Post by andrel on Apr 15, 2018 7:04:30 GMT 1
Re-assembled my clutch temporarily on my LC rdlccrazy.proboards.com/thread/43560/lc-clutch-surprise?page=2&scrollTo=399800Also swapped the two oil feeds at the pump and the left-side exhaust now smokes about evenly with the right. Fitted new valve block rubbers and airbox rubbers too. Wilst in that process I opened the carbs to have a look and got another surprise - in the one carb some ham-fisted mechanic destroyed the scredriver slot of the pilot jet and in the other carb the main jet just rotated but is stuck and because of the washer I cannot yet see what the problem is. So there is another job for the engineers in future. The needle jets are also ancient with hardly and spring pressure. Threw out the plastic see-through oil feed pipes and replaced it with black pipes which I think look better on the bike. Took it out for a ride and all went well until I got back and noticed droplets of two stroke oil on the bottom engine casing. With my luck it turns out to be the base gasket leaking at the front of the bike and not just a leak at the exhaust fittings. Just another reason to re-do the engine soon. It seems in this bike's case that the mechanicals of the previous engine rebuild is probably fine, but the build is being let-down by the use of bad quality seals and gaskets and a lack of care to ensure that there are no leaks (e.g. leak-down test) prior to final assembly. Aah well, it will keep me busy in the garage for some time which is not such a bad thing.
Post by spookoverload on Apr 15, 2018 9:53:23 GMT 1
Bought it :-) Just need to sort a charging fault out
kevm
Post by kevm on Apr 15, 2018 21:04:18 GMT 1
Went racing at Knockhill all weekend on my R6 13s first time there and first ever race, managed a 59 second lap in the last race :-)
oh and Muttsnutts now has my hybrid bits to build :-)
Post by huggy76 on Apr 15, 2018 21:15:10 GMT 1
I rode my 31k today after rebuilding the forks yesterday with new seals and Hagon progressive springs.
I was a bit concerned after reading some reviews but have to say i am very impressed.
Post by forkedbeard on Apr 16, 2018 9:33:45 GMT 1
Told her "I'm sorry for crashing her 7 months ago, and I'll start as soon as possible to make things right" "I love you".
Post by dangerousal on Apr 16, 2018 22:17:57 GMT 1
Blew the head gasket
Post by sparx on Apr 16, 2018 22:54:49 GMT 1
Nothing But did sell my mates hybrid to another mate
Post by Deleted on Apr 17, 2018 10:30:03 GMT 1
Well on my project, I put the speedo cable on, filled up the gear box with oil and put the rest of the air box and new air filter in. On my everyday LC . I topped up the 2t oil and thrashed the living sh#t out of it. I just can't help it. I'm a bit juvenile at times.
Post by spudscossiecobra on Apr 17, 2018 17:46:04 GMT 1
Cleaned cases for the hybrid engine build filled the oil tank on standard one ready for the thrash when the sun is out tomoz 😀😀😀
Post by donkeychomp on Apr 17, 2018 20:55:10 GMT 1
Coil on...tank off and prepped for paint...
Post by copper99 on Apr 17, 2018 22:10:14 GMT 1
Not so much as blew it as it whimpered out after a few miles, mine started leaking last week after 14 miles, was a genuine part and torqued as it should, no obvious pitting on barrels or head..Anyway put it back together with a new gasket this morning, Jessy03 lent me some Permatex Copper gasket spray to use and so far, after a few short runs, it seems to be water tight, I hope yours is as simple a fix.
Post by Tobyjugs on Apr 17, 2018 23:02:03 GMT 1
Thats unlucky hope it's ok now
Post by midlifecrisisrd on Apr 18, 2018 21:21:53 GMT 1
Not strictly today, story starts last week.
Thought I'd finally finished the 400 ac engine build for Rod
Was well happy till a little doubt crept into my head about the squish as barrels are tuned and heads have been machined down and the chambers recut
0.6mm
Bugger!
Thicker gaskets arrived today so all back together
Post by Yogi on Apr 18, 2018 21:42:32 GMT 1
Not strictly today, story starts last week. Thought I'd finally finished the 400 ac engine build for Rod Was well happy till a little doubt crept into my head about the squish as barrels are tuned and heads have been machined down and the chambers recut 0.6mm Bugger! Thicker gaskets arrived today so all back together Steve Close escape
Post by wallcraft on Apr 18, 2018 22:33:27 GMT 1
Not strictly today, story starts last week. Thought I'd finally finished the 400 ac engine build for Rod Was well happy till a little doubt crept into my head about the squish as barrels are tuned and heads have been machined down and the chambers recut 0.6mm Bugger! Thicker gaskets arrived today so all back together Steve What was the final figure you ended up with on the squish Steve Mark.
Post by midlifecrisisrd on Apr 19, 2018 8:02:05 GMT 1
Not strictly today, story starts last week. Thought I'd finally finished the 400 ac engine build for Rod Was well happy till a little doubt crept into my head about the squish as barrels are tuned and heads have been machined down and the chambers recut 0.6mm Bugger! Thicker gaskets arrived today so all back together Steve Close escape Yeah, reckon it wouldn't last long at that Steve
Post by midlifecrisisrd on Apr 19, 2018 8:05:33 GMT 1
Not strictly today, story starts last week. Thought I'd finally finished the 400 ac engine build for Rod Was well happy till a little doubt crept into my head about the squish as barrels are tuned and heads have been machined down and the chambers recut 0.6mm Bugger! Thicker gaskets arrived today so all back together Steve What was the final figure you ended up with on the squish Steve Mark. I played it safe and ended up at 1.1mm Reckoned on an old air cooler with unknown tune and recut domes I'd be pushing it Especially with today's unleaded Steve
Post by copper99 on Apr 19, 2018 14:37:57 GMT 1
Post by copper99 on Apr 19, 2018 14:43:41 GMT 1
MarsBar's swanky new yokes n clocks....
Post by jackjabba on Apr 19, 2018 20:25:35 GMT 1
Took the LC2 for its MOT. First ride with MikesXS emulators fitted. Wow what an improvement. The only problem is that the brakes now feel very poor without the masses of fork dive I had before.
Post by donkeychomp on Apr 19, 2018 20:54:28 GMT 1
Painted the underside of the tank, fitted new dials in the rev counter, painted the needle too, and started cleaning up an FZR400 rear wheel.
Post by steven on Apr 20, 2018 17:51:28 GMT 1
....phoned a local Yamaha dealer to ask if he had a 4L1/4L0 battery in stock, to be told "No, sorry we dont stock anything for the old Yamahas, try the Chinese bike shop, some of them use the same type of batterys." ..... Oh, I did mix up some 2 stroke as well, for the first time this year... for my strimmer ! Nice to see the summer is eventualy here, it was snowing two weeks ago ! Is anyone else on holiday next week ?....... I AM ! :-) Steven.
Post by oldelsieboy on Apr 20, 2018 18:20:22 GMT 1
....phoned a local Yamaha dealer to ask if he had a 4L1/4L0 battery in stock, to be told "No, sorry we dont stock anything for the old Yamahas, try the Chinese bike shop, some of them use the same type of batterys." Steven. Ask them for a YZF-R 125 battery, it is the same. OEB
Post by dave1963 on Apr 20, 2018 19:33:49 GMT 1
Went up to fahron and picked up the 370 head and barrells from ron just got them o ringed kept blowing head gaskets. Got home and put it together started it but wait till morning and put some water in it and hope for no more leeks
Post by Yogi on Apr 20, 2018 19:36:42 GMT 1
Went up to fahron and picked up the 370 head and barrells from ron just got them o ringed kept blowing head gaskets. Got home and put it together started it but wait till morning and put some water in it and hope for no more leeks Don't put vegetables in your engine
Post by steven on Apr 20, 2018 19:43:55 GMT 1
....phoned a local Yamaha dealer to ask if he had a 4L1/4L0 battery in stock, to be told "No, sorry we dont stock anything for the old Yamahas, try the Chinese bike shop, some of them use the same type of batterys." Steven. Ask them for a YZF-R 125 battery, it is the same. OEB Hi OEB, Thanks for the info. I will go to a more "Classic friendly" bike shop, it was the wee bit of sun that reminded me that I need a battery. Cheers, Steven.
Post by mattybeckett on Apr 20, 2018 21:32:58 GMT 1
Sun was shining and a cracking day, so dusted her off ' fired up first kick, then went for a 50 mile ride out, ran absolutely perfect. Good old elsie your now worth all that care/money and attention i sometimes enjoyed spending with you over the last 2 years getting you to perfection. Well worth it now and looking forwards to some more trouble free rides out.
kevm
Post by kevm on Apr 21, 2018 18:30:23 GMT 1
Had my first proper run out since Dave Whattam built the engine and dyno'd carbs, i cant stop smiling. All the sports bikes and nakeds at the usual haunts in Northumberland didnt stand a chance. Tried chucking it at some corners and was very surprised how it handled just the brakes that keep you on your toes :-) LC playing out by Kevin Monaghan, on Flickr
Post by donkeychomp on Apr 21, 2018 21:28:28 GMT 1
SNAP!
yamasakijase73
Restoring my 1st ever bike been a 1981 350lc..all advice welcome..
Post by yamasakijase73 on Apr 22, 2018 5:38:27 GMT 1
My first ever restoration is going ok the frame is at a mates for a bit of welding..so I bought myself a parts washer and started cleaning up and Dr-greasing what I can..I'm a total novice but loving it...
