Post by bertiemollie on Jun 8, 2012 10:58:21 GMT 1
Hi Guys,
Just fitted a 4CE-00 CDI in my N2 and it won't start. There is a blue wire on the CDI which isn't on the 1UA CDI which I understand is for the sidestand cutout switch.
Does anone know whether this blue wire should be earthed or positive?
OR has anyone got an RD350R wiring diagram? The one in the Haynes manual says RD350R and N2 / F2 are the same which they are not.
Cheers
Andrew
Post by Norbo on Jun 8, 2012 11:24:03 GMT 1
I think you may need to conext the two wires together .
Post by 47x on Jun 8, 2012 11:26:02 GMT 1
i was under the impression that a 4ce cdi will only work on a r loom???hey andy,i have a 1ua cdi you can have for £30,all working but no plugs ::)pm me if you have no luck m8 ;)DO NOT connect the wires together.
Post by bertiemollie on Jun 8, 2012 11:53:35 GMT 1
I think you may need to conext the two wires together . Hi Norbo, Which 2 wires? I have 1 more wire on the 4CE CDI than on the 1UA CDI. This is a blue wire. What do I connect it to + or -? Richie - If it goes badly I'll let you know. Cheers Andrew
Post by Deleted on Jun 8, 2012 11:59:29 GMT 1
If you need one, you can get good laminated colour wiring diagrams from here: www.kojaycat.com/index.htmI bought one for my F2 and I can recommend them.
Post by 47x on Jun 8, 2012 12:47:42 GMT 1
ok m8
Post by bertiemollie on Jun 8, 2012 13:25:00 GMT 1
All sorted now.
Blue wire to earth.
Thanks guys.
Cheers
Andrew
Post by 47x on Jun 8, 2012 15:04:07 GMT 1
well done m8.
Post by phats on Mar 25, 2015 9:49:07 GMT 1
Nice one having same problem with my mates will give that a go
