Deano
Post by Deano on Oct 3, 2019 19:23:59 GMT 1
Post by Yogi on Oct 3, 2019 19:44:56 GMT 1
Changed my gear box oil....is it supposed to be that colour 😮 Ones things for sure,it did need changing 😱
Post by Tobyjugs on Oct 3, 2019 20:38:16 GMT 1
Yes if you have been ragging it and slipping the clutch a lot.
Deano
Post by Deano on Oct 3, 2019 21:02:08 GMT 1
Never slip the clutch....and only squirt it now and again....bought the bike in March and didn’t know how long oil has been in there...so thought I’d change it...was having trouble finding neutral
Post by earthman on Oct 3, 2019 21:23:00 GMT 1
Never slip the clutch....and only squirt it now and again....bought the bike in March and didn’t know how long oil has been in there...so thought I’d change it...was having trouble finding neutral Haynes manual says to replace that oil every three months or 2000 miles.
Deano
Post by Deano on Oct 3, 2019 21:34:10 GMT 1
Used Motul Transoil 10W-30
Post by beardy on Oct 3, 2019 21:46:47 GMT 1
That’s fine. Lots of different opinions on oil. As long as you change it regularly as per recommended intervals.
Post by beardy on Oct 6, 2019 17:13:51 GMT 1
just painted my centre stand with por15. got a head ache coz I ignored what it said on the tin about ventilation. still living and learning. idiot.
Post by pdxjim on Oct 6, 2019 17:28:27 GMT 1
Stripped my 4u0 forks. Dropping them and footrest hangers off for vapor blasting
Any other chassis parts I should send with em?
crono
Post by crono on Oct 6, 2019 19:03:00 GMT 1
Made my second 31k come back to life. As this is a track bike only I minimized cable loom to just charge battery (lithion lightweight), the servo, tacho and temperature gauge. It ran with 2 kicks. Found an error though, cable splitter of my gas is sticking. Will have to redo that but thats easy.
Post by marrcel on Oct 6, 2019 22:23:55 GMT 1
Recycled my fauled plugs
Post by beardy on Oct 7, 2019 18:49:08 GMT 1
Wow. So are you melting them down to their base components?
Post by beardy on Oct 7, 2019 18:51:35 GMT 1
Refitted my centre stand 34 years after removing it. Practicality over weight saving.
Post by marrcel on Oct 7, 2019 20:29:35 GMT 1
Wow. So are you melting them down to their base components? All oil and carbon oxidises. That’s all 🤗
Post by bodger on Oct 10, 2019 18:16:36 GMT 1
Post by stusco on Oct 10, 2019 18:54:50 GMT 1
Started Deep cleaning for winter
Post by hudtm60 on Oct 23, 2019 20:22:05 GMT 1
not exactly today- but I recently took the Mars Bar to sign my will. Oddly, I drove home like an adult. I don't think I broke a single law.....they are quite a civilized bike when ridden like you've just signed your last will and testament.....needle never near the red...like Plod is on your heels....or a codger commuting on an MZed.. won't last though...
Post by Jethro5 on Oct 23, 2019 22:38:28 GMT 1
Who’s the lucky person who inherits it.😂
Post by JonW on Oct 24, 2019 0:14:12 GMT 1
not exactly today- but I recently took the Mars Bar to sign my will. Oddly, I drove home like an adult. I don't think I broke a single law.....they are quite a civilized bike when ridden like you've just signed your last will and testament.....needle never near the red...like Plod is on your heels....or a codger commuting on an MZed.. won't last though... Eeek Chris that is grown up! Not the Will thing, everyone should have one, but the riding... I guess you didnt want anyone to inherit just yet LOL! Happy memories of spending time in your shed garage mancave.
Post by hudtm60 on Oct 24, 2019 15:26:00 GMT 1
He doesn't know yet- but the guy who found it for me is going to get it if I kick the bucket prematurely- otherwise it's the kid who cares more about guns then bikes....maybe I'll adjust the will so he contacts you lot first when he tries to flog 'em- bit of a shipping issue tho. In the meantime- blowing out the cobwebs on the 81. Got this in 2015, apparently had been sitting a while but back then I knew nothing about cracking open the engine to replace the seals etc etc etc and just ran it. Apart from the 6k flat spot it's always run ok- but always sad when u have to pump up the tires coz it's been sitting too long. Can't face the bicycle pump tho. AirMan to the rescue! lazy t*sser.
Post by pdxjim on Oct 24, 2019 16:17:50 GMT 1
Reassembling the forks after full strip, vapor blaster, seals, etc ... No $$$ for new springs ... how much preload spacers should I add, and what weight oil? Fast rider 210lbs bare.
tlmark
Post by tlmark on Oct 30, 2019 20:59:23 GMT 1
I got to test ride with the my newly fitted gold spot brakes
don't suppose I'll get another chance to ride her till the spring now
Post by pdxjim on Oct 30, 2019 21:31:14 GMT 1
Did you just use an extra set of standard caliper bolts?
tlmark
Post by tlmark on Oct 30, 2019 22:28:07 GMT 1
Yup just another set
Post by tipfinchy on Nov 2, 2019 12:13:00 GMT 1
made a decision on paint for the hybrid and dropped new tank , plastics and decals off with painter be done in a week mart
Post by doohanno1 on Nov 7, 2019 23:47:42 GMT 1
Well i finally conceded that my days of picking up " quare ones" from the local are over.. So, no need for rear footrests..😜 I modded a spare set of footrests.. I think they look ok on this type of lc. !!
Post by doohanno1 on Nov 7, 2019 23:55:00 GMT 1
Before..
Post by hudtm60 on Nov 8, 2019 0:14:19 GMT 1
Tidy. Great paint too.
Post by Tobyjugs on Nov 8, 2019 0:31:57 GMT 1
Reassembling the forks after full strip, vapor blaster, seals, etc ... No $$$ for new springs ... how much preload spacers should I add, and what weight oil? Fast rider 210lbs bare. 14 mm and Bare's favourite ATF fluid
Post by 84rzrider on Nov 8, 2019 2:45:28 GMT 1
