Post by shell2tx on Jan 8, 2020 0:40:05 GMT 1
Not today but Sunday built 3 lc bottom ends and another 2 to get started and a pv engine.
Post by supermoto57 on Jan 9, 2020 16:59:35 GMT 1
Post by supermoto57 on Jan 9, 2020 17:03:49 GMT 1
Post by supermoto57 on Jan 9, 2020 17:12:21 GMT 1
Post by barrow on Jan 11, 2020 0:01:26 GMT 1
finished stripping my f2 restoration... clocked that the fairing bracket was bent ...... but top end in great condition...
Post by tacky1 on Jan 12, 2020 8:45:58 GMT 1
Got my Red Black 500 back running. Finished fitting the carbs today, cut the throttle cables. The left ones were just too long. finished up the wiring, added coolant. All new fuel lines. Added fuel and fired her up. It’s been a year since I fried it. Sounds class
Post by marrcel on Jan 12, 2020 11:52:25 GMT 1
Polished my spannies. Why? I got bored while waiting for my honed barrels😤
Post by tacky1 on Jan 13, 2020 4:34:19 GMT 1
Post by gozoboy on Jan 13, 2020 23:09:14 GMT 1
stevvo
Post by stevvo on Jan 17, 2020 19:59:54 GMT 1
tomtom1
Leeds
Post by tomtom1 on Jan 18, 2020 17:32:23 GMT 1
Fitted some new brakes hoses on my 31k, back one was bigger to bleed up, but all done now😁
denver
Post by denver on Jan 18, 2020 17:48:57 GMT 1
Got a couple KX100 carburetors in the mail from ebay. Pulled them apart and set in pine sol solution.
Post by rigga on Jan 18, 2020 18:09:52 GMT 1
Not today but Sunday built 3 lc bottom ends and another 2 to get started and a pv engine. Not all your own surely?
Post by boomflamingo on Jan 18, 2020 18:59:53 GMT 1
Got the bike started, smoked like a b*****d and loads and loads of brown sludge came out the exhausts
First time it has been started in 5 years
Was very pleased as bike is new to me and engine sounds great
tlmark
Post by tlmark on Jan 19, 2020 15:10:26 GMT 1
After spending nearly a year looking for one, at a sensible price.
I got a battery strap
before
now
Post by shell2tx on Jan 19, 2020 19:34:43 GMT 1
Yes unfortunately they are all mine 1 4l0 late already built 1 4l0 early still to finish bits n bobs a 4l1 bottom with late 4l0 barrels a 4l1 bottom with fahron topend a 4l1 with fast road tuned topend and a std 250 and a ypvs there are worse things to waste your money on . Started building an lc yesterday its surprising how far you can get when you have most parts ready to go on. I find its easier to build engines in series as you dont miss anything out along the way got another 2 bikes to start very soon and 5 10v dt125lc,s after that .
Post by stusco on Jan 19, 2020 19:53:50 GMT 1
After reading motorcycle mechanics elsie edition I went and uncovered mine just to make sure it was better looking than the ones in the mag😉
Post by dusty350 on Jan 21, 2020 21:51:39 GMT 1
We were throwing an old picture frame out until I decided to repurpose it for the garage. Some of the bikes I have owned and modded over the years 20200121_203626 by dusty miller, on Flickr Dusty
Post by 137d on Jan 21, 2020 22:29:46 GMT 1
Removed the tank on my F2 after it started pissing fuel onto the floor.
Off to Bike Paints in Cupar tomorrow to get it sorted.
Post by gozoboy on Jan 22, 2020 19:25:20 GMT 1
Post by parrott500 on Jan 25, 2020 20:41:05 GMT 1
Well not my bike but I repaired the threads with 10mm Timeserts on the lower crankcases of a RD350LC that someone had kindly stripped while restoring and then sold to my mate along with a million and one other things to put right. I think the seller has a 3 pointed hat and a mask, described 90% done? £500 and counting on the last 10% 2020-01-25_07-06-32 by richard parrott, on Flickr thumbnail_20200125_094604 by richard parrott, on Flickr
busby
RD 350 4l0
Post by busby on Jan 27, 2020 19:56:35 GMT 1
Received a present from my brother today, after crying about the state of the porting that some animal had done on my barrels he sent me a complete top end with barrels on standard bores. What a hero.
Post by dougw on Jan 28, 2020 22:20:48 GMT 1
Picked up a complete 4L0 matching number uk bike last month for £1K, knowing it hasn’t run for at least 8 years.
Seller parked it up after front brakes seized, shortly after having the engine “professionally “ rebuilt.
(My hybrid 4L1 ypvs rebuild has not progressed in the last 10 years)
So far every single thing on the bike has been found to be bodged or miss assembled!
Never mind was sort of expecting it.
Plan A was to fix brakes & electrics, mot it then strip motor and fit new crank seals on a rebuilt crank.
Cleaned carbs, adjusted floats so fuel could get in, fired up motor, head gasket blew and pressurised system.
Bang goes plan A.
Checked squish before motor out, 2.5 mm lhs 3.0 rhs ?
Carefully screwed in flywheel puller in preparation for the anticipated fight to remove flywheel, flywheel fell off in my hand ! Tapers not pretty but hopefully save able.
Also noted that frame is bent around side stand lug, either crash damage or fat lump sat on it on side stand.
Finished off fixing all the bodged electrics today.
Hoping to give the crankshaft a Holiday with Dave Hodgkinson in a months time.
Bracing myself for the state of the barrels and why the difference in squish...
Post by marrcel on Jan 29, 2020 8:37:19 GMT 1
Matching the pv’s
Post by huggy76 on Feb 1, 2020 18:53:46 GMT 1
1st Feb and managed a little ride out. Result!
busby
RD 350 4l0
Post by busby on Feb 3, 2020 19:05:05 GMT 1
Motor out, crankcases split. Ready for degrease and inspection.
Post by veg on Feb 3, 2020 19:08:31 GMT 1
Fitted renthall super bike bars instead of the micron ace bars, and the pro am fairing bracket, had to re route the clutch cable and brake line looks better got to paint the fairing to match the bike then got to run it in before it goes to daves for a pair of one off pipes.
Post by parrott500 on Feb 3, 2020 19:37:38 GMT 1
Post by pdxjim on Feb 4, 2020 8:17:02 GMT 1
Dropped the chassis and lump off with the pipe man for pipe building. Good to get it out of the way for a bit so I can focus on a few other things and keep Mrs Indoors happy.* * Who'm I kidding, moving on to the bodywork now!
Post by oldbritguy on Feb 4, 2020 22:05:48 GMT 1
Dragged the LC out from hibernation bed to see how it fared over the winter
