrels off to have a squiz. Found this on the right hand side. That'd be why it stopped with the rear tyre about 2 ft out to the right. Today...getting manual fuel taps for my XS11 in the mail Hope they fit & Waiting for the engine reconditioners to ring and tell me I can pick up my 250 AC barrels AND my 350 LC barrels after having them all freshly re-bored. The 250 is +.25. The 350 is +.75. Now it's late in the day & they haven't rung.
Post by cinder on Feb 27, 2013 10:05:43 GMT 1
started assembling my mick abbey pipes.its gonna be a long process
Post by grunt33 on Feb 27, 2013 10:13:02 GMT 1
fitted my stainless rad cap and drank a beer looking at it
Post by Norbo on Feb 27, 2013 10:21:12 GMT 1
nice . Now you will be bringing this lovely bike to one of our shows wont you . would love to norbo but she's not really up to show standard and looking at some of the beauties on your stands she would let the side down a little... Flames.....thats what i said to the bloke i bought them of .. It doesnt need to me mint mate . just nice and clean and it is that and better its not a yam. If you do fancy doing a show you and your bike are most welcome.
Post by withnail62 on Feb 27, 2013 17:48:21 GMT 1
Spent an hour in my garage so now I can join in, Started stripping my 500 down for its winter clean/refurb, the clutch was slipping under load so going to put some yzr springs in so gearbox oil drained ready to take the clutch case off! Carbs came off next going to tweek the pilots before a good clean then refit, Rode the bike quite a lot in the rain last year so need to give all the hard to clean parts a good seeing too, Just made me feel a load better using my spanners again, Roll on spring.
Post by skydemon on Feb 27, 2013 19:05:56 GMT 1
I took mine out for a spin today. Coughed spluttered and generally didn't run well moots of smoke and a general feeling of sluggishness. Then stopped smoking but a little smoke from the offside pipe. Just once did it burst into life and I nearly shat myself so something is not right :-( Also to add to the misery the clutch cable is on full adjust and just pulls in but slips when stationary :-( is clutch replacement an easy job as I am NOT mechanically minded at all. Comments appreciated as always :-) It was amazing when she did pop into life :-) when I got back I noticed lots of black oil up the number plate too. Not such a good day. But that momentary burst is still making me smile :-)
Post by marsbar350 on Feb 27, 2013 23:56:41 GMT 1
you can adjust the clutch in another place take the cover left hand side of the engine.the 3 pointed emblem cover try that it may help sounds like it running a little rich.change the plugs and give it a good thraping ;D
Post by Splodge on Feb 28, 2013 0:31:52 GMT 1
I have fitted the rebuilt engine back in the RD400 frame this evening ;D ;D
Post by skydemon on Feb 28, 2013 0:39:32 GMT 1
Cheers MarsBar. Plugs ordered (iridium) will check air filter too. Filled with super unleaded and hope a good blat will sort it. Worried about the smoke as I have read it can be a seal :-(
Post by x444guy on Feb 28, 2013 8:45:14 GMT 1
Just ordered a small shine horn
Post by Bozzy on Feb 28, 2013 14:33:18 GMT 1
Just ordered and set of Banshee coils for my PV.. ;D
Post by raven13 on Feb 28, 2013 16:57:01 GMT 1
i did this click the picture to play the video
Post by steve h on Feb 28, 2013 17:35:05 GMT 1
You found your bike has been nicked?
Post by sidney on Feb 28, 2013 22:49:52 GMT 1
Just put my crank in one half and gave it a wizz round ;D
scoobysal
If it hurts, you know ya made it.
Post by scoobysal on Feb 28, 2013 23:13:46 GMT 1
Looked at it and took the Harley out. Rd is in bits at the moment.
Post by kennyroberts on Feb 28, 2013 23:19:32 GMT 1
stuck my new seat on it,. picked up today
Post by steve h on Mar 1, 2013 18:58:56 GMT 1
Took the seals out of a pair of spare fork legs, and found that a previous moron had managed to score the surface where the seal sits If he / she was a spark, I wouldn't let them change a fecking light bulb!!!! P.S. spell check recognises that "fecking" is a spelling mistake ;D ;D ;D
Post by grunt33 on Mar 2, 2013 3:37:25 GMT 1
just fitted a new chain on the lc and the fz project . ordered parts of norbo on thursday night and realised i need a few more bits and bobs
Post by rzsteve on Mar 2, 2013 7:49:33 GMT 1
Rode my RZR250 up and down the garden
