Post by davey on Oct 10, 2011 14:46:11 GMT 1
what the compression stats of a 250 lc guys from hot and cold. not standard bore its +25 if it makes any difference .
thanks
Post by steven on Oct 11, 2011 9:56:37 GMT 1
Hi,
CP (compression pressure) = 17-20 x CR (compression ratio) So for your 250 LC with a compression ratio of 6.2:1 = 17 x 6.2= 105.4psi 20 x 6.2= 124psi.
So by using this approximation your compression figure should be somewhere between 105.4psi-124psi (7.17bar-8.4bar)
This is only a theoretical figure. Ideally you should take the readings with the engine at operating temperature. Perhaps someone else has taken compression readings on a known good engine and can let us know what the reading is in practice, as opposed to this theoretical guestimation. Ideally you are looking for both cylinders to be the same pressure, with no more than approx a 10% difference. HTH Steven.
Post by davey on Oct 11, 2011 11:01:18 GMT 1
Thanks steve
