Post by philip on Mar 6, 2006 6:38:35 GMT 1
The Yamaha RZ350R brake caliper has two pistons, will one piston from this caliper fit the RDLC caliper which only has one piston?
Thanks
Philip.
Post by hooligan on Mar 6, 2006 8:53:27 GMT 1
Hi Philip
Norbo will put you right but I'm 99% sure the 350R pistons are twice the lenght of the RDLC ones. I tried to shorten some a while back in my lathe but there hardened and ground and all that hapend was it wore away my cutter.
Post by Norbo on Mar 6, 2006 12:02:12 GMT 1
LC pistons are a lot longer they will not fit sorry . If you need an lc one i have new ones with new seals as well .
Post by philip on Mar 7, 2006 12:41:00 GMT 1
Could you post 2 kits to Australia with a rebuild kit for the LC350 master cylinder
Thanks
Philip
Post by Norbo on Mar 8, 2006 14:01:09 GMT 1
yes not a problem post would be just £5 they wont waigh that much
