carbs
Feb 1, 2006 11:26:06 GMT 1
Post by Deleted on Feb 1, 2006 11:26:06 GMT 1
Are there any differences between the 4l0 carb bodies and the 4l1 ? I have a good set of 4l1 bodies and would like to know if they can be used on my 4l0. Cheers, Kev.
carbs
Feb 1, 2006 13:07:39 GMT 1
Post by Norbo on Feb 1, 2006 13:07:39 GMT 1
Hi Kev You can use them but will need to rejet them as the 250 runs a smaller jet then the 350 and the pilet jet is smaller to bit i wouldent worry about that to much . Yopu will need the holl carb . As the internals like the needle and emulshon tube are not the same .
carbs
Feb 1, 2006 13:11:58 GMT 1
Post by Deleted on Feb 1, 2006 13:11:58 GMT 1
Cheers Norbo. Will swap all internals over.
